How to remove a locking wheel nut... - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Rover 600
Old 26-07-2010, 20:24   #1
XR219
Car: Rover 600
Without the key!
The two front wheels on the Ti have the original rover security nuts, but the key nut has self destructed. Has anyone an idea of the best way to get the nut off without damaging the alloy?
Ta muchly
XR219 is offline   Reply With Quote Quick reply to this message
Old 26-07-2010, 21:12   #2
Ray_S
Car: Honda Civic Type-S (05), Honda Accord 2.0i SE (98), Honda Civic 1.4i S Auto (00)
Is it the bayonet style key with a number stamped on it?
Might be easier to obtain/borrow another key, if not an option then hammering some old 12 point socket on might work or paying a fast-fit place if its still mobile and you don't have the tools.
Ray_S is offline   Reply With Quote Quick reply to this message
Old 26-07-2010, 22:07   #3
XR219
Car: Rover 600
Hi Ray,
Not mobile I'm afraid. Basicly the nut looks like a completely rounded nut, but with two groves cut in in along its length. I think I'll give the 12 point socket thing a go, either that or I'll see if there is a mobile fast fit who can come and do it.
Thanks for the help.
Old 26-07-2010, 22:18   #4
amtcoupe
Car: ford puma , rover 214se,ford ka
you can buy a special socket for this job , look for locking wheel nut removal tool , its a socket with a left hand thread cut into it , as you tighten it on to the nut it cuts into it and when it reaches the end of the thread starts to undo it , good bit of kit , andy
amtcoupe is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 02:32   #5
600Racer
Car: 94 620 SLi (R.I.P.), 98 414 LE (R.I.P.), 620Ti
if you do get one of the special sockets, which by the way deffinately work great, please remember not to leave it in the car.
I have one, and unfortunately got pulled at the wrong, cue 4 hours down the police station, explaining that the alloys in the back seat were my friends (who was the passenger) and that I had a legitmate reason for having the locking wheel nut remover, which was purely the fact it was cheaper to buy the tool than pay 5 per nut to have mine taken off, and it has saved me even more than that since, helping out friends and family as well. Anyway cut a long story short, my mate had to get his gf to walk down to the cop shop with the receipt for the alloys before they let us go, they wanted to do us for theft and when that fell through they were going to charge me with going equipped, until they researched and found out I was actually telling the truth.
600Racer is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 08:32   #6
xDGTx
Car: Other Manufacturer
Ditto.. One of my essential tools...done many a friends car with it.
xDGTx is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 12:48   #7
XR219
Car: Rover 600
Perfect chaps. That sounds easier. I'll pick one up tomorrow. New Box arrived today, so really need to start getting the old one out, and wheels off would be a good start.
Cheers,
Ben.
Old 27-07-2010, 19:05   #8
MetroMartin
Car: Rover 620ti, Metro 1.8 VVC, 1982 X reg MG Metro 1300, Rover 214Si Lotus Elise S2, Porsche 924
when in the scrappy, i've used a deep 19mm socket and steping on it so the socket is its at an angle with my breaker bar works most of the time.
means i've been able to get good alloys and tyres which others couldn't get off
MetroMartin is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 20:47   #9
XR219
Car: Rover 600
Thumbs up
Got them both off tonight. One with the reverse thread tool... worked perfectly.... but, then couldn't get the nut back out of the reverse thread thingamybob... so for the second wheel, used an 18mm socket hammered over the top. Both methods worked perfectly. Thanks for the advice :-)
Old 09-04-2012, 15:07   #10
andypandy1961
Car: Rover 25
how do you remove the reverse thread socket from the nut
andypandy1961 is offline   Reply With Quote Quick reply to this message
Old 14-03-2013, 16:19   #11
freddyokel
Car: MGF 1.6, Berlingo 1.9D
Sorry to rescurect a dead thread, but I've just been through this.
Laser Tools 'Emergency locking wheel nut removal tool'.
After mangaling by Kwik-**** so the 17mm removal tool would fit on it, I tightened it onto the nut as much as would go with the ratchet handle, then around 1280 degrees more using a 24" breaker bar and off came the nut.
My dad and I had to mount the socket in the headstock of a rather large metalworking lathe and drill out the old nut using a 13mm drill mounted in the tailstock.
Brutal.
freddyokel is offline   Reply With Quote Quick reply to this message
Old 19-03-2013, 12:31   #12
The Singing Bush
Car: Mini Cooper S & BMW X1 184ps 2.0d
I bought a set of "OEM" MG Rover locking nuts, branded McGuard - just put the first one on and just about to nip it up and it sheered off!!
They look like a cheap nasty imitation to be honest but i bought them last year in the summer so i cant look back at previous history to find the seller - meanwhile Im stuck with a perfectly round sheered of nut, any ideas would be really helpful ?
thanks
The Singing Bush is offline   Reply With Quote Quick reply to this message
Old 19-03-2013, 13:20   #13
The Singing Bush
Done! Went to local tyre place and they used a bit of brute force... Off it came
Old 19-03-2013, 14:19   #14
LOONEY666
Car: 618IS silver bullet
what a ****** around
LOONEY666 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Unable To Remove Locking Wheel Nut!!! Dandemann8 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 21 22-07-2009 21:02
Wheel nut caps?? how do you remove? Iain160Trophy MGF and MGTF (Sponsored by MGFnTFBITZ) 6 18-06-2009 17:30
How to remove a damaged locking wheel nut? MG Novice MGF and MGTF (Sponsored by MGFnTFBITZ) 20 13-05-2009 12:58
Alloy wheel locking wheel nut key jellybean Other Motoring Chat 2 22-09-2005 16:28
Locking Wheel Nut Banford Others 3 05-08-2005 12:24
