rover 100 wont start - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Metro / Rover 100
Old 04-05-2009, 13:55   #1
mgroy
Car: MG ZT
hi all my son has a rover 100 knightsbridge se that wont start, the battery was flat so i changed it when i turn the key to the first position you can hear the fuel pump start then when i try to start the ignition the is nothing at all, the ignition lights are on and the alarm light led goes off when the button on the fob is pressed "help me please"
regarde mgroy
mgroy is offline   Reply With Quote
Old 04-05-2009, 14:00   #2
FreddieS
Car: Too many!
Send a message via MSN to FreddieS
When you change or disconnect the battery it will lose all power to the 5as, you need to resync, to do this press unlock 5 times iirc, it might be more times, then lock it etc, it will dis-arm the immobilizer and you'll be able to start the car.
Failing that, it could be the MFU has buggered, as the MFU contains the starter motor relay, when they fail they allow the fuel pump to prime but wont allow the car to start.
FreddieS is offline   Reply With Quote
Old 04-05-2009, 14:46   #3
mgroy
Car: MG ZT
have tried what you said and still wont start i am getting a clicking from the silver box in the engine bay
Old 04-05-2009, 15:03   #4
FreddieS
Car: Too many!
by silver box do you mean big square silver box near the RHS wing, thats the ecu, i doubt thats clicking.
more likely to be the throttle stepper motor, which makes a clicking noise when you turn the ignition off or when you reset it by having the IGN on and pumping the throttle 5+ times then turning the ign off.
Old 04-05-2009, 15:20   #5
secretelephant
Car: Other Manufacturer
Check the starter solanoid hasnt come adrift when you changed the battery.
If it is in position, switch on the ignition & connect a wire from the battery +ve terminal to the starter solanoid (you will need to remove the original wire to do this).
MAKE SURE THE CAR IS OUT OF GEAR & BE V CAREFUL WHEN DOING THIS!
If the starter spins over & the engine starts you know you have some kind of wiring fault. If it doesnt then your starter may be goosed or you possibly have a bad earth connection.
secretelephant is offline   Reply With Quote
Old 04-05-2009, 15:29   #6
mgroy
Car: MG ZT
there is defintaly a click sound from the ecu when i turn the key to the start postion just a single click
Old 04-05-2009, 15:46   #7
MetroMartin
Car: Rover 620ti, Metro 1.8 VVC, 1982 X reg MG Metro 1300, Rover 214Si Lotus Elise S2, Porsche 924
Does it go if you bump start it?
How long was it laid up for?
MetroMartin is offline   Reply With Quote
Old 04-05-2009, 16:35   #8
mgroy
Car: MG ZT
not tried to bump it its been parked up a few months but started a few times and never had a problem
Old 04-05-2009, 16:39   #9
yorkiebar
Car: Rover 45
is the battery charged enough?
yorkiebar is offline   Reply With Quote
Old 04-05-2009, 16:44   #10
mgroy
Car: MG ZT
its a brand new battery
Old 04-05-2009, 16:51   #11
yorkiebar
Car: Rover 45
Not missed a lead off at the battery connection?
Old 04-05-2009, 17:27   #12
probey
Car: zs 180, shogun 2.5
clean the thin lead connection going to the starter motor. this lead should have feed to it when ignition in crank position..
probey is offline   Reply With Quote
Old 04-05-2009, 18:09   #13
mgroy
Car: MG ZT
have tryed everything you have all told me and still nothing
Old 04-05-2009, 18:24   #14
probey
have you got feed on lead when cranking?
Old 04-05-2009, 19:50   #15
mikeanodd
Car: Rover 100
i got same problem,,voltage to solenoid on cranking,but it wont spin over,i think solenoid has jammed....bugger
mikeanodd is offline   Reply With Quote
Old 04-05-2009, 20:12   #16
probey
check main lead going to starter motor and check engine earth. if ok give starter a tap...
Old 04-05-2009, 20:32   #17
MetroMartin
Have you tried bump starting it,
Metro starter motors hate to be laid up and if it bump starts fine just needs a replacement starter motor.
Old 06-05-2009, 21:27   #18
mgroy
Car: MG ZT
thanks a lot for all your help bumped car today and it ran just need starter now cheers
Old 09-05-2009, 17:52   #19
mikeanodd
Car: Rover 100
i will try bumping it in the week no rush yet..thanx
Old 10-05-2009, 15:28   #20
mikeanodd
Car: Rover 100
Smile
right...solenoid is goosed..not enuf power to pull yer socks off.i mean it wont throw the cog thing forwards...does it have magnetic coils in it or something?..off to the scrappy for me next week
You may not post replies
1998 rover 400 1.4 16v wont start, wont spark rugrat MG ZS / Rover 45 & 400 7 15-04-2010 20:53
help rover wont start j_o_n MG ZR / Rover 25, 200 & Streetwise 8 04-05-2009 11:20
my rover 100 won't start rovy66 Metro / Rover 100 7 25-01-2008 12:55
Rover 100 knightsbridge won't start spikey_mern Metro / Rover 100 2 09-07-2006 16:01
My rover wont start!!! colthillary MG ZR / Rover 25, 200 & Streetwise 4 10-11-2002 15:00
