#1 |
Mudslinger extraordinaire
Location: Ashington, Northumberland Car: MGTF 160, Focus ST2, KTM 640, Kangoo Van
How to adjust door window seals.
One problem with the F/TF is water ingress around the driver and passenger windows.
Signs of leaks are wet carpet (normally under the carpet), water marks on the door card or speaker grill ![]() Or water pools on the top of the door card. ![]() Getting a perfect seal is something of a black art, or even luck. I spent a whole afternoon yesterday just doing the passenger window and I’m still playing. There are many adjustments that can affect the seal on your window, and it is a combination of small adjustments and patience that will get you a good seal. The best way to test your seal is to use a hose. Set it on a rain like spray pattern and try to simulate the rain coming from an angle slightly above and in front of the car. If you set it to too strong a spray and direct it straight at the window it WILL leak, but won’t represent real rain. The first thing you need to do is remove the door card http://forums.mg-rover.org/showthrea...97#post3592497 Once the door card is off you need to lower the window so that it is not up against the stop. ![]() Next you need to adjust each of the 2 upper stops to achieve a good seal. Hopefully you will have seen where the leaks are and know whether to raise or lower the stops. ![]() The bolts that secure the upper stops are 10mm bolts. This shows the front stop, which is recessed through a hole in the door. ![]() Loosen the bolt and slide it up or down to suit. Try small changes first to see if the leaks improve. ![]() Adjusting the front bolt will also affect the alignment of the window at the rear as well. You will need to play around with both stops to get the optimum seal. It really is a case of trial and error. The wind cheater (or where the mirror attaches to) is also adjustable. If you loosen the 2 bolts at the base of the cheater it will slide backwards and forwards with a little persuasion. ![]() Also the seal around the cheater can deform over time. If you need to you can buy some silicone tubing and feed it into the recess to push out the seal a bit. ![]() ![]() ![]() Another thing to remember is the door striker plate. This is adjustable and can cause the door to close more and hold a better seal. Loosen the 2 torx bolts (T40) and slide the plate in to tighten or out to loosen the door closure. ![]() The reason I spent a whole morning playing with this is that I could not get a good compromise between the inevitable gap between the windscreen seal and the hood seal (where they meet) and the rear corner. If I adjusted one then the other would get worse. After a bit of poking around, I found that the rear seal was held to the frame with a 4mm allen bolt. So I loosened the bolt ![]() And chopped some thick washers to use as shims. ![]() I then added the shims in to pack out the seal to frame joint. ![]() This had the effect of closing the gap. ![]() I still have a leak from the wind cheater, but I am going to be removing it at some point and sealing it to the door with black silicaseal to see if it makes any difference. |
#2 |
regained interest
nice work as usual Clive
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow ![]() MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links Soft Resin Badges for sale |
#3 |
Rebel without a brain
top banana clive.....this is something i need to get sorted on mine...only thing im not happy with at the mo
__________________
For sale: parachute. Only used once, never opened, small stain.....................
#4 |
Now with added Blue Flame
Excellent Clive. One of Misty's windows is slightly out of alignment and I've never gotten round to sorting it. This 'how to' will be very helpful
__________________
#5 |
Now avalible in White!
Fantastic thread Clive. Your contributions to this forum are priceless, well done!
__________________
Anna-May Ice White Babe ![]() Where is Martina? Follow her adventures here http://forums.mg-rover.org/showthread.php?t=348405
#7 |
Car: MGF
silicone tubing
great tip with the silicone tubing, what size did you use and where can i buy some?
J |
#8 |
I just searched ebay and bought a selection. I guess the size depends on how much you want to bulk the seal out by.
__________________
#9 |
Thermostat fool
Location: All over the country but usually in Swansea...ish Car: Yellow 115 MGTF, Red Audi TT 3.2 Quattro, Black Escort RS1600i, Blue 206cc, Silver Ford Focus
Brilliant as usual, this is something I need to do as well.
I think our windows are rising too much as they are pain to open when the roof is up, especially the drivers door. Have some rep ![]() ![]()
#10 |
My passenger window jams against the A-pillar before it gets to the top, I have to push the top of it out! It will probably drop off before I get round to fixing it!
#11 |
Hobbits Inc and Audrey2
excellent write up :-) Many thanks :-) this will come in very usefull.
__________________
#12 |
As before, Many thanks for detailed instructions.
My passenger door has to be closed in a certain way to avoid gap, and my drivers door sticks on the rubber sill and doesn't want to let me out lol. Will look into doing this when i have a day off to have a good go at adjustment. Thanks again - Mikki.
__________________
- love my little ladybug - mwaaaahh X
#13 |
'wisp'ering around.......
Marvellous job. Forgot all about the door striker being adjustable!! Will have a look at mine this weekend.
__________________
Genuine Scrap Yard parts fitted.............. |
#14 |
106.6db loudest F
Nice Job
![]() I thought with you going to the dark side welding the door shut an super glue the window in place would have been the way to go ....lol
__________________
FOR SALE MGF VVCMGF Active rear spoiler, manual up/down, brake up/down and soon cornering G-force up/down http://www.youtube.com/user/busterno...10/vx23AlYEjCg http://www.youtube.com/watch?v=rmpsV-fkjwQ http://www.youtube.com/watch?v=oRtQZ...eature=related |
#15 |
Did think about it at one point.
__________________
| Bookmarks |
| Thread Tools | |
| How to adjust the door window seal. | CJJ | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 8 | 10-11-2009 09:04 |
| Bubble 3 door rear side window seals & boot seal | andyellis111 | Wanted | 0 | 09-03-2009 15:19 |
| Anyone from midlands can help adjust my window? | seabass | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 1 | 17-08-2008 09:52 |
| Lubricate door window seals? | Rusty Bullet | 'R8' Rovers (aka Wedges!!) | 5 | 03-10-2006 18:25 |
| Drivers door window fitting into rubber hood seals | Mikef | MGF and MGTF (Sponsored by MG Rover Parts Ltd) | 14 | 12-08-2006 17:55 |
