#1 |
Location: South Coast Car: '53' MG ZT+ 1.8T Anthracite , '05' ZT+ CDTI 135 Silver Sparkle
Another 1.8T Hesitation under hard acceleration
Hi guys as per title my 1.8T hesitates just as the turbo is kicking in at 3000RPM upon flooring the accelerator mainly in 2nd but also in 3rd gear.
At first I thought it was the common misfire symptoms that everyone else has pointed to. I have checked the turbo pipes all seems fine and I dont think it is the coil packs or spark plugs etc. I wouldn't describe it as a misfire or any kind of electrical fault. It is definitely more like a very strong hesitation causing the whiplash jerking that others speak of. I have narrowed the problem down and find it only happens when I accelerate hard with 1/4 of a tank or less of petrol. So my question is do you guys think it is fuel related and do I need to get myself an orange clip on my filter as maybe this is the cause???? This problem ruins what otherwise is an excellent drive when working correctly. Any help much appreciated |
| Sponsored Links | |||
Advertisement | |||
#2 |
Location: Yeovil Car: Jaguar X-Type Sport 2.5 V6. Peugeot 207 Verve 1.4 2010.
Hi,
It could be the manifold pressure sensor, number 6 on this grid. http://www.rimmerbros.co.uk/Item--i-GRID001691 They sometimes give that sort of problem. Or it could be sucking air in around the throttle body? |
#3 |
#4 | |
If these were the problem, wouldnt this happen all the time? and not just when there is little fuel in tank? Last edited by MR (Z)T; 10-05-2010 at 11:34. |
#6 |
Possibly. I'm going on what I've read on here in the past. I did read a post that someone had a problem much as you describe, replaced that sensor and it cured it.
#7 |
Trader Supporter
Turbo vac and boost pipe oil swollen and sucking in air almost definately
__________________
TS Autos - I do everything apart from paint and bodywork, I excel in trim, mechanical and electrical faults on all models, but know ZT/75's every nut and bolt quite literally. Please PM me if you need a part or work doing to your car! location as requested Midlands Area DY8 1XQ www.tsautos.com |
#8 |
#9 |
Trader Supporter
No all the time under load if it's not the filter syndrome, it'll be this it's repairable with a smaller pipe insert or cable tie
__________________
#10 |
#11 |
Trader Supporter
See the post boost problem on this page it shows the pipes I'm talking about
__________________
#12 | |
Thanks TS do you mean this thread http://forums.mg-rover.org/showthrea...=boost+problem ? If so whats the best position to sort the white pipe on the wastegate and should i need to remove anything? |
| Bookmarks |
| Thread Tools | |
| hesitation on acceleration | davecooper | MG ZS / Rover 45 & 400 | 7 | 23-05-2008 17:53 |
| Rover 75 1.8t Club- misfiring on hard acceleration | Old Roverian | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 3 | 06-07-2005 11:40 |
| hesitation on acceleration | spikes | Others | 2 | 29-04-2005 14:15 |
| Hesitation on Standing Start Acceleration | vitessecoupe | Others | 5 | 03-06-2003 12:20 |
| Hesitation on Standing Start Acceleration | vitessecoupe | Others | 0 | 02-06-2003 09:26 |
