Heater Fan speed switch - MG-Rover.org Forums
Old 02-07-2009, 12:29   #1
Brum200
Hi, I've searched on the forum briefly for this answer, came to no avail.
On my Rover 200 bubble, My heater fan speeds doesnt work at all, (The knob with 1234 on it) I've changed the switch itself from an known working one on another rover and have tested working on that car.
Fitted said switch from working car to mine and it still doesnt work at all??Can anyone shed any light on this?
It currently has suspected HGF but I would like to get the heater fan working before changing the HG after a garage "bodged" an HG fix on it.
Any help would be apprecitated.
Andy
Brum200 is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 12:31   #2
HotTubRepairer
Car: Astravan 165
Send a message via MSN to HotTubRepairer
I'd be more concerned about fixing the HG myself. Anyway, do all of the speeds not work? Did you check the fuse?
HotTubRepairer is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 12:41   #3
MyMgCar.com
Car: R2h1zZle Vvf0sh1Zzle!!
Send a message via MSN to MyMgCar.com Send a message via Skype™ to MyMgCar.com
When you say swapped the "switch" is this just the knob on top that you use to turn the dial? Does the dials turn to position 1,2,3,4 and do you get any air at any speeds?
If you dont get air at speeds 1 and 2 its most likely your heater resistor pack is gone. If you dont get hot air on 4, then get the garage to clean out the pipes and check the "bodged" HG job they did.
MyMgCar.com is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 21:54   #4
Brum200
Do they stop working when the HG goes? Everythings been checked, fuses n fan switches, none of the speeds work at all.
Old 02-07-2009, 21:56   #5
Brum200
I dont get any air at any speeds the switch clicks freeley.
Wont go to the garage as bunch of knobs, try argue n they resort to threatening.
Old 02-07-2009, 22:40   #6
Olly650
Car: 420 TD Exec
Have you checked the heater resistor pack, under the glovebox?
Olly650 is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 22:48   #7
HotTubRepairer
Car: Astravan 165
Surely that would be rare for the resistors to stop the fan working on all speeds at the same time?
Old 02-07-2009, 22:56   #8
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
If the resistor pack fails completely the fan will always still operate on position 4 - full speed.
Does the cigarette lighter work? It shares the same relay and fuse as the fan for it's 12 volt supply.
Check Fuse 7 (20 amp) in the engine bay fusebox, Fuse 18 (10 amp) in the drivers fusebox, this provides power for the relay or the relay itself which is located behind the glovebox and is a sod to get to!
The fan motor can fail but it is rarely the fault.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - discount for .org Supporters - PM for details.
technozen is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 12:41   #9
larryMG
Car: MG ZR
Send a message via MSN to larryMG
I've got the same kind of problem. My heater dosn't work on 1&2 3 & 4 work though. Also the heater rod has like sezied up and wont change from heat to cold
help
cheers
larryMG is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 13:34   #10
Popeye 89
Car: MG ZR160
Send a message via MSN to Popeye 89
hmm thats kinda strange. rather than start a new thread i thought id use this one as i have no fan on speeds 1 and 2, just 3 and 4. cigarette lighter still works though
Popeye 89 is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 13:40   #11
minesarover
Location: Mid Glamorgan.........@@@@@@@ SYKES PICKAVANT ACR4 IMAP & IKEYS @@@@@@@
Car: Rover 420 sdi ,Mitsubishi Shogun 2.8 LWB,BMW Z3, Ford Transit, MG ZSTD
Your problem is the heater resistor pack behind the glove box top of fan housing 2 screws.
minesarover is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 13:44   #12
Popeye 89
Car: MG ZR160
does this have to be replaced or can it be repaired?
Old 21-08-2009, 14:00   #13
larryMG
Car: MG ZR
I'll have look is it easy to find? And how much would a new one cost?
Old 21-08-2009, 14:49   #14
rikernumber1
Car: Rover 211 1.1 8v SE
Folks on here sometimes supply them, or try eBay. Around the 5 mark is reasonable - you may get them cheaper.
rikernumber1 is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 14:55   #15
Popeye 89
Car: MG ZR160
when you take out the glovebox its right in front of you with a 4 pin plug and 2 x 6mm bolts
Old 21-08-2009, 15:00   #16
Richy
Car: RZ5
Mr. Technozen sells them.
Richy is offline   Reply With Quote Quick reply to this message
Old 21-08-2009, 15:08   #17
larryMG
Car: MG ZR
Cheers i'll check it out tonight n get one from him if thats what it is.
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Heater fan switch cherokee MG ZR / Rover 25, 200 & Streetwise 2 16-01-2009 19:29
Heater Fan Switch Robert.Nicholls MG ZS / Rover 45 & 400 3 21-05-2007 16:51
Heater Fan Switch The Gas Man MG ZR / Rover 25, 200 & Streetwise 1 28-02-2007 21:45
Rover 200 heater fan, Not resistor or switch. Help! gadget32 Others 8 14-01-2006 12:32
Mk2 416 Heater fan switch! hughjohnson MG ZS / Rover 45 & 400 7 19-12-2002 18:08
