Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 15-06-2009, 01:17   #1
philmgf
On a mission
philmgf's Avatar
Car: MGF 2002 BRG. XJR1200, Bandit 600 s, gs500 x3, sr125 x3, ybr125 x2 VW Polo, peugoet 207,
philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.philmgf has a reputation beyond repute. Respect.
Coolant level warning with pics and wiring
Hi peoples here is the coolant level warning device ive managed to sort out. I have wired it up and tested it and works fine .
The 12v supply is wired through the ignition so when you turn the key you get 1 very small beep. This tells you that you have supply to the module.
If the level is ok then you will hear nothing else.
however if the coolant is low on starting the car the buzzer sounds continuously until the expansion tank is topped up.
If the coolant drops whilst driving and the coolant stays low for more than 10 seconds (adjustable via the potentiometer) then the coolant warning buzzer sounds continuously until the ignition is switched off and the coolant is replenished.
if the coolant level drops slightly because of tha car cornering (say on a roundabout) then the buzzer doesnt sound because the level rises again before the adjustable 10 seconds has been achieved.
the parts are as listed
circuit board from cpc/farnell code number HK00260
level sensor from maplins or cpc
12v buzzer maplins
mounting abs box from maplins.
here are the pics of the circuit board and wiring.
Hope you find these useful and if it saves an hgf then well worth the relatively small cost.
Have fun,
Phil
philmgf is offline   Reply With Quote
Old 15-06-2009, 07:56   #2
Aiketgate
is back - in black
Aiketgate's Avatar
Car: MGF mk2 Freestyle 1.8mpi 16" wheels
Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.
Talking
Well done, Phil!
A very useful bit of work there.
I've been banging on about fitting low level alarms for ages, and your diagram including a timer circuit means that self installation of a practical system should be within most peoples' ability.
Have some rep.
One question. Is the timer circuit board ready assembled? Or would I need my trusty soldering iron?
David
__________________
NORTH LAKES RUN September 11th
Aiketgate is offline   Reply With Quote
Old 15-06-2009, 08:13   #3
Michiel.B
Michiel.B's Avatar
Car: MG TF 135 Trophy Blue RHD Originally on 03 plate
Michiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. AwwMichiel.B is just really nice. Aww
well done! I've used someting similar, Works a treat
Michiel.B is offline   Reply With Quote
Old 15-06-2009, 08:34   #4
adamelphick
Meg is a nightfire babe!
adamelphick's Avatar
Car: 1998 MGF 1.8i Nightfire with TF Front & 1996 Amaranth F called Fleur!
adamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud of
Send a message via MSN to adamelphick
Originally Posted by Aiketgate View Post
Well done, Phil!
Have some rep.
David
Voila:
http://cpc.farnell.com/jsp/search/pr...equestid=54935
adamelphick is offline   Reply With Quote
Old 15-06-2009, 08:44   #5
Michiel.B
Michiel.B's Avatar
I used this one:
http://www.conrad-uk.com/goto.php?artikel=195901
You have to get your soldering iron out though
Old 15-06-2009, 11:42   #6
philmgf
On a mission
philmgf's Avatar
The module is already built up which is going to be easier for the average diy'er as soldering can quite easily go wrong with tracks lifting etc due to excessive heat and also components being soldered in the wrong way round.
one of the reasons I chose this module.f anyone wants to get the parts and is unsure what to do feel free to pm me and i will ring you and explain over the phone.
To keep the wiring down there is probably an ignition switched live 12v feed in the engine bay somewhere to tap into for the supply.
I will look at the diagrams and give you as location and wire colour to use .
regards phil.
PS thanks for the comments guys.
Old 15-06-2009, 12:10   #7
Michiel.B
Michiel.B's Avatar
You can use a PR wire from the boothinge wiring loom. They give 12v. wheen the boot is closed and 0 V wheen it's open. Quite convenient as when you stop and open the boot the annoying beeper stops
Old 15-06-2009, 12:32   #8
philmgf
On a mission
philmgf's Avatar
Absolute star, how good is that to use. Is that the same on "F"s and "TF's"
Old 15-06-2009, 12:50   #9
Michiel.B
Michiel.B's Avatar
Don't know about that acutally... But a quick check with a multimeter would tell..
Old 15-06-2009, 15:58   #10
Rob Bell
Car: MGF and MG ZT-T (also Mk3 Triumph Spitfire and Mk1 Austin Mini)
Rob Bell will become famous soon enoughRob Bell will become famous soon enough
Nice work. One question - how is the float mounted in the coolant tank? Would it be better to use the MG Rover float-equipped tank instead?
Rob Bell is offline   Reply With Quote
Old 15-06-2009, 16:12   #11
philmgf
On a mission
philmgf's Avatar
there are two types of float available both needing a hole drilling in the tank. both float switches come with a sealing washer .
the one in the picture is mounted in the top of the tank pointing down whereas some can be mounted in the side of the tank.
I don't know if you could use another rover tank due to mounting problems but i'm sure it could be modified to fit with brackets.
where there is a will there's a way
regards,
Phil
Old 15-06-2009, 17:13   #12
Michiel.B
Michiel.B's Avatar
I Bought the original MGR tank and sensor. It cost about £ 35 from Rimmers.
Old 19-06-2009, 11:57   #13
Rob Bell
35 quid from Rimmers is not unreasonable - but Phil's budget busting plan looks very attractive! Do you have any pictures of your completed installation?
Old 19-06-2009, 12:41   #14
Michiel.B
Michiel.B's Avatar
No but If you want I can make one for you. It's pretty much the same setup as Dieter uses on his website with exception of the delay timer.
Old 19-06-2009, 12:53   #15
Pendle Lass
Got her Mojo back!!
Pendle Lass's Avatar
Car: A Drop Dead Gorgeous Sunspot Yellow MG TF
Pendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud of
Send a message via MSN to Pendle Lass
what a brill idea.... well done
__________________
Provisional dates 01 July - 03 July 2011 Goodwood Festival of Speed
Little Mermaid @ Muppets And Numpties It Alternative Club
Pendle Lass is offline   Reply With Quote
Old 19-06-2009, 14:11   #16
MGFmad
The futures orange
MGFmad's Avatar
Car: MGF VVC 75th ANNIVERSARY & TF LE500
MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.
Send a message via MSN to MGFmad
Excellent work - another project for the 'to do' list
__________________
TF LE500 No 27 of 500 & 75th Anniversary No 452 of 2000
MGF & TF Facebook Group
MGFmad is offline   Reply With Quote
Old 19-06-2009, 20:53   #17
philmgf
On a mission
philmgf's Avatar
assembly pics
I mounted the board into the box using double sided number plate tape as it has foam to absorb vibration.
I then drilled a hole big enough to take the buzzer and siliconed it in but you could use just strong gaffer tape across the back of the buzzer.
I then drilled a smaller hole in the side and inserted a grommet to take the supply, earth and float sensor wires.
The file attatched is a quick video of the unit working before assembly into the car. Im not sure wether to extend the wires and mount it in the car itself behind the drivers seat somewhere or mout it near the coolant tank. The buzzzer is fairly loud so should be able to hear it from the engine bay.
http://s684.photobucket.com/albums/v...coolantvid.flv
Old 19-06-2009, 20:55   #18
philmgf
On a mission
philmgf's Avatar
video link
here's the link.
Old 10-01-2010, 11:20   #19
S!NGH
Car: 45 1.4 IL
S!NGH will become famous soon enough
Hi Phil,
Is it OK to buy this item from ebay, rather than spending £9 at maplins?
S!NGH is offline   Reply With Quote
Old 10-01-2010, 13:54   #20
msunduzi
Car: MGF & Onyx Firecat
msunduzi is just really nice. Awwmsunduzi is just really nice. Awwmsunduzi is just really nice. Awwmsunduzi is just really nice. Aww
Originally Posted by S!NGH View Post
Hi Phil,
I'm not Phil, but I would say no.
The operating temperature is too low
msunduzi is offline   Reply With Quote
Tags
f/tf how to
You may not post replies
low coolant level warning system marczmg MG ZS / Rover 45 & 400 15 16-06-2009 08:45
coolant level riano MGF and MGTF (Sponsored by MG Rover Parts Ltd) 2 29-04-2009 12:08
coolant level j55hgv MG ZT / Rover 75 2 08-02-2008 20:26
coolant level warning light garythesnail MG ZS / Rover 45 & 400 6 09-01-2007 20:18
Coolant level Milton70 MG ZT / Rover 75 4 03-02-2005 08:42
Terms and conditions of use
