Old 07-09-2009, 14:44   #1
sniperpenguin
sniperpenguin's Avatar
Car: TF 135 Sprint
sniperpenguin is a splendid one to beholdsniperpenguin is a splendid one to beholdsniperpenguin is a splendid one to beholdsniperpenguin is a splendid one to beholdsniperpenguin is a splendid one to beholdsniperpenguin is a splendid one to behold
Send a message via MSN to sniperpenguin Send a message via Skype™ to sniperpenguin
HOWTO - Replacing your aerial mount :)
Seeing as I recently had my aerial snapped by chav's , I had to perform the task of replacing the Aerial mount. I though it only fair I do a HOWTO, seeing as it save a little bit of grief for somebody.
First, I sourced a replacement unit from "CAR-MASTS-UK" on ebay - about £12 for the entire assembly
*REMOVAL*
The aerial mount has a top piece with flat edges. this will unscrew (lefty-loosey ) using a pair of pliers and come off, leaving you with 3 pieces
1. unscrewed top piece
2. Black plastic mount (visible on car)
3. Aerial internals
Below is a pic of the old component removed
To remove the interals, you will need to disconnect the coaxial cable, shown here (dont forget to reconnect when done! )
*REPLACEMENT*
Disassemble the new piece in the same way, and clean off any muck / grease around the bodywork. Take the replace ment mount (middle piece) and line up the notches before pressing it in firmly. It looked a little out of alignment to me, but it isnt.
The easiest way I found to re-insert the aerial mount is to hold the bodywork with your right-hand, having the mount between your 3rd / 4th fingers (I've removed the mount to make the pic clearer). Once roughly lined up, manually screw on the top piece (hand-tight is fine).
Once done, reconnect the cable and you are finshed with the replacememt. And all that remains is to fit an Anti-Chav Richmeond aerial supplied by a sympathetic wife!
__________________
Everything above is my own opinion...... and should therefore be taken as fact
sniperpenguin is offline   Reply With Quote
Old 07-09-2009, 19:21   #2
mogatrons
Bohemia..the place to be!
mogatrons's Avatar
Car: MINI Cooper convertable
mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1mogatrons has reached their true position at number 1
Thanks for that Sniper!
Jeff.
__________________
mogatrons is offline   Reply With Quote
Old 07-09-2009, 19:56   #3
MoonManMike
Now with added Blue Flame
MoonManMike's Avatar
Car: MG TF 135 Sprint, Rover 25
MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.MoonManMike has a reputation beyond repute. Respect.
I wonder if anyone makes a stainless steel/chrome base mount for the aerial?
I've not found one yet!
__________________
MoonManMike is offline   Reply With Quote
Old 07-09-2009, 20:20   #4
sniperpenguin
Car: TF 135 Sprint
MGF Centre will turn up with one shortly after a few trips to the scrappy....
Cost? = £80 probably
__________________
Old 07-09-2009, 22:40   #5
MG_CHIC
Banned
Car: MGF
MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.MG_CHIC has a reputation beyond repute. Respect.
Send a message via MSN to MG_CHIC
Excellent guide SP!
Quite clever to have an anti-theft one - do you mind me asking how it works?
MG_CHIC is offline   Reply With Quote
Old 07-09-2009, 22:42   #6
adamelphick
Meg is a nightfire babe!
adamelphick's Avatar
Car: 1998 MGF 1.8i Nightfire with TF Front & 1996 Amaranth F called Fleur!
adamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud ofadamelphick has much to be proud of
Send a message via MSN to adamelphick
Originally Posted by MG_CHIC View Post
Excellent guide SP!
Small grub screw methinks! My local Halfords have them in the sale bins for a tenner I think at the moment for some reason!
adamelphick is offline   Reply With Quote
Old 07-09-2009, 22:52   #7
MG_CHIC
Banned
Car: MGF
Dammit I just bought a new aerial but I'm quite tempted to get one of these tbh. Gotta pop to Halfords tomorrow so will check for them... thanks for the tip hun!
Old 08-09-2009, 11:20   #8
AussieTF160
Car: Toyota Camry Sportivo V6
AussieTF160 is up and running. Hey we all have to start somewhere.
Thanks for the How-To - always wondered how it came apart!
(now go and clean your boot channels!)
AussieTF160 is offline   Reply With Quote
Old 08-09-2009, 12:31   #9
Tytalus
Here, Fatey Fatey Fatey..
Tytalus's Avatar
Car: MGF VVC & Prius T4
Tytalus is a glorious beacon of lightTytalus is a glorious beacon of lightTytalus is a glorious beacon of lightTytalus is a glorious beacon of lightTytalus is a glorious beacon of lightTytalus is a glorious beacon of light
Could have done with this a year ago when I dealt with all the rust around the aerial; took me a while to figure it out!
All you've got to do now is find the 'macro' focus on your camera
__________________
North Essex Rag Tops - www.nert.org.uk
To quote Inspector Gently: "You can keep the MG, we wouldn't want you driving something sensible..."
Tytalus is offline   Reply With Quote
Old 08-09-2009, 13:01   #10
Scarlet Fever
Scarlet Fever's Avatar
Car: MGF
Scarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant futureScarlet Fever has a brilliant future
Good how to - will give some rep.
...always thought about fitting an electric aerial, wonder if anyone has done it...
__________________
Andrew Phillips
MGF Register Committee - Archivist & Registrar
MGF 'Scarlet Fever'
MG ZT260 'old #27'
Scarlet Fever is offline   Reply With Quote
You may not post replies
ac howto sourfacedsod MG ZS / Rover 45 & 400 5 24-06-2009 13:22
Replacing the aerial mattk Rover 600 2 19-04-2009 11:21
Aerial mount seabass MGF and MGTF (Sponsored by MG Rover Parts Ltd) 8 23-06-2008 18:08
Rear Screen Replacement HOWTO iaross MGF and MGTF (Sponsored by MG Rover Parts Ltd) 9 14-09-2007 11:17
Replacing Aerial on MGF? Flyte MGF and MGTF (Sponsored by MG Rover Parts Ltd) 13 20-06-2006 15:36
Terms and conditions of use
