Old 14-04-2009, 19:34   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
Fitting a modified Clutch Release Arm
As those who have had their F/TF for a while will probably know, one of the pains that you have to go through is the clutch release arm seizing in the bell housing.
This shows itself by the clutch getting heavy, or the clutch slipping, and finally complete failure.
One solution is to regularly force oil and grease into the point where the arm enters the bell housing and work it until it frees up.
Another solution is to buy a modified clutch release arm from the likes of Mike Satur, for around £30, which has a grease nipple which feeds grease to the contact surfaces and prevents it from seizing.
This is a simple how to, mainly because my engine and gearbox are out of the car. Whether you can do this in the car I wouldn't like to guess. If it is possible you would have to seperate and rotate the gearbox, so that the release arm is pointing upwards.
Here is the standard release arm
And here we can see the clutch release fork, which is attached to the lever shaft by an M8 bolt.
Remove the M8 bolt and washer
and the lever pulls out.
You can see the standard and the modified arms side by side in this pic.
Slide the new release arm through the housing and through the fork. Refit the M8 bolt and clip the release bearing into place.
I didn't show the removal of the bearing in this how to because it is a brand new gearbox and didn't have one fitted.
Here is the finished item.
You can see from the position of the lever in the last diagram that you would not be able to pull it out while in the car as the bulkhead would get in the way. Also bear in mind that there are usually a lot of coolant pipes etc in that area too. I think it would be difficult to undo the fork in situ as well. However, there may be people out there who have done it and would like to share.
For the record, The new and the modified levers turned very easily with one finger. I was going to remove the old one from the orignal gearbox as a comparison, but it was seized solid.
__________________
CJJ is online now   Reply With Quote
Old 14-04-2009, 19:38   #2
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
that's all
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 14-04-2009, 19:40   #3
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
nice work again CJJ
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 14-04-2009, 19:54   #4
SHARKYMGF
Member of the real HCHDC
Car: TF160
SHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud ofSHARKYMGF has much to be proud of
Send a message via MSN to SHARKYMGF
On a nice shiny new gearbox maybe, but on an old box with a seized arm it can be a bit more difficult and involve the use of a large hammer and lots of swearing
SHARKYMGF is offline   Reply With Quote
Old 14-04-2009, 19:56   #5
Chris T
Moderator
Chris T's Avatar
Sounds like you have the been there done that tee-shirt Steve.
__________________
Old 14-04-2009, 19:57   #6
CJJ
CJJ's Avatar
Yep. see the last sentence. This is another reason it would be a pain to do in the car, getting good access for leverage and hammerage.
Maybe I should have put "and simply remove lever" in good old Haynes Manual style.
__________________
Old 15-04-2009, 09:22   #7
CJJ
CJJ's Avatar
So, has anyone fitted on of these with the box still in the car?
__________________
Old 11-08-2010, 06:32   #8
chrisspider21
Car: 1.8 VVC
chrisspider21 is up and running. Hey we all have to start somewhere.
How to remove old arm?
So i`ve now found that my clutch release arm is not working as it should i need to use a large bar to move it.... it does move but it should as you know be easyier to do than this... i understand that i need to :
1. remove clean and replace with grease.....
2. romove and replace with a new one.......
This is my problem how to remove the old in the possition its in, the gearbox has been moved same process for clutch removal but now need to get the arm out... does anyone have any ideas please any advice would be great
cheers chris
chrisspider21 is offline   Reply With Quote
Old 11-08-2010, 09:54   #9
CJJ
CJJ's Avatar
If you can get a large tube over the lever so that you can work it backards and forwards and at the same time get a large screwdriver or prybar under the arm and lever it out while moving it backwards and forwards. Also adding release oil to it every now and then.
Have you taken the bolt out of the fork?
__________________
Old 11-08-2010, 13:50   #10
touche
Car: MG ZR
touche will become famous soon enough
cheers chris
i needed a blow torch and a very large lump hammer and an hours braying to get mine out of pg1 (5 year old 160). I had to bray it so hard I thought the gerabox was going to explode! they can get very very stuck and need some serious persuasion!
touche is offline   Reply With Quote
Old 11-08-2010, 13:54   #11
touche
Car: MG ZR
gear box out by the way, to make room for some big swings!!!
Old 12-08-2010, 18:54   #12
Funky_Munky
Car: MGF
Funky_Munky will become famous soon enoughFunky_Munky will become famous soon enough
Awsome pics CCJ!
Just looking at the gearbox and clutch bell assembly.......is it possible to separate the two just by undoing the bolts closest to the passenger side and separate the two halves? Or are there more bolts that are only accessible from within the clutch bell? I have a slight (almost un-noticable) whine in 5th gear....as some point (perhaps years?) I'm guessing I'm going to have to fix it. I'm looking to see if I can seperate the box into as small parts as possible to aid remove & avoid removing the engine and sub-frame assembly.
Any advice would be cool
Funky_Munky is offline   Reply With Quote
You may not post replies
Checking clutch release arm? rich_b Diesel Forum! 11 10-07-2009 21:39
PG1 Clutch Release Arm tonytiger Diesel Forum! 15 05-03-2009 07:57
Clutch Release arm R65 Digga_hole Wanted 3 07-11-2008 11:40
Clutch release arm seized dalejg MGF and MGTF (Sponsored by MG Rover Parts Ltd) 21 01-06-2008 17:00
How would a clutch release arm seize up? rich_b MG ZR / Rover 25, 200 & Streetwise 6 19-09-2007 09:22
Terms and conditions of use
