7 fault codes !!!! - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 29-05-2009, 15:50   #1
Typhoon 180
Car: MG ZS
Send a message via MSN to Typhoon 180
7 fault codes !!!!
Found a garage today that could read the error codes on my Rover Commerce and this is the list :
P0102 Mass or Volume Air Flow Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0237 Turbocharger Boost Sensor A Circuit Low
P0562 A/C pressure sensor low voltage(Chrysler) I dont have Air con, but on my print out from the garage it says "system Voltage" (low input)
P1402 EGR Metering Orifice Restricted
P1610 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
I have had the light turned off and so far it hasnt come back on, but can anyone explain what each one means please
cheers
Typhoon 180 is offline   Reply With Quote Quick reply to this message
Old 29-05-2009, 16:44   #2
Dakta
Diesel Tuning Dude
Dakta's Avatar
Tower Defence War Champion!
Car: 75 Tourer Conn SE & 45 TDi VNT
Send a message via MSN to Dakta
I'd check the loom for chafing, seems like a bunch of crossed wires!
__________________
Dakta is offline   Reply With Quote Quick reply to this message
What do these fault codes mean.... Southside MG ZR / Rover 25, 200 & Streetwise 5 02-02-2009 23:03
what EXACTLY do these fault codes mean? tall_phil27 MG ZR / Rover 25, 200 & Streetwise 4 05-03-2008 15:30
Fault Codes sbk1972 Others 1 22-03-2005 09:12
Fault Codes Neil brotherton Others 11 21-03-2005 19:41
Fault Codes CliveD Others 0 01-01-2004 15:46
