#1 |
Mudslinger extraordinaire
Location: Ashington, Northumberland Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
Gearbox Oil Fill how to
The gearbox oil should be checked for level occasionally, especially if you have a leak. Otherwise it should be changed evey 105,000 miles or 7 years.
I have just filled mine up as I have just fitted a new gearbox and drained it to fit a magnetic drain plug. The oil I used was Castrol SMX-S. Filling from empty takes around the 2.4 litre mark, so you will need 3 x 1 litre bottles. The bottles usually have a filler tube built in. In this case you simply break the seal and pull the centre cap outwards. The filler hole is also where you check for the level. It is above the drain plug and to the right, looking from the nearside. You can see them on this pic of my old gearbox with the driveshaft removed. ![]() If you are checking the level, then it should be just below the threaded hole with the filler plug removed. Unfortunately, in real life, the filler is a pain in the but to get to. Remove the filler plug from underneath the engine bay (17mm socket). You will need the car up on axle stands or ramps to do this, but the car must be level when checking or filling the oil. If any oil comes out then the level is OK (should only be a slight weep). I found the easiest way to fill the gearbox was to remove the engine inspection cover and the airbox. I also used a length of tube, one end pushed into the filler You can also see the drain plug on the above photo, it is the shiny one as it is an aftermarket magnetic plug fitted on mine. If you are changing the oil then you will need to remove this and drain the oil into a suitable container, refitting the plug afterwards. The other end of the tube is accessable through the top of the engine bay. Simply fill the geabox from here. Now, just keep filling the gearbox until the oil starts flowing out of the filler hole. Once the oil has stopped dribbling out, refit the filler plug and the gearbox is done. Now refit the airbox and engine cover.
__________________
#3 |
All fluids are present and correct, and holding level, which is always good.
__________________
#5 |
Clutch problems at the minute as I cannot get any pressure. Need to pressure bleed it tomorrow. I don't want to start it without a clutch as it may be in gear and it is up on ramps. Could get messy.
__________________
#6 | |
my cabbages appreciate me
Location: No Place - Beamish co durham. Car: MGF Trophy 160 - Miss lemons
![]() although shares in hammerite might drop
#7 | |
The great god of Hammerite will always be there for us
__________________
#9 |
Are you going to hand paint the BMW?
__________________
#10 |
is trying...
An alternative method of filling without having to go through the inspection hatch is to use a large hypodermic like this one -
with a tube attached - the gearbox can then be filled from below using the filler plug hole. Mine was checked and topped up yesterday (thanks Jerry ) - it took an astonishing 450ml to fill
__________________
#11 |
Very good how to CJJ
& Great idea as well Jan, going to get me one of those from work this afternoon
#12 | |
is trying...
![]() Another perk of the job eh Dave?!
__________________
#13 |
Good call with the syringe Jan, but I had the cover off and had to put nearly 2.5L of the stuff in. Anyway, I ain't got any epideemic nerdles.
__________________
#14 |
regained interest
http://www.mgf-tf-central.co.uk/ht-r....shtml#gearbox
and where might one purchase such a large item from ???
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale Last edited by Petevick; 16-06-2009 at 08:53. Reason: url update |
#15 |
is trying...
__________________
#16 |
regained interest
thanks Jan
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#17 |
is trying...
They can also be bought from farms as this is where Jerry got his - they can be used for.... actually I don't think I wanna say what they can be used for on cows, just make sure you buy a new sealed one
__________________
#18 |
Thanks for these photos. Very useful.
I changed my gearbox oil today. I bought 1m of tubing from B&Q and dropped it down from the gap in the boot. Another way to do this without removing the engine cover! |
#19 |
So how often doe the gear bow oil need changing?
#20 | |
IT Slave
![]() I can imagine a lot of alternative substances to have in that ![]() ![]()
| Bookmarks |
| Tags |
| f/tf how to, gearbox oil change |
| Thread Tools | |
| Automatic Gearbox drain and fill | capese21 | MG ZT / Rover 75 | 2 | 31-12-2007 20:08 |
| gearbox oil | spadam | MG ZR / Rover 25, 200 & Streetwise | 1 | 15-10-2007 17:08 |
| 214si 16v Engine Oil, Gearbox Oil | SplateKseries | MG ZR / Rover 25, 200 & Streetwise | 4 | 05-06-2007 17:39 |
| Gearbox 620DI topped up with gearbox oil | *Victor* | Rover 600 | 4 | 13-08-2004 18:58 |
| Fill to level on gearbox? | MikeO | Others | 12 | 15-03-2004 13:37 |
