#1 |
Car: Rover 75
Rover 75 - CDTi Starter Motor Bolts
Hello,
I am trying to remove the starter motor from my 2003 Rover 75, 2.0 CDTi Auto to replace the contacts in the solenoid. However, in spite of much trying and knuckle scraping, I cannot locate one of the bolts! I can see and remove the nut & bolt which is the radiator side of the starter, I have found photo's on-line for my Denso starter motor and it does show another bolt hole opposite this one. I have tried every way I can to feel for this other bolt (from the starter motor side) and I just cannot find it (I know it must be there as the starter will not budge with just the one nut & bolt removed. Has anyone who has removed one of these got any tips? Do you know if the bolt is from the starter motor side or should I be looking around the bell housing side (there is a bolt in the bell housing but it looks a bit too far around to be in the starter)? Is there something else I need to remove first to gain access (other than the engine cover and air supply pipe)? Any help would be greatly appreciated as the tell tale clicks are becoming more frequent and I know I am on borrowed time! I have searched this forum and cannot find reference to anyone else having the same removal issue. First post, so thanks in anticipation. Mark |
| Sponsored Links | |||
Advertisement | |||
#2 |
There are two fixings the top one is the bolt that the earth strap is fastenened to on the bell housing and screws into the starter motor. The second one is futher down and is a nut and bolt probably the one you have already removed.
#3 | |
Trust me.
Location: France Car: R 75 Diesel. Plus Honda CB 1,000 R. motorbike. 130 bhp engine
#4 |
Car: Rover 75
RoverRattles, may thanks for the reply. I will have another look at the bell housing side. I did remove one bolt which looked like it was probably about an inch too far round the housing for the starter - and it was as the starter still would not budge.
I think the key is the elusive earth cable - this is also not immediately obvious on this car. The earth on this one runs from the battery to the body and stops. Obviously it will have one that runs to the engine, but it does not appear to be near the starter. Have had Rover's for many years so know there bizarre ways. Will look at the car on Wednesday and try again. Colvert, thanks for your informed assumption. I did not read in the Forum Rules that you had to log-on in order to gain answers to your posts. As this forum is viewable without loggin on, I simply bookmarked the question and have checked it everyday - several times a day when I first posted it! |
#5 | |
Trust me.
And I wish you luck with solving your problem . ![]()
#6 |
It sounds like you have been trying to remove the correct bolt, it does look to be too far
round for the starter motor. You will need to remove it completely as the motor would not move if you had only loosened the bolt. Hope this helps unless anyone else can offer a suggestion. My car is a manual so it may be slightly different. |
#7 |
Car: Rover 75
RoverRattles, many thanks for the reply. I will take the bolt out completely (I did loosen it quite a bit but the starter did not give the usual "shake loose" you would expect) so I will totally remove it, from your comments I now know that the bolt is the bell housing side and the starter had a thread into which the bolt goes. This alone is a major step forward.
Will try again on Wednesday and let you know. Regards Mark |
#8 |
Car: Rover 75
RoverRattles, well done, I found the elusive bolt! Starter removed, solenoid overhauled and all fitted back within an hour. Many thanks for your help, you have saved me from having to suffer the humiliation of not being able to remove such a simple item! Much appreciated.
All the best. Mark |
#9 |
Car: Rover 75
If anyone is having the same problem as me with this bolt, here are a few notes which may be of help.
On the Rover 75 Diesel Auto, there is one nut (15mm) & bolt (13mm) located on the Radiator side of the starter motor. Once you have removed the engine accoustic cover, the air ducting, disconnected the battery and the cables from the starter, this nut & bolt is easily removed. As RoverRattles stated, the second bolt goes into a threaded hole in the starter motor, the bolt head (13mm) is located on the bell housing side. Looking from above the engine, between the inlet manifold and the battery box, you will clearly see a 15mm bell housing bolt head, it looks a little bit too far around to be fitted to the starter motor and it is! The bolt you need is approx 2-2.5 inches from this one, on my car it was located underneath a metal water pipe (if you were looking from the passenger side of the engine bay, the easily visible 15mm bell housing bolt head is approx just before 12 o'clock, the starter bolt is at approx just before 11 o'clock). To remove the bolt I needed a 13mm socket on a 9" extension bar, I also unhooked the water pipe (the one with the vent valve) from their clips around the battery box, this allowed me to reach the extension bar with a torque wrench and get enough movement to undo the bolt. I removed this bolt from the starter, but did not withdraw it from the bell housing so it made refitting easier. Note, this bolt has approx 25mm of thread beyond the bell housing, so it does take a good few turns to fully disengage from the starter. I refitted the starter using the nut & bolt finger tight, I could then just turn the extension bar I had left in situ to locate and tighten the 13mm bolt. Sorry this is very wordy, I took a couple of photos and followed the instructions in the FAQ, but it appears I do not have the options to upload them. |
#10 |
Welcome Mister B and thanks for sharing with us your experience....sorry for the 11 days
John |
#11 |
Glad to be of help. Thanks to the forum I saved some money with a solenoid repair kit.
I was about to buy a reconditioned starter motor until I did a quick search on here for starter motor problems. |
#12 |
Car: MG ZT
Thanks all for this thread . . . i spent about 30 mins trying to find the hidden 2nd bolt and this directed me to it. I also used the repair kit and all is fine. The hidden top bolt with engine earth strap gave me severe problems when i first bought the car. I had occasional severe gear changes (auto box) which turned out to be a loose earth on this bolt!! Mr RAC fixed that one for me so i hadnt seen it at the time!
| Bookmarks |
| Thread Tools | |
| Rover 75 - Starter Motor? | medhead42 | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 10 | 05-08-2009 09:20 |
| Rover 75 starter motor | robwal0 | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 17 | 13-09-2008 12:56 |
| Rover 75 starter motor | dsouzac | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 3 | 26-10-2005 20:37 |
| Rover 75 Starter Motor | webprojectuk | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 9 | 28-09-2005 19:36 |
| Rover 75 Starter motor problem? | zappa | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 0 | 05-05-2005 08:31 |
