#1 |
Mudslinger extraordinaire
Location: Ashington, Northumberland Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
Rear bumper removal.
As it was fairly nice today (wind below 60 knots and no sleet) I decided to crack on with prepping for the removal of the engine/gearbox/subframe.
This give me the opportunity to do a how to for removing the rear bumper so that I can have a matching pair of bumper removal how to's. The first thing I did was to get the car off the ground to make access a bit easier (not necessary for bumper removal). ![]() There are a total of 9 screws, bolts and nuts holding the bumper on. ![]() There are 2 cross headed screws on the rear of each wheel arch. One is right at the bottom, holding the plastic liner ![]() And one towards the top of the bumper wheel arch section. ![]() It is in a recess out of view and took me a while to realise they were there. ![]() It is easily removed with a screwdriver. ![]() Once these screws are out, the sides of the bumper are free to move. ![]() Next you should disconnect the 2 electrical connectors that go through the rear of the boot to the number plate lights. You can push the grommets through the holes with a screwdriver. ![]() Next, remove the 2 Torx bolts (T-50), one above each exhaust finsher. ![]() I found it easier to remove the exhaust finishers as I have the superior quad setup. If you have the inferior single finishers then you might not have to. ![]() ![]() This just leaves the 3 x 13mm nuts inside the boot. There is one each side, under the rear light clusters. ![]() And one central one under the boot lock. ![]() The middle one is recessed and a pain to get to with a spanner. Best bet is a deep socket and a ratchet with an extension. ![]() Once the last nut is removed it is just a case of sliding the bumber rearwards. You might want to put a blanket on the ground in case you drop it. This should stop it getting scratched. Congrats, you are now minus a bumper.
__________________
#2 |
is on the up!
First class as ever CJJ and perfect timing as I plan to remove mine this weekend to fit the mesh
__________________
Enclosed K&N, 52mm TB, Miltek, AP fast road clutch, WON Streetblaster 150i kit, Additional brake servo bracket, MS front 280mm brakes (Black Diamond drilled & grooved discs, Predator pads), 280mm rear brakes (Greenstuff pads), SS Braided brake hoses, TF solid subframe mounts, Polybushed, Lowering pins, Gaz adjustable shocks, MS bell crank, SEAT Leon front splitter, Alpine ICE, MKII center console, Colour coded interior
Has hydragas pump - will travel ![]() |
#3 | |
__________________
#4 |
Location: Alnwick,Northumberland Car: MGF,75th Anniversary VVC
Looking at your second photo CJ, I see the kids have been setting off fireworks & pinching your number plate letters again!
__________________
#5 | |
__________________
#6 |
Ah yes, left over from Valantines day?
__________________
#7 |
Now with added Blue Flame
While the bumper is off, always worth taking the crush boxes off and checking for rust on the connecting edge (and treating if necessary). Apply waxoyl before repositioning
![]() Hopefully, an 04 should be ok though! |
#8 |
Why are you taking the engine, box and frame out of a clean recent car?
#9 |
Good tip. I will be doing the lot when the subframe and heatshields are out.
__________________
#10 | |
![]() Seriously though, lots of jobs to do, such as timing bels, head gasket, clutch, modified clutch arm. I am also going to modify the bulkhead to give more room in the engine bay between the engine and seats.
__________________
#11 |
regained interest
wont the fuel tank have something to say about that ????
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#12 |
__________________
#13 | |
If you do eventually have to sheer the bolts off, you'll need to remove them afterwards with a hacksaw or angle grinder. If you use an angle grinder, be careful of hot filings becoming embedded in the bumper! (an old damp towel or cloth coul be used for protection) Good luck Dan, hope the job goes smoothly
#14 |
Richard
great job as always Clive
#15 |
#16 | |
__________________
#17 | |
__________________
#18 |
my cabbages appreciate me
Location: No Place - Beamish co durham. Car: MGF Trophy 160 - Miss lemons
Fantastic guide which is going in my bookmarks, I have rust appearing behind my bumper. Will use this when i come to fixing it Cheers!
#19 |
Oy! CJJ, Im sure I spotted your car at the metro center last week!!!
do you park in the debenhams carpark sometimes?! yip was deffo you, blue 160 TF. |
#20 |
Great how to...
Er - how did you get the car up both front and rear ramps? |
| Bookmarks |
| Thread Tools | |
| rear bumper removal guide | Deano | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 4 | 03-01-2009 11:46 |
| Rear bumper removal 620 | jd76 | Rover 600 | 2 | 11-10-2008 18:15 |
| rear bumper removal | davy2xl | MG ZT / Rover 75 | 1 | 23-07-2008 21:30 |
| Rear bumper removal | 62car | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 5 | 10-02-2008 16:05 |
| 75 Rear Bumper Removal | pc1962 | MG ZT / Rover 75 | 0 | 08-09-2004 14:28 |
