#1 |
Mudslinger extraordinaire
Location: Ashington, Northumberland Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
How to remove your door card.
There are several jobs that need the door card removing.
It might be to fix the door lock, window mechanism, adjust the window stops, changing door speakers etc etc. The first thing to do is remove the 2 cross headed screws at the rear edge of the door panel. Remember to put them somewhere where you won’t lose them. ![]() Now remove the top front screw. ![]() Remove the 2 screws that hold the door pull in place. ![]() And pull out the finisher. ![]() Now remove the single screw behind the door handle. ![]() Pull the finisher forward ![]() Turn the finisher through 90 degrees and remove it. ![]() Now you need to release the clips along the bottom of the door card. You can use a screwdriver to lever it, or buy a proper trim removal set. ![]() Use the tool to “pop” the clips out. ![]() And pull the bottom of the door card away from the door. ![]() Next you need to pull the small rubber seal out of the way and manoeuvre the card to clear the door locking pin. ![]() Pull the card up to clear the pin. ![]() Now slide the card backwards to clear the mirror/wind cheater. ![]() And remove the door card. Remember, if you have a tweeter fitted then you will need to unplug the speaker cable. ![]() Your door card is now removed. ![]() Refitting is the reverse of removing. |
#2 |
MGTF X-Power
Car: MGTF Cool Blue S.E.
What jobs were you doing?
__________________
#3 |
#4 |
Location: Zeist, The Netherlands Car: MG TF 135 Trophy Blue RHD Originally on 03 plate
Am I the only one on here that just gives the doorcard a good tug to get it off instead of using the fancy lifters.....?
#5 |
Werder Supporter
Good work Clive, I love the pillow right below the door
__________________
Stephan Hebert MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling |
#6 |
That's the dogs bed. The ground was wet, so I had to put something down to kneel on.
#7 | |
regained interest
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#8 |
It was either that or kneel on the dog.
| Bookmarks |
| Thread Tools | |
| How to remove your door card. | CJJ | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 4 | 09-11-2009 20:50 |
| how to remove credit card pymts off Live | hardmonkeys | XBox / 360 Gaming | 8 | 12-01-2009 19:47 |
| Rover 220 Bouble, do i need to remove door card to get to front speakers? | chunk | In-Car Audio, Entertainment, Sat Nav etc... | 6 | 03-05-2006 10:12 |
| How do I remove my door card? - R25 | tahiti25 | MG ZR / Rover 25, 200 & Streetwise | 9 | 27-03-2004 13:53 |
| How do you remove a 25's door card? | Windy Miller | In-Car Audio, Entertainment, Sat Nav etc... | 3 | 19-04-2003 20:16 |
