timing belt or timing belt kit ? Rover 420sdi - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 24-01-2010, 17:48   #1
bob123
Car: Rover 400 (95-99)
HI,
Got an old rover 420 sdi V reg 99. It's got 97,500 miles. Can't find when if at all i did timing belot change. Reckon might have done it at 36,000 miles.
Anyone know when it needs to be changed again?
Should i ask the garage to get the timing belt kit (i..e woith tensioners etc) or just replace the belt?
p.s what is the auxiliary belt - i saw that was changed a couple of years back at the rover dealer at the time on my service receipt?
Thanks,
Bob
bob123 is offline   Reply With Quote
Old 24-01-2010, 18:06   #2
E_T_V
Car: Maestros, 200, 600, ZTT
Belt changes are due at 80 odd thousand miles so it may not have been done yet.
Aux belt is the belt that drives the aircon/alternator/PAS etc.
E_T_V is offline   Reply With Quote
Old 24-01-2010, 20:52   #3
thefarmer
No smoke...no poke
Car: Rover 420 iXLD
Send a message via MSN to thefarmer
I would always change both belts and both tensioners if the history is unknown.
__________________
400 iXLD (~135bhp) - Tu1|Boost @ 19 PSI|Decat|Roose hoses|boost gauge|iL seats|F mirror|Sony BT3600u|262 venteds|chrome 45 mirrors//Planned - FMIC|exhaust|straights|ZS180 struts|Nghtbreakers|CB radio
thefarmer is offline   Reply With Quote
Old 24-01-2010, 23:18   #4
bob123
any idea roughly how much parts would cost for both belts and tensioners? recommend anyone other than dealer e.g. smc
Old 24-01-2010, 23:22   #5
thefarmer
No smoke...no poke
Car: Rover 420 iXLD
The whole kit will be around £150-175.
Try your local motor factors.
__________________
Old 25-01-2010, 09:16   #6
Rik420SDi
Rik420SDi's Avatar
Car: Megane Coupe 1500 DCi
Just to clarify, there are 3 belts in total on the L series:
Cambelt
Fuel Pump
Accessory belt
The Cam and Fuel pump belts (+ tensioners) are what comes in the kit, you need to source the accessory belt separately.
Also worth doing at the same time are the fuel and air filters, unless these are known to be good.
Rik420SDi is offline   Reply With Quote
Old 26-01-2010, 14:08   #7
sprayer
Wink
Bought my Gates cambelt kit from my local motor factors ( cambelt/pump belt/ 2 tensioners/1 roller) for £110 then paid garage £80 to fit
sprayer is offline   Reply With Quote
Old 25-03-2010, 16:54   #8
bob123
Just wondering - Where did you get a garage to do this for 80 quid. Evereyone i call is charging a lot more. I got told 4 hours labour at £246 at &2.50 per hour, they did say the belt kit was £147. They also said it's poss the water pump may need changing meaning another 50 quid. cheapest quote i got so far is £375 on a garage that is just changing the 2 belts - they said they don't normally change tensioners - although i could ask to get this done as well. (i am based in london). Still ringing around for more quotes.
Old 25-03-2010, 20:27   #9
Oldgitpete
Car: Rover 45
Er - I would give that garage a rather wide berth - they obviously don't
know the L-series engine from many other makes where the water pump is driven from the timing belt (eg, VAG) I reckon the water pumps last on the L-series for many thousands of miles - I changed mine at the time of my second timing belt change as I could see a very tiny drip from under the pump area. The pump was obtained at the same time as the belt kit, very reasonable, from AtoZ parts - total about £145 delivered. Now comes the best bit - there was no sign of leakage from the pump but the large cover plate o-ring was badly fitted at engines branch and coolant over all those miles had been seeping past it. The pump looked perfect. Also - they are driven via a tongue/slot arrangement from the PAS pump!
HTH
Pete
PS - anyone with mech know-how will find the belts a doddle to change (a bit tight for room on the 25s apparently) Only problem I had with mine was the stub for the idler coming away from the block, but handy as if it stays in place the idler is a ***** to get past the end without levering the engine over.
Oldgitpete is offline   Reply With Quote
Old 15-12-2010, 05:46   #10
Turkey69
Car: Rover 600
Exclamation
Oldgitpete as im in the Oxford area is ther any chance that you could help me in the new year to change my belts and anything else that you think on my rover? PM me if you would be willing to help you out. Many thanks James
Turkey69 is offline   Reply With Quote
You may not post replies
rover 220d/ 420d GATES timing belt kit (brand new) revincivic For Sale 7 09-12-2011 16:51
need timing belt kit , for my 1997 rover 420 d turbo revincivic Diesel Forum! 1 17-08-2009 17:13
Water pump, timing belt, alt belt, power steering belt...?? Vinny73 MG ZR / Rover 25, 200 & Streetwise 2 24-01-2009 17:35
Rover 400 Timing Belt Kit w i l l MG ZS / Rover 45 & 400 4 18-05-2008 20:29
