#1 |
MG ZT Camber on front wheels
I have a MK2 ZT CDTi which seems to have alot of camber on the front wheels
Is this normal as there doesnt seem to be any adjustment I have the standard 18" alloys fitted and the clearance between tyre & strut isnt much either Are all ZT's like this as this is the first i have owned |
| Sponsored Links | |||
Advertisement | |||
#2 |
Only the front and rear wheel toe is adjustable. The camber is set by the design of the suspension. Here are the specs.
![]() The tyre/strut clearance is small, especially in cars fitted with wider rims. The rims used should always be within the limits set down in the Handbook. EDIT: I have yet to figure out how the differences between the 75 and ZT specs are reconciled by the fact that all the suspension parts are the same. Some parameters are clearly affected by a variation in toe setting, but I'd like someone to explain it fully. TC |
#3 |
Trader Supporter
Not all suspension parts are all the same they differ in lower arm bushes, subframe bushes, antiroll bar thickness, spring strength and ride height, and omission of rear anti rollbar on some models
__________________
TS Autos - I do everything apart from paint and bodywork, I excel in trim, mechanical and electrical faults on all models, but know ZT/75's every nut and bolt quite literally. Please PM me if you need a part or work doing to your car! location as requested Midlands Area DY8 1XQ www.tsautos.com |
#4 |
Ah, so they do. I hadn't noticed that before. So most of the wishbone bushes sold on eBay aren't suitable for both 75s and ZTs as they specify in the ads. Could that explain why tyre wear is so common on these cars?
TC |
#5 |
Trader Supporter
Yes the diesels had more rubber in the rear bushes clearly evident looking at two together,
__________________
#6 |
So the diesels differ from petrol cars and the 75s differ from the ZTs. How many different bush fittings does that mean?
TC |
#7 |
Trader Supporter
No diesels differ from petrols so two different bushes, the Mg's used diesel suspension set up plus later in life different subframe mounts all very confusing, because you could order an Mg with comfort suspension meaning diesel subframe mounts and diesel bushes for the arms
__________________
#8 |
Blimey, all rather complex. It seems a good reason not to buy derivative bushes from eBay, where none of these distinctions are recognised. They just sell mountings for all 75 & ZTs as one item.
TC |
#9 |
Trader Supporter
Do rimmers list a part number for each Tc Have you noticed
__________________
| Bookmarks |
| Thread Tools | |
| front wheels MG ZR | gigidel | MG ZR / Rover 25, 200 & Streetwise | 6 | 20-01-2010 09:52 |
| Negative camber on both rear wheels... | sarah001 | MG ZR / Rover 25, 200 & Streetwise | 3 | 29-08-2009 14:05 |
| Front camber adjustment? | mark3 | 'R8' Rovers (aka Wedges!!) | 0 | 21-03-2009 20:21 |
| Rover 200 front camber adjustment ? | Rally Rover | Others | 2 | 05-02-2006 17:35 |
| Mg Zt Wheels ; What Also Fits ?? | billy mc gill | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 0 | 11-01-2005 16:45 |
