Does my car have a DMF? - MG-Rover.org Forums
Old 12-05-2009, 09:01   #1
Clive Speaks
Car: Rover 418 SLD Tourer
Hi there, pricing up a clutch replacement at the moment. I am getting confilcting information as regards whether the car (2001 MGZT 2.5V6) has a DMF. Obviously it makes a huge difference in the price of the bits. Could anyone illuminate please? Apparently Autdata insists that it DOES have one, Rimmers and a local Auto Factors I trust say no it doen't. Help!!
Clive Speaks is offline   Reply With Quote Quick reply to this message
Old 12-05-2009, 09:26   #2
workaholic_ro
Car: Rover 75
All 75/ZT with manual transmission have DMF.
workaholic_ro is offline   Reply With Quote Quick reply to this message
Old 12-05-2009, 09:36   #3
T-Cut
All models with a manual gearbox are fitted with a DMF. However, replacing it with the clutch isn't an automatic step. There are tests set down by the manufacturer (LUK) that can determine whether the flywheel should be removed. This involves measuring the amount of periferal play in the springs.
According to robdrinkwater: 'The maximum permitted movement is 30mm of rotational movement at the edge of the flywheel, using good hand pressure against the springs.
There should also be no more than 1mm of lateral movement at the edge.'
Only when the mechanic gains access to the DMF can it be determined if a replacement is necessary.
Some LUK info here: http://www.schaeffler.com/remotemedi...ose_PKW_en.pdf
TC
T-Cut is offline   Reply With Quote Quick reply to this message
Old 13-05-2009, 10:34   #4
Clive Speaks
OK thanks Guys.
Just won a Borg and Beck clutch kit and slave cylinder on Flea-bay for £160! Result
Can now afford a DMF if needed. Phew.
Help, please. Had new master, slave, clutch and DMF fitted.... but... maleercan MG ZT / Rover 75 (Sponsored by Rimmer Bros) 73 28-03-2011 18:15
DMF(Dual Mass Flywheel) question(s) simon.guna Other Motoring Chat 2 29-04-2009 17:36
Kia Cee’d SW - What Diesel Car? Estate car of the year 2008 Ian Other Motoring Chat 0 16-04-2008 18:37
The Motoring ‘Oscars’ 2008 - What Car? Car of the Year is won by Jaguar XF Ian Other Motoring Chat 0 18-01-2008 14:50
Mercedes-Benz wins two prestigious What Car? Awards in Luxury car & Safety categories Ian Other Motoring Chat 0 19-01-2007 13:32
