Bleeding the clutch on a TD4 Freelander - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Land Rover
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-06-2009, 09:03   #1
rikib
Car: Freelander, and ZR
Hi all, my clutch went t'other day.....Started to feel spongy and then just went, could only get 3rd and reverse.......
I've bought a new master cylinder but I wanted to bleed the clutch first to see if that was the problem. Could always resell the cylinder if need be.
I got some fluid (Dot 4), a closed valve bleed pipe.
Method 1, I located the bleed screw, stuck the bleed pipe on it, undid the Master cylinder cover. Opened the bleed screw, raised the pedal, lowered the pedal, raised and lowered etc etc checking that fluid is topped up in reservoir.......At first I got some fluid out of the bleed pipe, but the pedal would always drop straight to the floor. No matter what I did, I couldnt get any pressure to build in the pedal.
So I ditched the bleed pipe, thinking that maybe the valve was faulty, and proceeded to method 2.
Remove cover from Master cylinder, Open bleed screw, raise pedal, close bleed screw as pedal is pressed down, check the fluid (top up if needed), repeat procedure......And, nowt.......Pedal is still flat to the floor
What am I doing wrong......???? I have bled brakes and clutches before, albeit a good while ago, is there anyhting in my methods that are incorrect?
I dont want to replace the master cylinder if it is not needed, but at this rate I might just have to......
Riki
rikib is offline   Reply With Quote Quick reply to this message
Old 04-06-2009, 15:29   #2
c4a5er
Car: Freelander TD4
Fluid is displaced when you press the pedal not when the pedal is raised.
No need to keep locking up the bleed screw as you bleed.
All that is required is a plain tube on the bleed screw and into the bottom of a jar. You will be able to see the aerated fluid being expelled.
When bleeding you will have to raise and lower the pedal by hand as the return spring is not strong enough.
You will need assistance to ensure the master cylinder fluid level does not drop enough to allow air in otherwise you will have to start all over again.
If this doesn't work the master cylinder is u/s and will have to be changed.
c4a5er is offline   Reply With Quote Quick reply to this message
Old 04-06-2009, 19:09   #3
rikib
Well, the old master cylinder had definitely had it......so I had to swap it out for the new one, what a bloody pain it was, the junction that holds the master cylinder in it is a ******** design. A small circular piece of metal, bit like a washer, holds the plug end in. There is a bit of plastic that you push down to release the connector. However, if the connector was joined incorrectly it bends the holding pins, meaning it cannot be uncoupled without a good bit of ingenuity. I used some mole grips on either side and brute force.
Anyhoo, fitted the new master cylinder and it worked great for all of 5 mins ......I bled the system, got a good deal of pressure in the pedal. Gear selection was superb. Then, while trying to reverse out the drive there was a clunk, then the pedal dropped to the floor again
I'm going to try and bleed it as c4a5er suggested, but I am beginning to think that the clutch is fubar and will need replacing.......
So far it's cost me 100 for a master cylinder, fluid and bleed pipe. Not looking forward to having to find another 350-500 for a new clutch.
If anyone sees what looks like the ugliest prostitue hanging around Bolton, dont be afraid, it'll just be me trying to pay off my garage bill
Gives a new meaning to the phrase 'Gettin shafted by a garage!'
Old 05-06-2009, 12:00   #4
rikib
:Update:
Master cylinder not apparently the problem........It appears to be the slave
Oh well, now it's new clutch time......
Does anyone know any decent clutch replacement garages in or around Bolton/Chorley area.......Cheapest I've been quoted is 500 so far......There must be somewhere cheaper than that ???
Old 09-06-2009, 16:48   #5
rikib
:UPDATE of the UPDATE:
Had a new clutch fitted today, 402 fitted plus the 100 I paid for the new master cylinder ........I is officially poor now
At least it's fixed, but it'll take me a bit of time to get used to it again. Why is it that when your car gets sick you lose all confidence in driving it
Anyhoo, I have a feeling the bite point is slightly lower, but the gear changes are smoother so it seems a fair trade off.......Fingers crossed it is fixed, otherwise it'll be seeing the nozzle end of a petty can
Old 13-06-2009, 15:43   #6
COLVERT
Car: R 75 Diesel. Plus Honda CB 1,000 R. motorbike. 130 bhp engine
Well you can always go and hang around in Bolton as you suggested. Your earnings could reduce the garage bill a bit !!!!!
COLVERT is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 15:18   #7
tsam19
Car: Rover Commerce (Van)
Question
Re: Rikib
Hi mate, I'm in the same predicament as yourself.
Here's my thread:
http://www.landyzone.co.uk/lz/f9/wha...ml#post1432117
What garage did you use in the end to get your TD4 sorted, what did you get changed?
Flywheel, Clutch, Release bearing, Slave Cylinder in the bell housing, Master slave cylinder - if so how much for the lot to be changed??
I'm in Manchester and it seems my TD4 is rendered undriveable due to my recent bleeding the master slave cylinder clutch.
tsam19 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Freelander Td4 - Any good? londonmark Land Rover 12 29-12-2008 14:29
Freelander TD4 Clutch Slave Cylinder caterhamnut MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 14-10-2008 15:11
Would LANDROVER FREELANDER TD4 clutch part fit R75 CDT? david_geng MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 10-05-2008 13:23
Freelander TD4 clutch lates Other Motoring Chat 13 26-02-2007 21:32
freelander td4 td4daz Land Rover 0 14-01-2007 14:57
