Interior Clock Display Not Working? - MG-Rover.org Forums
Old 27-07-2010, 10:44   #1
george1986
Car: MG ZR
Red face Interior Clock Display Not Working?
I have a MG ZR 2004. The interior clock display is very hard to read? You can hardly see but the display if there? Any Ideas how to fix this?
george1986 is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 10:48   #2
richipro
sounds like the bulb has gone easy to replace. just pop the surround off unscrew the clock and there is a bulb in the rear to replace. sure there are more details explanations on here.... 5 mins max time wise.....
richipro is offline   Reply With Quote Quick reply to this message
Old 27-07-2010, 10:50   #3
ironeagleuk
Car: Rover 25 1.4iXL
sounds like the backlight bulb(s) have gone.
Should be bright during the day, and dim at night.
Easy to replace from what I recall.
With a flat blade screw driver, carefully prise off the black surround from the bottom, and it should just lift up and out of place.
This then reveals abit of a hole below the clock, so you really need to fill that with newspaper or something so the screws don't fall down.
There are either 2 or four screws holding the clock in place....undo these carefully not dropping them, pull the clock forward and disconnect the cable.
The clock is now free for you to turn over and see the bulb holders on the back....these unscrew half a turn and you should be able to see which has blown.
ironeagleuk is offline   Reply With Quote Quick reply to this message
400-- R860 radio/clock display not working !! Scottreilly In-Car Audio, Entertainment, Sat Nav etc... 7 20-04-2010 17:49
clock display leighwhite02 In-Car Audio, Entertainment, Sat Nav etc... 6 11-10-2006 15:03
R8 interior clock display... Rover_King For Sale 0 04-09-2006 23:19
Clock display off tony_anon Others 5 12-01-2006 14:24
Clock/radio-display not working Striker In-Car Audio, Entertainment, Sat Nav etc... 3 17-12-2003 06:15
