D'oranging help (again, not for the last time either knowing me!) - MG-Rover.org Forums
Old 12-05-2004, 12:45   #1
foshdafosh
Car: '00 Honda S2000
Send a message via ICQ to foshdafosh Send a message via MSN to foshdafosh Send a message via Yahoo to foshdafosh
Question D'oranging help (again, not for the last time either knowing me!)
Afternoon all!
I've done my lights, they look lovely!
Couple of questions though, if they're not sealed properly, how long d'ya think it'll take for them to go wrong?
I want to sell these ones and do the other set of lights I've got you see. But I don't want to sell duff goods to anyone, so I'm wearing the nice lights on my car to see if they go wrong..
Ta all!
Foss
foshdafosh is offline   Reply With Quote
Old 12-05-2004, 14:28   #2
Striker
Car: '99 Rover 200 Vi
You'll find out very soon. Just use a pressure washer (or whatever you call them) on them, you'll see damp inside of the lights if they haven't been sealed properly.
Striker is offline   Reply With Quote
Old 12-05-2004, 14:31   #3
foshdafosh
Ooer... Fingers crossed!!
It needs a clean anyhow, I'll get it done this afternoon...
Old 12-05-2004, 14:47   #4
Schtopper
Car: Something Else
They'll look like my fog lights did when it rained, half full of water and if they're not sealed properly or any air containing water vapour has got in whilst you were doing the mod you'll get loads of condensation building up on the inside and that realy can be a bugger to sort out. i've had to put my fog lights in the oven to stop them doing that!
Schtopper is offline   Reply With Quote
Old 12-05-2004, 15:54   #5
lard
Car: MG ZS
Send a message via MSN to lard
Foss
I would so like to do this on my ZS - can you advise where to get the lights from??
Thanks,
lard
lard is offline   Reply With Quote
Old 12-05-2004, 15:58   #6
Schtopper
Car: Something Else
You don't replace the lights (well you can but the choices for the ZS are well nearly none existent) de-oranging i think in the way he's on about involves taking apart the existing headlight unit and removing the orange lining in the indicator leaving clear plastic. Not something i'd want to do myself and certianly not whilst the car is still under warranty (because well it won't be anymore)
Old 12-05-2004, 16:00   #7
Striker
The 45 lights don't have the orange bits, so you could fit these as well (not cheap though).
Old 12-05-2004, 16:01   #8
Schtopper
Car: Something Else
Don't they?!?! oooh i didn't know that i assumed they were exactly the same unit given it's pretty much the same car. Would cost around £220 i'd imagine, i know a ZS headlight unit is £110.
Old 12-05-2004, 16:28   #9
Mike12345
Car: Other Manufacturer
Yeh for the ZS you can change for the 45 headlights.
Anyway...fosh...please seal em properly. Trust me.
Any water in there will just nacker the lights over time, rendering them useless.
Myne steamed up for a few hours...then went completely, so giv it a bit of time.
I think it was just like a tiny bit inside when i sealed em back.
Just seal em back together, then take em out again...
And seal over it all again. That usually does the trick.
Mike12345 is offline   Reply With Quote
Old 12-05-2004, 18:06   #10
Mgfdude
Car: MGF
Send a message via MSN to Mgfdude
will the 400/45 lights de-oranged fit 200mk3?
Mgfdude is offline   Reply With Quote
Old 12-05-2004, 18:29   #11
foshdafosh
This is my concern.. There ain't no way I'm doing it to the other set until I've run these ones for a while.. Touch wood, there was no moisture in them today.. But as you said, over time!
I think I might give it as long as a month, if they cloud up at all, they're dead and I've done it wrong yeah?
Also, for those of you who are interested in buying the lights, hang on a while.. It's going to take me a long time to decide these are fit for sale! Even then, I've got to do it to my other set and test those too!
I promise I'll put a post up in the for sale section if I do sell any though..
Old 12-05-2004, 18:31   #12
foshdafosh
I don't think so mate, I just looked at the 400 over the road and they're not really the same shape..
Maybe one of the companies that sell the lexus lights should start making these! I know I'd have bought some.. May still have to if these go t#ts up!
Old 12-05-2004, 20:14   #13
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Interesting this.....because there is a Rover technical bulletin that covers
the subject of the Mk3 200 headlights "fogging up".........Dealers are advised
to inform customers that the headlights are in fact not sealed and the fogging can be considered to be normal and should dissappear after the headlights have been on for some time.
I've just had a look at a 200 in the scrappies that had de-oranged headlights.....I wanted the indicator bulb holder...its all rusted...I bet the
new sealant used was of the silicone variety....ooooh I did warn you all!!!
technozen is offline   Reply With Quote
Old 13-05-2004, 08:02   #14
foshdafosh
How odd.. Did you read that in the Rave thingy then?
Ermmmm.. What's wrong with silicone then? That's what I used.. :-S
Old 13-05-2004, 15:33   #15
technozen
Mmmm....Rover..
technozen's Avatar
Silicone based sealants give off acetic acid as they cure....which is corrosive.
My original tutorial mentioned the use of a non-silicone sealant for this very reason.
Old 13-05-2004, 15:46   #16
Striker
Not to mention the effect it gives when the front of your car has to be resprayed .
Old 13-05-2004, 16:25   #17
Mike12345
What does that mean Sander?
Old 13-05-2004, 19:36   #18
foshdafosh
I followed instructions which said this:
"Use a silicone mastic to replace the original grey sealant, preferably a non acetic type
such as RITO. There is no need to fill the groove right to the top as it will squeeze out
everywhere when the two halves are reassembled.
Fill the groove about one third the way up."
I didn't understand so showed this sentence to a cousin who does understand! He gave me some stuff he said was right.. Is the above statement correct?
Old 13-05-2004, 21:25   #19
technozen
Mmmm....Rover..
technozen's Avatar
Well, I had used RITO before and knew it was a non-acetic sealant and that
it wouldn't do any harm.
Silicone sealants that give off acetic acid have a familiar "vinegar" smell....after all thats what vinegar is.
Old 13-05-2004, 21:58   #20
Striker
If the front of your car has been in contact with silicone and it has to be repainted, the paint won't hold very well.
You may not post replies
brakes scraping time to replace. EBAY time??? mgfnortheast MGF and MGTF (Sponsored by MGF Mania) 4 31-08-2007 20:54
FAO: Belgian Yellow Scissor Doored F (Or anyone knowing him) LuCkY MGF and MGTF (Sponsored by MGF Mania) 27 30-03-2007 15:01
Bulldog claims BT deliver on time less than 60% of the time Bazza Tech Chat 0 25-07-2005 09:12
D'oranging headlight aligment question Mike12345 Others 0 18-08-2003 19:41
