Removing Rover 25 factory fitted CD player - MG-Rover.org Forums
Old 27-06-2009, 14:12   #1
bmediauk
Car: Rover 25 Impression s 3dr
I have managed to get my original factory fitted CD player out of it's fittings but just wondered if anyone knew how to release the big square plug from the back of the unit? A diagram on the unit shows to pull up the plastic clip which I obviously did. There seems to be no other way of freeing this plug from the unit itself. It is a case of brute force to pull it off?
Also, I stupidly pulled on the front of the CD player and the plug ribbon that connects the front panel to the circuit board came loose. Is there a quicker way of getting this slotted back in or do I have to dismantle the whole unit to get easier access to the circuit board?
The other option I suppose is to just fit a new CD player. Am I right in thinking all car stereos have the same connectors/plugs on the back and it should be a simple process of plug in and play?
Thanks in advance
bmediauk is offline   Reply With Quote Quick reply to this message
Old 27-06-2009, 14:13   #2
BLMC
Car: -
What type of connection or what year is the car.
BLMC is offline   Reply With Quote Quick reply to this message
Old 27-06-2009, 14:14   #3
soooperspeed
Car: rover R200 wid loadza sweet modz....
there is a small plastic pin at the top of the connector if it has snapped thenuse a small flat head in the groove to press it down and it will slide out
or this
soooperspeed is offline   Reply With Quote Quick reply to this message
Old 27-06-2009, 14:16   #4
BLMC
Car: -
I'm guessing he has the BMW wiring not ISO.
Old 27-06-2009, 14:17   #5
bmediauk
It's an 02 plate
Old 27-06-2009, 14:18   #6
soooperspeed
ok so its like this then
Old 27-06-2009, 14:18   #7
bmediauk
Yeah, that is similar to the connector I have on my unit. Thanks for the advice on the small plastic pin.I'll try that
Old 27-06-2009, 14:18   #8
BLMC
Car: -
It's probably bmw.
Just lift the plastic clip as you stated and then pull.
Old 27-06-2009, 14:19   #9
bmediauk
Yep, that's the one :-)
Old 27-06-2009, 14:19   #10
soooperspeed
and this sorta player
images courtesy of 220deano
http://forums.mg-rover.org/showthread.php?t=273472
Old 27-06-2009, 14:21   #11
soooperspeed
ok see the bottom there is a small clips and just put a flat head there and wiggle it
tell me if you are taking it out
is this on the end of the wires or is it adapted from the iso system wires
cos if it is just take the iso one loose that is all you need
Old 27-06-2009, 14:22   #12
bmediauk
That's the exact one :-) I just need to try and get that ribbon type plug back into the front now which looks like a bit of a mission. (when I say ribbon type I mean it is similar to the types of plugs your get inside a computer that connects the battery to the hard drive)
Old 27-06-2009, 14:24   #13
soooperspeed
so you have damaged the front of the cd player taking it out isi
photos
Old 27-06-2009, 14:24   #14
bmediauk
Thanks for the advice. I'll try that now
Old 27-06-2009, 14:25   #15
bmediauk
I'll post some photo's in sec
Old 27-06-2009, 14:36   #16
bmediauk
http://img190.imageshack.us/img190/6796/27062009611.jpg
This is the connector that has come loose
http://img29.imageshack.us/img29/4667/27062009612.jpg
Back of the unit
Old 27-06-2009, 14:41   #17
soooperspeed
lol you need to click the rezise box when useing imageshack set it to 640 by 480
like this
and that is the ribbon cable going to the circuit board you are going to have to remove the top ov the stereo and reslide it into the plug (black or brown looks like a minature card port
Old 27-06-2009, 14:44   #18
bmediauk
like this
[img]http://img10.imageshack.us/img10/6796/27062009611.jpg
Oh what fun! :-) I'll try and get the plug off the back first to release the unit freely and then work at getting the lid off the thing. Thanks for you help
Old 27-06-2009, 14:46   #19
soooperspeed
its k
Rover 25 Factory fitted CD player help bmediauk MG ZR / Rover 25, 200 & Streetwise 2 02-06-2009 15:06
Removing the Stock Rover 45 CD Player munk3h MG ZS / Rover 45 & 400 5 02-05-2008 12:44
6 CD player/magazine - what make is fitted to the Rover 75 ? steve46 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 31-05-2005 15:43
Rover 75 - Removing the factory-fit CD changer from my glove box!! bigwils In-Car Audio, Entertainment, Sat Nav etc... 2 12-05-2005 01:36
Removing Rover 45 CD Player Rover45Guy In-Car Audio, Entertainment, Sat Nav etc... 6 11-01-2004 15:26
