Location of the Coolant Temp Sensor?!? - MG-Rover.org Forums
Old 15-02-2010, 13:13   #1
Smurray
Car: MG ZR 105 Mk1
Afternoon ppl,
Just wondering if anyone has a picture showing where the coolant temp sensor is located? My car is only getting around 200miles to 35 and i've read on these forums that this could be the culprate? If anyone else has any other ideas then they would be appreciated. My car also struggles a wee bit now and again.
I know its not he ignition system as i've changed both coil packs and ht leads along with spark plugs. Giving the engine a flush on saturday aswell as fuel filter change and oil filter change. Really hoping i can get my car running well for an extended period of time.
Hoping someone has a solution other than paying out top dollar.
Cheers Scott
Smurray is offline   Reply With Quote Quick reply to this message
Old 15-02-2010, 13:17   #2
spampebs
Car: Fiat Bravo Dynamique 150bhp (formerly ZT190/214 bubble 200 VI)
Send a message via MSN to spampebs
well, when i changed my fuel filter, i noticed a massive change in tickover smoothness, the fact that you could see rust coming out with the petrol in the filter proberbly wasnt helping things , dont see how engine temp would greatly effect economy, unless it thought it was always cold, and was permanently on choke? then youd pi** through it!!
spampebs is offline   Reply With Quote Quick reply to this message
Old 15-02-2010, 13:18   #3
Seanodell
Car: VW Golf VR6
Send a message via MSN to Seanodell
wasnt it only mk2 that had coolant temp sensors? i dont think mk1's have them mate
Seanodell is offline   Reply With Quote Quick reply to this message
Old 15-02-2010, 13:21   #4
SilverRover007
Car: MG ZR 160
Its on the metal elbow that is bolted to the engine block, right side near airbox.
SilverRover007 is offline   Reply With Quote Quick reply to this message
Old 15-02-2010, 13:22   #5
Seanodell
Car: VW Golf VR6
sorry i was thinking of the coolant level sensor!
Old 15-02-2010, 13:28   #6
Smurray
Car: MG ZR 105 Mk1
Ah right....the thing that has the electric feed attached to it on the elbow? Thought it was that but wanted to double check.
Well i think fuel filter could do the job, luckily i've got my fuel filter ready to change.
There's also a fair bit smoke/steam coming out the exhaust?? Could this be caused by clogged fuel filter?
Cheers Scott
Old 15-02-2010, 13:52   #7
spampebs
Cheers Scott
wouldnt of thought so really, smoke would suggest burning oil, that and its cold so its gonna look like its smoking more than usual anyway, yeah get that fuel filter changed, takes about ten mins, id ptfe the threads on it though, mine leaked a bit without, could be halfords sh** filter though!!
Old 15-02-2010, 14:43   #8
Smurray
Car: MG ZR 105 Mk1
I'm hoping with me getting a Bosch (i think) Fuel filter, it should be a good one. I've also bought **5-40w** (Sorry thought it was 5-30w) Mobil S oil, i'm hoping this is ok? Especially as i paid 45 for 6 litres lol.
I haven't got the slightest clue when my car was last serviced as i did the stupid thing of getting a car with no service history! Doh! My aim is to try and renew or refurbish the majority of the parts on my car to get it running as new. These forums have helped alot even tho i haven't done anything major lol.
Scott
Old 15-02-2010, 14:51   #9
rikib
Car: Freelander, and ZR
Grey or black smoke is oil, white is vapour, most common causes of white smoke are moisture build up in the exhaust and evaporates due to heat, as seen in most cold mornings or coolant leak.......
Hows your coolant? Nice pink colour and always staying at half way after engine cools? Run you finger/dry paper towel around the back of the Inlet Manifold and check there are no damp areas to rule out possible IM gasket failure.
Might be a good idea to get yourself a Haynes book mate......
rikib is offline   Reply With Quote Quick reply to this message
Old 15-02-2010, 14:51   #10
Seanodell
Car: VW Golf VR6
shouldnt you be using 10w 40?
Old 15-02-2010, 15:04   #11
Smurray
Car: MG ZR 105 Mk1
Yeah i read that Sean but when i put in my car details on Opie Oils the 5-40w showed up. Am i taking a chance with that?
I really think i have a coolant leak tbh. On Saturday i'm going to be renewing my coolant bottle so will be flushing the radiator and renewing the coolant and maybe also renewing the inlet manifold gasket so hopefully it will sort it.
Touch wood its not the dreaded HGF! Really can't be affording that right now lol.
Cheers for the replies!
Scott
Old 15-02-2010, 16:43   #12
rikib
Known causes of coolant leak are IM gasket and the Coolant Cap.......Would doubt the bottle to be the prob tbh.......
Start with the cheap/easy parts first. New Cap. Replace IM gasket. By the sounds of it the IM gasket has gone and is leaking coolant through the system, hence why you are getting excess white smoke........
Old 15-02-2010, 16:55   #13
Smurray
Car: MG ZR 105 Mk1
Well i've recently fitted a new coolant cap so hopefully its just the IMG. How hard is it to fit? I've seen the 'How to...' but still a little bit unsure....
Could this lead to HGF? or would that only happen if i let the coolant run dry and overheat? I've been keepin a close eye on my coolant so hopefully i'm reducing the chances.
Thanks again for the replies.
Scott
Coolant temp sensor. bezzy3004 Metro / Rover 100 4 11-10-2008 13:28
coolant temprature sensor location?? ZS180 steve MG ZS / Rover 45 & 400 0 21-06-2008 16:32
Water Temp sensor location - urgent help please rob5059 MGF and MGTF (Sponsored by MGFnTFBITZ) 5 03-09-2007 18:16
Best location for Pieburgh MAF temp sensor Bungywilliams MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 13-08-2007 12:11
rover 200 1999 gauge temp sensor location help shane1234567 MG ZR / Rover 25, 200 & Streetwise 1 23-02-2006 14:33
