Rover 25 diesel died!! - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 27-07-2009, 08:50   #1
alan.4d
Car: Rover 25
Unhappy Rover 25 diesel died!!
Hi, all
I still looking for a bit of help!! My Rover 25 cut out on a roundabout 3 weeks ago. I got a tow home and had a look with a mate. As it seemed fuel related we took off line to the fuel injector and saw that when the engine cranked over, a miserable amount of fuel came out. With all re assembled the engine will not even cough or splutter. No firing at all. Suspecting the fuel pump, I got hold of a scrapper and fitted the 'new' pump. Same problem. Absolutely no firing at all. However fuel now spurts from the injector lines. Checked and rechecked timing on pump belt.
Any help appreciated or should I just sell the car of for bits????
Alan
alan.4d is offline   Reply With Quote Quick reply to this message
Old 27-07-2009, 12:18   #2
ramdonice
Car: rover 75 club cdt
Send a message via MSN to ramdonice Send a message via Skype™ to ramdonice
the pump turns twice for every one turn of the engine, try turning the pump pulley round 360 and time up again.
ramdonice is offline   Reply With Quote Quick reply to this message
Old 27-07-2009, 16:43   #3
alan.4d
Car: Rover 25
Ok. Tried that to no avail. However if I squirt some easy start in the air intake it fires up straight away. Could it be that the stop solenoid is not activating? Is there any way of checking this?
Old 27-07-2009, 16:53   #4
Dakta
Diesel Tuning Dude
Dakta's Avatar
Car: 75 Tourer Conn SE & 45 TDi VNT
Send a message via MSN to Dakta
Unless i'm having another stupid moment (I doubt it) the vp30 doesn't have a stop solenoid - doesn't need one - just doesn't actuate the fuel quantity solenoid when it wants to shut down.
It could however be that solenoid, or the timing solenoid. Probably time to be considering a pump replace/repair.
Gosh these pumps are dying every two minutes now!
(possibly scrapped because of pump?)
Any ecu problems? bad earths?
__________________
Dakta is offline   Reply With Quote Quick reply to this message
Old 27-07-2009, 16:58   #5
alan.4d
Car: Rover 25
I tried swapping the pump from a breaker up in Glasgow who assured me that the pump came off a runner. (I know it is not conclusive.) The Haynes manual talks about a stop solenoid, I think, built into the pump. Could it be that the ECU has thrown a wobbly and not delivering fuel? There is no management light on in the dash though.
Old 27-07-2009, 17:01   #6
Dakta
Diesel Tuning Dude
Dakta's Avatar
Could be.
Any chance at all, no disrespect, but any chance at all that you've botched up the pulley position against the shaft timing, so the timing mark on the pulley no longer corresponds to the right timing?
Injection Timing - It's your last real chance before things get nasty imo.
__________________
Old 27-07-2009, 17:08   #7
alan.4d
Car: Rover 25
Ok. Engine locked on flywheel at t.d.c. and corresponds to timing mark on camshaft pulley and plastic line on timing belt casing. (Also convenient white paint someone has put at top of casing and on pulley). All line up.
Otherside of engine, pump locked and belt tensioned.
I presume that I'm not missing anything silly!!
The only slight doubt is that the breakers yard actually took the timing plate off the pump. Is that a possibility?
Old 27-07-2009, 17:09   #8
Dakta
Diesel Tuning Dude
Dakta's Avatar
no, unless the pump shaft (the shaft itself) has slipped against the pulley...
__________________
Old 27-07-2009, 18:02   #9
alan.4d
Car: Rover 25
My bet is that the ecu is malfunctioning. ANYONE OUT THERE WANT A DEAD ROVER 25 THAT'S DOING MY HEAD IN?
Old 27-07-2009, 18:16   #10
Dave
Car: MGZSTD - 150+bhp
Send a message via MSN to Dave Send a message via Skype™ to Dave
Where are you?
Dave
Dave is offline   Reply With Quote Quick reply to this message
Old 27-07-2009, 19:09   #11
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Pump I expect. Bloody things.
Dr Dave is offline   Reply With Quote Quick reply to this message
Old 27-07-2009, 21:20   #12
alan.4d
Car: Rover 25
Dave, I'm at Ross on Wye (in between Hereford and Gloucester)
Old 28-07-2009, 07:02   #13
Dakta
Diesel Tuning Dude
Dakta's Avatar
Bring it to me and I'l take care of it.
(No I don't expect you to take that seriously. Would be nice though )
__________________
Rover 25 fuel pump problemsmy 2001 2litre diesel 25 started to act up, kept stalling ajamesiel Diesel Forum! 8 29-05-2009 17:03
Rover 25 2.0 Diesel robskytoon MG ZR / Rover 25, 200 & Streetwise 3 20-04-2008 12:38
Diesel 75 Died on M1 Pollyp40 Diesel Forum! 8 08-07-2006 03:03
Diesel died biker bloke Others 2 03-08-2005 00:45
arrrghhh my 25 derv died on the A1 tonight HELP!!!! jonplace MG ZR / Rover 25, 200 & Streetwise 42 19-03-2005 10:38
