MG ZR Boot Will Not Open - MG-Rover.org Forums
Old 28-04-2009, 19:33   #1
Peter Carter
Car: MG ZR
Wink MG ZR Boot Will Not Open
Hi to everybody
My boot will NOT open. It has been fine but tonight after I got home it will not open either on the key or the central locking. The silver push botton just goes in to the stop and nothing happens.
P.S. How do I open it to get into the back of it??
Peter
Peter Carter is offline   Reply With Quote Quick reply to this message
Old 28-04-2009, 19:35   #2
g.warren216si
Car: rover 216 (for sale) mk4 golf gti
try locking and unlocking the car a few times and see what happens. it sounds like the mechanism has jammed.
g.warren216si is offline   Reply With Quote Quick reply to this message
Old 28-04-2009, 19:38   #3
Catterall1
Car: ZR160 daily and ZR160 Track Car
Send a message via MSN to Catterall1
go inside the car, and fold down the rear seats (awkward to do with the parcel shelf still there)
When inside the boot, remove the plastic cover at the bottom of the boot.
Under there you should see a cable going from the boot popper button to the hinge at the bottom centre, have a look and a play and it should release.
Catterall1 is offline   Reply With Quote Quick reply to this message
Old 28-04-2009, 19:45   #4
probey
Car: zs 180, shogun 2.5
Originally Posted by Peter Carter View Post
Hi to everybody
Peter
take off interior trim from inside . where the button comes in from outside, you will see a black lever that this pushes, its stuck in the open position so the boot wont unlock till its pushed back. move it back unlock the boot , then remove it lubr it and free it off on its spring.
probey is offline   Reply With Quote Quick reply to this message
Old 29-04-2009, 07:47   #5
Peter Carter
Car: MG ZR
Thanks to all for the advise
Old 29-04-2009, 10:33   #6
nag1_uk
Car: MG ZR
Hi to everybody
Peter
A similar thing happend to me!
Get into the lock area as suggested to others.
Once I had done this I found that the plasctic that a roll pin goes through to act as a pivot for the leaver on the push button had brocken. This looked to be caused by the roll pin rusting slightly and thus getting to big for the plastic and it then snapping.
To fix the problem I had to buy a new button release unit for about 7 off someone on hear and swap the unit. With a bit of work the key barrel can be swapped between the units to ensure you still have the correct key for the boot.
As a temp measure till it was fixed I left the trim pannel off, tied a bit of string to the realase cable and ran the string to the drivers seat. I then had a remote boot ope system!
Mike
nag1_uk is offline   Reply With Quote Quick reply to this message
Old 03-05-2009, 08:51   #7
shellz
Car: MG ZR
hi , my boot is stuck, since my alarm went off and blew the fuse my boot will not open , when unlocking it makes a noise from the boot like it is trying to unlock but its not , tryed to open boot with key but wont seem to let me put the key in the lock.
also my passenger side door no longer locks .
can anybody help ...??
shellz is offline   Reply With Quote Quick reply to this message
Old 18-01-2015, 16:21   #8
Ross6392
Car: Rover 25
Re Passenger door
i had the same problem on my rover 25 driver side door not locking.
I removed the door card and replaced the locking mechanism which I picked up second and from a local scrapy, and found that this sorted it. I would recommend buying new trim clips for the door panel as I managed to break a few of these when removing it. Cost about 2 for 20 off eay and the lock mechanism was 15. Hope this helps.
I've also got the same problem with the boot lock not opening, going to have a look at it next week will get a video posted it if this helps anyone.
Ross6392 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
MG TF Boot Open Light Sprinter MGF and MGTF (Sponsored by MGFnTFBITZ) 6 30-11-2006 22:38
MG ZT / Rover 75 - 2004/5 - How do you open the boot on a facelift car? kingspade MG ZT / Rover 75 (Sponsored by Rimmer Bros) 25 01-11-2006 16:30
Boot hydraulic arm broken... boot now very heavy (and won't stay open) ;) madfiddler MG ZS / Rover 45 & 400 4 07-06-2006 08:29
MG ZR boot release popping open whilst driving! Staggerin Jim MG ZR / Rover 25, 200 & Streetwise 4 27-04-2005 16:58
