MG ZT 160 1.8t Engine cooling fan,mayo in engine, HGF? - MG-Rover.org Forums
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 24-09-2009, 18:54   #1
nasxtra
Car: MG ZT
Hello Evryone, I purchased MG ZT 160+ cos it looked good, then did a little research and stumbled on this forum, was always reading about HGF failure but with the info and advice on this forum took preventative measures, always checked coolant / oil, waited for ambient temp before giving it some all good until................
Rubber pipe that attaches to T pipe started leaking, think i caught it in time kept it topped up and replaced tube, then the right hand side of T pipe burst did same again..got the car serviced and then noticed radiator was letting off steam..noticed too that radiator wasn't working have kept the coolant level up and only driven about 16miles since was looking oil cap and shock! the dreaded Mayo!! only a little but its there...am now at total loss what to do..I live in Bradford and don't know of any MG specialists apart from breakers off wakefield road.
1) Do i have HGF? if so is it repairable? do i need new headgasket? how much will it cost and from where?
2) can i fix the cooling system fault? why isn't the fan working? will know by tomoz as am getting it checked via auto electric dudes.
3) Anyone know any HONEST, reliable and reasonable MG specialists who can work on the car in the Bradford area? Having recently lost my job cost is of an issue for me...Can anyone advise..Please help!!
nasxtra is offline   Reply With Quote
Old 24-09-2009, 19:18   #2
T-Cut
I think you could be worrying prematurely. A small amount of emulsion under the filler cap may mean very little, other than the engine's not had much use. If you have not had a temperature escallation into the red on the gauge, it's unlikely any damage has been done. The next thing to do is replace the pressure cap on the coolant header tank. It will eliminate that as a source of loss. Available from Rimmer or any Xpart depot.
As to the fan not working, it may or may not be OK. The fan doesn't run all the time, only when needed. What year is the registration? That will help with the advice.
Does the fan run continuously when the aircon is set to 'Auto' with the engine running. It should. If not the fan is probably faulty. Check that and come back.
TC
T-Cut is offline   Reply With Quote
Old 24-09-2009, 19:33   #3
nasxtra
Car: MG ZT
Hi Thanks T-Cut, I have been driving around town with heaters on full blast and windows down to various garages (even got pulled by the cops as i was looking at temp gauge and went thru amber/red lights!) and during this time the fan never came on i took itto a back street garage as i was panicking he popped the bonnet and let engine idle approx 10 mins still no fan on just steam coming from radiator area..he told me possible electrical fault..also pointed out it was missing only on 3 sparks? its a 53 plate 1.8t ZT no air con
also noted a little water in left handside exhaust tube ...
Have read about K-seal anyone ever used that stuff??
Old 24-09-2009, 21:02   #4
T-Cut
There's obviously an external/visible coolant leak which you should fix before even considering sealant of any kind. I wouldn't use it anyway. Replace the pressure cap as a start. Look at all the hose connections. It shouldn't be difficult to see where steam is coming from. When the leaks are fixed ensure you use 50% AOT antifreeze mixture in the cooling system.
TC
Old 25-09-2009, 10:34   #5
COLVERT
Trust me.
COLVERT's Avatar
Car: R 75 Diesel. Plus Honda CB 1,000 R. motorbike. 130 bhp engine
After 10 mins tickover the fan should have come on. It does sound as if the fan is one of your problems. Change the plugs as a precaution as it is just as well to start off with new plugs anyway. Find and fix that leak and try the tickover test again. The fan should switch on before your temp gauge rises above the 9 o'clock position. If not you have a duff fan or temp. sensor. Check in search feature above for more info.
__________________
Rep:■■■■■□□□□□
COLVERT is offline   Reply With Quote
Old 25-09-2009, 11:13   #6
SteveChilds
Administrator
SteveChilds's Avatar
Tournaments Won: 1
Car: MG F/TF Hybrid, ZT-T 190SE, ZS 180 in Aurora
Send a message via MSN to SteveChilds
DO NOT use this stuff...
__________________
F/TF Hybrid in Firefrost Red
ZS 180 in Aurora
SteveChilds is offline   Reply With Quote
Old 25-09-2009, 11:41   #7
nasxtra
Car: MG ZT
Question OOhhh no!!!
Well hears the bad news its definatly HGF, started up this morning checked oil dip covered in mayo, oil cap ditto...coolant loosing it like mad..drove to breakers as the grage dude told me it's not worth doing HG change as engine maybe damaged...it started to chug a little and spurted out white smoke (like it was burning oil)
he told me engine was damaged beyond repair...finding prices for 1.8t engine look like a bag of sand (grand) I was quoted! but none in stock then found a rover specialist
I'll probably get it towed to him as not risking any further damage...is thisthe right thing to do..i don't want to drive it because it started to loose power and chug a bit and spit out loads of white smoke from the back have I gone beyond repair??
Old 25-09-2009, 14:28   #8
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
There is no reason to think that it will be beyond repair, but no way of knowing until the head is removed. Do not drive it because the turbo bearings will soon fail if there is water in the oil.
Head gasket job should be sub £500 with new belts etc.
1955diesel is offline   Reply With Quote
Old 01-10-2009, 19:34   #9
nasxtra
Car: MG ZT
Smile
Heard from the rover guy..it needs a HG change, water pump, spark plugs, engine flush cam belt, thermostat hopefully pick it up 2moz...will let you know the final outcome..
Old 27-12-2009, 15:47   #10
nasxtra
Car: MG ZT
Got the car back on the road cost me £550 new belts etc....turbo was ok so didn't need replacing...gave me 12 month guarantee....and will have to go back for an oil change soon..but good job
Old 27-12-2009, 18:26   #11
tazman3
Car: Alfa Romeo 159 2.4 JTDM Lusso - MG TF 115 Xpower Grey
Glad to hear you got the car sorted....just goes to show that one person tells you engine is damaged beyond repair yet another garage sorts it including belts for £550
Pays to shop around
Martin
tazman3 is offline   Reply With Quote
Old 29-12-2009, 18:20   #12
kaiser
Car: 75 v8, tourer 2.5 auto, 1.8T auto, 105S, 105R, p5BCoupe, 3500Auto, Van den Plas, Range Rover
If you have mayonnaise under the oil filler cap on a hot engine, then you have water entering the oil.
If that is the case, it can come from head gasket, a leak past the liner or a crack in the block/liner.
K-seal will definitely help in the last two cases. I have done it with great success.
kaiser is offline   Reply With Quote
Old 30-12-2009, 19:52   #13
Bobert
Bling Bling Blue
Bobert's Avatar
Car: 2004 MG ZT Mk2 160T+ 2000 MGF Mk2 VVC
The T piece took out my head gasket last easter, the plastic ones fitted are crap.I fitted a metal one available from a member on the 75 zt owners club.
Follow this link http://www.the75andztclub.co.uk/foru...t=gerry&page=2 it might help stop a repeat HGF.
__________________
Hear my ZT on you tube[
Bobert is offline   Reply With Quote
You may not post replies
Rover 75 / MG ZT 1.8T engine rwkshaw Wanted 0 27-07-2009 23:12
ZT-T Engine cooling fan not working MGScottie MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 03-06-2009 08:15
MG ZT 1.8T Engine management-head gasket A20C SX MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 02-08-2007 21:18
MG TF 160 - replacement engine, cooling etc gbagnall MGF and MGTF (Sponsored by MGF Mania) 36 29-04-2007 09:26
Rover 75 / MG ZT 1.8T K-Series Engine Tuning GOODSHARE MG/R Modification & Tuning 0 15-07-2004 19:03
