K-Seal anyone? - MG-Rover.org Forums
Old 23-12-2009, 07:55   #1
Chris-K
Car: Rover 75 CDti Conne SE Saloon Silver/Gold 67K
K-Seal anyone?
When i bought my 1.8T (ultra low 25k) the cooling fan used stay on for few seconds after switched off (never did that on my old 1.8T)
Started loosing water
Couple months later cylinder head gasket blew to the tune of 550
It's been OK for few weeks until last night when the dreaded cooling fan came after i pulled in the drive
1/ I need to get some coolant/anti-freeze in quick (haven't got time to shopp around), what do Tesco or Halfords sell that's suitable
2/ I am also putting some K-Seal in (i can't afford another 550) - anyone had any experience with this - best methods?
The good news is when i drove it to work this morning and switched off - no fan blissssssssssssss
Chris-K is offline   Reply With Quote Quick reply to this message
Old 23-12-2009, 08:06   #2
igundwane
Car: Rover 45
Dumped a can of it in my 45 2 weeks ago after doing the head gasket. Seems to be working nicely, as the liners on mine had moved slightly.
Do read the can first which says shake vigoriously for 30sec before dumping it in, rather than the reverse then having to stir vigoriously !
igundwane is offline   Reply With Quote Quick reply to this message
Old 23-12-2009, 08:22   #3
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Although not reccomended, I've used K Seal with great results recently.
As above, shake and add to the expansion tank making sure you don't overfill. Run engine, go for a drive.
Dr Dave is offline   Reply With Quote Quick reply to this message
Old 23-12-2009, 09:51   #4
Chris-K
Great - thanks
any ideas on universal anti-freeze to top it up?
haven't looked yet, but i'm assuming coolant will have dropped
Old 23-12-2009, 09:54   #5
Dr Dave
Administrator
Dr Dave's Avatar
Use only OAT based antifreeze, pink/orange in colour.
Old 25-12-2009, 08:34   #6
twopoke
Car: Rover 75 2.5 v6
i put k seal in my 75 when i put ut back together after replacing the head gasket just to make sure//!
hasnt used drop of water in the 2k miles since
now if i could only get it to run again!!
twopoke is offline   Reply With Quote Quick reply to this message
Old 25-12-2009, 09:50   #7
Bobert
Bling Bling Blue
Bobert's Avatar
Car: 2004 MG ZT Mk2 160T+ 2002 MG TF 160
You might find this an interesting read.
http://www.the75andztclub.co.uk/foru...ad.php?t=36562
Get a brew first it's a long thread.
Bob.
__________________
Hear my ZT on you tube[
Bobert is offline   Reply With Quote Quick reply to this message
Old 25-12-2009, 10:07   #8
kaiser
Car: 75 v8, tourer 2.5 auto, 1.8T auto, 90, 105S, 105R, 110, p5BCoupe, P6B, Van den Plas, Range Rover
As for the antifreeze/anti corrosion inhibitor.
OAT is recommended. Its main claim to fame is longer service life. I have, from practical experience, got to the point, that I realize there is no way that I will get 4 years of uninterupted service from my cooling system, so for me, this feature is not worth paying for.
In stead I use normal antifreeze, which has served millions of people over the years fine, at a fraction of the cost.
I have recently had one engine opened, and it was clean as a whistle inside. Just remember that the service life of this type is about 2 years.
But you can use it with confidence.
As for the addition of k-seal. Go for it. I don't claim it will cure HGF, but it certainly sorted my leaks past the liners out.!
kaiser is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Looking for exterior door trim/seal/strip for MGF ("Outer waist seal"?) ohansen MGF and MGTF (Sponsored by MGFnTFBITZ) 2 02-12-2008 18:58
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 600 10 28-06-2008 14:55
Rover 600 rubber door seal, can I use a Rover 400 rubber seal istead? megmeg Rover 800 0 19-05-2008 09:24
mg zr door seal and sunroof seal irish pa MG ZR / Rover 25, 200 & Streetwise 1 12-01-2008 14:49
