Old 06-09-2009, 17:25   #1
CJJ
Mudslinger extraordinaire
CJJ's Avatar
Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1CJJ has reached their true position at number 1
Heater cable adjustment.
I have been suffering for a while with a heater system that will never fully shut off, so even though the knob was turned fully into the blue I was still getting warm air. This wasn't good on a warm rainy day with the hood up.
So I decided to have a fiddle a couple of days ago and see if I could adjust the cables.
This will work for either the hot/cold or the directional knob (winscreen/feet etc) as they are bothe cable operated.
First of all you need to take the footwell light panel off.
Drivers side for the temp and passenger side for the direction/vents.
First remove the 2 crosshead screws holding the panel in place.
And pull the panel forwards and down.
And disconnect the 2 spade connectors to the lamp holder. Remember which way around they were connected.
The heater control cable is the red cable shown here and the clip you need to play with is circled in yellow.
The first thing I noticed was that a loom was very close to the moving parts of the valve.
So I tucked the cable out of the way to prevent damage.
You can see the clip that secures the cable in place. The clip is just a spring clip that bites into the cable outer and holds it in place. You need to push the rounded tab away from you and towards the cable.
This releases the clip and allows you to move the cable up or down.
You need to move the cable up if you want more hot (A) or down if you want cooler (B).
I needed to move mine down.
Once adjusted you need to feed the rounded tab back through the bracket and push it until it clicks into place and bites into the cable.
The valve should now close more in my case when the knob is turned to blue. If the knob won't turn to the full cold position then you have adjusted too much
and you shoud readjust the cable until it is right.
So, know I have cool air once again. Err....Cool.
Remember not to place too much stress on the valve as it could easily be damaged. It is also possible that the symptoms are of a damaged valve and if this adjustment doen't work then you might have to change the valve.
The cable that controls the vent selection is on the passenger side and is coloured grey. The clip is similar.
__________________
CJJ is online now   Reply With Quote
Old 06-09-2009, 17:27   #2
Pendle Lass
Got her Mojo back!!
Pendle Lass's Avatar
Car: A Drop Dead Gorgeous Sunspot Yellow MG TF
Pendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud ofPendle Lass has much to be proud of
Send a message via MSN to Pendle Lass
think this is the same as my problem Clive....... I never get any cold air at all.....
__________________
Provisional dates 01 July - 03 July 2011 Goodwood Festival of Speed
Little Mermaid @ Muppets And Numpties It Alternative Club
Pendle Lass is offline   Reply With Quote
Old 06-09-2009, 17:38   #3
WindDrifter
IT Slave
WindDrifter's Avatar
Car: MG TF160, Daytona 955 x2
WindDrifter is just really nice. AwwWindDrifter is just really nice. AwwWindDrifter is just really nice. AwwWindDrifter is just really nice. AwwWindDrifter is just really nice. Aww
Thanks CJJ! Just what I need. Never get any air on the windscreen.
Very funny when it's raining and roof is up and windows closed....
steam everywhere!
__________________
http://forums.mg-rover.org/album.php?albumid=144
http://t955i.net
WindDrifter is online now   Reply With Quote
Old 06-09-2009, 17:50   #4
CJJ
CJJ's Avatar
It is possible that the valve or the heater matrix is at fault, but it is always worth starting with the cheap or free fixes first.
__________________
Old 06-09-2009, 17:51   #5
CJJ
CJJ's Avatar
Try doing the same as I have done, it might solve it. I had to drive with the window down in the rain because it was too warm.
__________________
Old 06-09-2009, 19:41   #6
spaceoctagon
Car: MGTF 160
spaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud ofspaceoctagon has much to be proud of
Talking warm
You wont be getting too warm this winter now you've fixed it!
spaceoctagon is online now   Reply With Quote
Old 06-09-2009, 20:50   #7
Aiketgate
is back - in black
Aiketgate's Avatar
Car: MGF mk2 Freestyle 1.8mpi 16" wheels
Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.Aiketgate has a reputation beyond repute. Respect.
Another useful 'how to'.
When the cable is disconnected - is it worth manipulating the valve lever to check the valve operation?
David
__________________
NORTH LAKES RUN September 11th
Aiketgate is offline   Reply With Quote
Old 06-09-2009, 20:53   #8
CJJ
CJJ's Avatar
David
If you can, never really tried. I would have done if the cable adjustment hadn't worked.
__________________
Old 06-09-2009, 20:55   #9
Reaper
MG!
Reaper's Avatar
Car: MG ZT+ 135
Reaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud ofReaper has much to be proud of
Great post CJJ.
A little off topic; I think i may need to take those pannels off as my HU has millions of cables and the last thing i want is them getting jammed, but you can never get to them as the HU is in the way.... so side ways is next....
__________________
Reaper is offline   Reply With Quote
Old 06-09-2009, 21:07   #10
Teri
Car: MGF 1.8mpi 1998
Teri has a spectacular aura aboutTeri has a spectacular aura about
Thanks for that CJJ... Mine seems to have the same problem too.... All hot air and no cold at all..
Will have a little fiddle with mine during the week..
Great step by step
Teri is offline   Reply With Quote
Old 07-09-2009, 14:27   #11
CJJ
CJJ's Avatar
Let me know if this solves anyone elses heating woes.
__________________
Old 07-09-2009, 15:27   #12
a_wh
a_wh's Avatar
Car: MKI MGF 1.8 Mpi
a_wh is starting to get known about herea_wh is starting to get known about herea_wh is starting to get known about here
I had to do a similar thing to you CJJ, while you are doing it its also a good opportunity to straighten out your alarm/immobiliser receiver (it’s the yellow cable that doesn’t seem go anywhere) it usually gets curled up but if you straighten it out and tape it down it should give you a longer range on your key fob.
a_wh is offline   Reply With Quote
Old 07-09-2009, 16:11   #13
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
Originally Posted by a_wh View Post
.....while you are doing it its also a good opportunity to straighten out your alarm/immobiliser receiver (it’s the yellow cable that doesn’t seem go anywhere).......
only on the F, on the TF it seems to be invisible !!
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 16-09-2009, 17:31   #14
Teri
Well got round do doing this today and it doesnt seem to have made any difference.. Still blowing hot air, so I guess it must be something to do with the valve?
Without sounding too stupid, what do I try next?
Old 16-09-2009, 17:50   #15
CJJ
CJJ's Avatar
A new valve probably. You can try moving the valve by hand if you can get to it, but it sounds like it might be jamming slightly open. The bad news is you have to drain the coolent to do it.
__________________
Old 17-09-2009, 15:02   #16
Teri
Pahh thats what I didnt want to hear lol.. Oh well winter is coming I suppose, so better to have warm air than cold eh?.....
Old 17-09-2009, 18:21   #17
The Blue Vroom
Car: MGF
The Blue Vroom will become famous soon enough
Been meaning to post a question about this for a while. I get cold air when the dial is at cold, but if I move it one notch it goes straight to hot-will this work for my problem do you think cjj? Need to try it on the air direction dial too, don't seem to get any air to the windscreen...
The Blue Vroom is offline   Reply With Quote
You may not post replies
Accelerator cable Adjustment winker 'R8' Rovers (aka Wedges!!) 3 28-06-2007 12:09
Throttle cable adjustment Teflon MG ZT / Rover 75 9 20-10-2006 19:21
ZRTD Clutch cable adjustment. coolrooster MG ZR / Rover 25, 200 & Streetwise 0 06-06-2006 15:38
Metro Clutch Cable Adjustment The Pig Metro / Rover 100 10 03-05-2005 23:16
Throttle Cable adjustment Schtopper MG ZS / Rover 45 & 400 14 19-02-2004 19:34
Terms and conditions of use
