Old 06-04-2009, 01:34   #1
happychappy#1
Car: Other Manufacturer
happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.happychappy#1 has a reputation beyond repute. Respect.
A pillar tweeter builds for a MY2000F/TF how to
As a follow up to my “glove box sub box” how to I thought I would show how I built the latest addition to my TF, some A pillar tweeter (APT’s) builds.
For those of you that haven’t a clue as to what I am on about I will try to explain, the tweeters in a standard MY200F/TF are positioned reasonably well, but there’s always room for improvement. By moving the tweeters up into the A pillars it increases the sound stage (stereo effects) thus making the listening experience more enjoyable and accurate.
Before you start you will need:-
Supplies
Fibreglass resin + catalyst
Cheap paint brushes
Speaker cloth
Contact adhesive
MDF
Glass paper
Material to cover builds, I used Vinyl.
Specialist Tools
Hot glue gun
Hole saw
Scalpel
Dremmel
Initially
First you will need to aim the tweeters. This is usually done by placing some blue tack on the rear of the tweeters and sticking them to the A pillar trims and moving them around until a satisfactory sound pleasing to YOUR ears is achieved. The aiming of the tweeters should not be rushed into, you should listen to some music that you are familiar with so that you can get the sound spot on, this can take many hours to get just right, do not rush it. Once this has been achieved mark the height/placement on the A pillar trims with some Tipex or such like.
The tweeters should look something like this:-
Making a start
Next you will need to remove the APT‘s, first fold the hood back and make a start by removing the two screws that hold the sun visors on and remove them and then the sun visors:-
Next up remove the metal clips that hold the soft top to the windscreen, these are held in place by two Torx screws (T27S), unscrew these and remove the clips:-
Now place you fingers, windscreen side, under the top trim above the mirror, pull down sharply to remove. Repeat this with the A pillar trims on either side, work from the top down on these.
The build begins
By now you will have an idea of where the tweeters sound best and you will need to make a hole to help the fixing of the tweeter cup and the wire.
Now you need to make some tweeter cups, I used a pillar drill and hole saws but if you are careful a jigsaw could be used, this is what the cups for my tweeters looked like:-
These now need to be hot glued to the APT’s as close to the position that you found best for your ears, don’t worry if they are not spot on at this stage as you will be able to adjust them later:-
Refit the APT’s to the car and aim the speakers once again using the tip of the glue gun to melt the hot glue and also add some more when your ideal position is reached (this part can take some time). When you are satisfied with the position carefully take the APT’s off and make some legs for the cups to add some strength:-
Once the cups are in the correct position try them out again, you can never do this enough times! Now take the APT’s off again and check that they are a mirror image of each other, if they are you are now ready for….
The messy stages.
Start by giving the tweeter cup side of the APT’s a rub down with some coarse sandpaper, 60 grit is what I used, to give a key for the resin, also turn the APT‘s over and key the edge of the rear of the APT‘s . Once you have done this you will need to attach the speaker cloth to the APT’s. Turn the APT’s over and Working a small area at a time run a small amount of hot glue along one of the keyed edges, as you attach the speaker cloth press down firmly on the cloth to make sure that it sticks well to the APT’s, also try to squash the glue line down as you do not want to add unnecessary bulk to the rear of the APT’s. When you have attached the cloth along one complete edge it now gets a little harder as you will now have to do the other side and this needs stretching as you are doing so, 8 pairs of arms is handy here! Alternatively a partner or friend will do. Now trim the excess material off leaving an overlap of around 10mm:-
When you have finished they should look like this:-
Try to keep the material at the top end of the APT’s a tight as possible:-
You will need to poke the material through the tweeter cup to achieve a smooth and flowing shape to the builds, to do this I used a measuring spoon from the kitchen to push the material whilst hot gluing the rear, when doing this some talcum powder on the rear of the spoon will help to stop it from sticking as will rotating the spoon slightly too:-
Note hot glue:-
Cont in part 2......
happychappy#1 is offline   Reply With Quote
Old 06-04-2009, 01:55   #2
happychappy#1
A pillar tweeter builds for a MY2000F/TF how to Part 2
Ready for the resin.
Mix up your resin (I used around 100ml per coat) according to the instructions (usually 2ml catalyst to 100ml resin) and brush onto the builds, going right up to the edge but not over it, remember you do not want to add bulk to the rears as this could impede re-fitting, brush resin around the tweeter ring and over lap this by a few mm, do not cover the whole of the hole as it can make things a little harder later. Use the resin sparingly and do not allow the resin to run and drip around the edges, it will make the job much harder come the preparation for the final finish.
Repeat this until 3-4 layers have been achieved, by now the APT’s should be pretty tough.
You will now need to cut the material from around the tweeter ring and tidy it up. I used a Dremmel:-
Once this has been done give the APT’s another rub down with some 60 grit to give a key for the contact adhesive, heres a pic of a before and after being attacked with glass paper:-
The final assault
Its now time to attach the finish, brush contact adhesive onto both the APT’s and the vinyl and wait to dry. Now take the vinyl and cover the APT’s with it, simples……
Well it would be if it wasn’t the most frustrating job in the world!!! I failed on my first attempt and had to start again and to be honest I cannot really describe why it went better the second time, perhaps it was just luck, even so I am still not 100% happy as there are a few more wrinkles than I would have like but they are pretty much hidden from view and I have received quite a few pos comments now, besides when you are immersed in the quality sound that is now emanating from your ICE you will soon forget about a few wrinkles….
A few tips I would like to pass on is to pull the vinyl hard and only towards the rear edge, oh and you really will need two people for this part of the job. When finished trim the excess material from the rear of the APT’s and stand back and admire.
Re-fit the APT’s in the opposite way to removal and then sit back and enjoy the realms of your hard work.
Any problems please ask away, I will do my best to help.
David
Update
Please see finished pics at post number 18
Old 06-04-2009, 05:34   #3
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
blimey, much as ICE goes over my head, that is some serious clever and pro workmanship there David . I'll add to my ICE web site section later
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 06-04-2009, 06:03   #4
anthracite45
anthracite45's Avatar
Car: 2003 MG TF 160 & 2000 Rover 45 2.0 TD
anthracite45 will become famous soon enoughanthracite45 will become famous soon enough
Seconded, Pete!
Well done mate, what a great how-to! The standard of workmanship looks better than OEM.
Does it make much difference to the overall sound?
anthracite45 is offline   Reply With Quote
Old 06-04-2009, 06:40   #5
happychappy#1
That would be an honour Sir.
Originally Posted by anthracite45 View Post
Seconded, Pete!
It make a massive difference, its as if someone has suddenly jumped onto your bonnet to sing especially for you.
Old 06-04-2009, 07:19   #6
LuCkY
Genetically Different!!
LuCkY's Avatar
Car: Project F2000 coming soon....
LuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to beholdLuCkY is a splendid one to behold
That is a seriously good job mate - why are you not doing this stuff for a living??? You'd clean up, seriously!
See you decided to go with the cloth/resin combo to get the shape right.....good choice - that's what i was suggesting when you first asked me in the other thread, and its paid off really well....looks OE good, and no lumps or lines
Impressive - have some rep
__________________
Out with the old....In with the new. Project 2000 coming soon
Follow my progress here:
http://forums.mg-rover.org/showthrea...t=292529Bucket
MG/Rover models bucket seat fitting 'How To' Here:
http://forums.mg-rover.org/showthrea...08#post3116708
LuCkY is offline   Reply With Quote
Old 06-04-2009, 07:50   #7
designad
Noone ever reads this bit
designad's Avatar
Car: 98 MGF 1.8i
designad is a glorious beacon of lightdesignad is a glorious beacon of lightdesignad is a glorious beacon of lightdesignad is a glorious beacon of lightdesignad is a glorious beacon of lightdesignad is a glorious beacon of light
Seriously good bit of engineering there Happy. You've given me some good ideas for the MIG
__________________
1998 MGF 1.8i - Solar Red
Stainless roll hoops & nipples, alloy knobage, 52mm alloy throttle body, lowered to 300mm, Viper Induction, Toyo R1R's, MS Slick Shift, shift light, TT Mk4, stainless decat.
Member of MG Car Club of Queensland http://www.artxdesign.com.au/hillclimb.gif
designad is offline   Reply With Quote
Old 06-04-2009, 09:28   #8
gotenks1321
is on the up!
gotenks1321's Avatar
Car: BRG MGF VVC & Charcoal MGF VVC
gotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant futuregotenks1321 has a brilliant future
Send a message via MSN to gotenks1321
Looks bloody awesome Dave I was amazed with your glovebox sub but this just goes one better If this doesn't deserve rep then I don't know what does...
Now the question everyone wants to ask, how much for a set
__________________
Enclosed K&N, 52mm TB, Miltek, AP fast road clutch, WON Streetblaster 150i kit, Additional brake servo bracket, MS front 280mm brakes (Black Diamond drilled & grooved discs, Predator pads), 280mm rear brakes (Greenstuff pads), SS Braided brake hoses, TF solid subframe mounts, Polybushed, Lowering pins, Gaz adjustable shocks, MS bell crank, SEAT Leon front splitter, Alpine ICE, MKII center console, Colour coded interior
Has hydragas pump - will travel
gotenks1321 is offline   Reply With Quote
Old 06-04-2009, 21:15   #9
happychappy#1
Thanks for the comments Chaps, most appreciated.
Dan if you have to ask you cant afford.
They only cost about £40 for the materials, plus a pint of blood, a bucket of sweat oh and a swear box filled up to overflowing.....
Seriously if anyone is interested in making their own I am more than willing to give advise.
David
Old 06-04-2009, 21:39   #10
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
Great thread, we could do with more threads like this
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 06-04-2009, 21:57   #11
Dan Coupe
Always Beer in my Fridge
Dan Coupe's Avatar
Car: MG F (Mk II) & Rover Streetwise
Dan Coupe is a splendid one to beholdDan Coupe is a splendid one to beholdDan Coupe is a splendid one to beholdDan Coupe is a splendid one to beholdDan Coupe is a splendid one to beholdDan Coupe is a splendid one to beholdDan Coupe is a splendid one to behold
I am in awe! Nice one - looks OEM!!!!
Dan Coupe is offline   Reply With Quote
Old 07-04-2009, 00:10   #12
Fast Jan
is trying...
Fast Jan's Avatar
Car: TF 160
Fast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these partsFast Jan is becoming God like round these parts
Oh wow how the hell did this thread manage to slip under my radar!
Respect to you David! You take on some pretty hefty challenges, well done indeed
__________________
Experience is a journey, not a destination
For Sale: **17" wheels & Toyo tyres**
Fast Jan is offline   Reply With Quote
Old 07-04-2009, 00:25   #13
Rizem
Car: MG TF 160
Rizem will become famous soon enough
Awesome idea and execution as the others have said. I think you have a niche market product here for the (lazy) people such as myself who would never ever try this lol. That said i'm guessing there's some proper time goes into this even now you've done it before?
Oh and a public thanks for all the help and advice in PM's over my ICE
Rizem is offline   Reply With Quote
Old 07-04-2009, 05:34   #14
Petevick
regained interest
Petevick's Avatar
David, if this is part 1, what is part 2, 3, 4.....going to be
__________________
Old 07-04-2009, 08:49   #15
twe
Car: MG TF (R.I.P.); Mitsubishi Colt Diesel
twe has a spectacular aura abouttwe has a spectacular aura about
looks great... do you perhaps have a final picture of it in your car all set up?
twe is offline   Reply With Quote
Old 07-04-2009, 09:38   #16
happychappy#1
No problems its always a pleasure as it encourages me to research different products, dont forget I would love to have a listen one day.
And also, I really want the interior of your car.....
Twas late and I initially made two separate threads, then realised that they would get lost and suddenly remembered that I could link them via a reply.
Sometimes I guess that I just need my beauty sleep (stands back and awaits "pos" comments )
Wonder if a Mod could remove the "part 1" bit from the heading?
I am going out today to get some, been a bit hectic here over the last few days, MG in for service + MOT and Mrs Happy trying to locate a pair of shoes for a pals wedding.
Thanks once again for all the pos comments and the rep left, much appreciated and dont forget I am always willing to give advice where I can
David
Old 07-04-2009, 11:24   #17
thatone1967
Car: Mk1 Morello Plum "F", Cream Leather
thatone1967 will become famous soon enough
Happy.. you HAVE To go to the Brighton Bunny meet.... have an urgent desire to see your work "in the flesh"
thatone1967 is offline   Reply With Quote
Old 17-04-2009, 10:29   #18
happychappy#1
Finished pics
Better late than never here are a couple of finished pics:-
Close up of a tweeter.
Drivers view, note the new MK1 door panels with no tweeter hole.
And finally a view from the rear (ooh err!)
Old 17-04-2009, 10:32   #19
Petevick
regained interest
Petevick's Avatar
who the frik is WonkyJon
__________________
Old 17-04-2009, 10:34   #20
Broon
Grade A mentalist
Broon's Avatar
Car: MGF(x2), Fiesta Mk3
Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1Broon has reached their true position at number 1
Nice one happy. I love when someone does something completely novel to their cars. Much respect !!
Any pics of them fitted in the car yet?
Broon is offline   Reply With Quote
Tags
f/tf how to, f/tf ice
You may not post replies
TF - Components & Tweeter ihclarke In-Car Audio, Entertainment, Sat Nav etc... 6 26-08-2008 15:28
Mazda builds first new 2 Ian Other Motoring Chat 0 21-05-2007 15:49
Boot Builds!! X-Trophy In-Car Audio, Entertainment, Sat Nav etc... 22 11-05-2007 21:39
door builds Master Yoda In-Car Audio, Entertainment, Sat Nav etc... 3 10-08-2005 21:38
Terms and conditions of use
