engine misfire when warm flashing engine management light - MG-Rover.org Forums
Old 13-08-2010, 17:52   #1
mgljf
Car: MG ZS
Unhappy engine misfire when warm flashing engine management light
Hi i have a 52 reg 1.8 mg zs. Yesterday on my way to work after about 15 mins the engine started to misfire then the engine management light started to flash. I pulled over, called RAC and waited about half hour. When they arrived he turned engine over & could not find any problem. So he escorted me to work, about 10 mins, and it didnt happen again. On way home i went another route off motor way & went steady, It appeared fine.
Partner did a service on it last night, changed oil filter, fuel filter etc.
On way to work this morning after 15 mins exact same thing happened. So i waited a while and started up again, only got half mile before it did it again. Waited a while and only got 200 yards this time. Every time i restart the light is no longer on.
Called RAC he did diagnostics, gave error general misfire.
I'd been waiting over an hour this time so he escorted me back to garage. Yet again the problem never happened. Rac guy advised garage to check coils.
They've just told me that after 2 hrs looking at it they still have not found problem. They took it for a test drive themselves and it did the same to them.
What could it be?
mgljf is offline   Reply With Quote Quick reply to this message
Old 13-08-2010, 18:20   #2
marty1a
Car: VW Passat 20V & 3dr Freelander & Rover 216Si (3 Dr) + VW Caddy Van
Send a message via MSN to marty1a
Could be a bad cam sensor? Inlet manifold leaking?
Do you no what the error code was? p0300? Or p0301,2,3,4 if its 1-4 at least it will tell you what cylinder is causing it where as p0300 is a random misfire across the cylinders.
I no its not doing it all the time but start with the basics, are they the right spark plugs? are the leads good?
compression test each cylinder
marty1a is offline   Reply With Quote Quick reply to this message
Old 13-08-2010, 23:53   #3
2bellys
Car: Transit T280 100bhp, Diesel Focus, Kubota B6000 Tractor & ZS180 project
do not i repeat do not use your car with the engine managment light flashing it is telling you that you are damaging your catalytic converter.
if the light is constantly on it is telling you a fault exists which will affect emmisions and needs diagnosing/rectifing
if the lamp flashes it usally means a significant ignition related misfire exists and is dumping raw petrol onto the cat monolith causing it to overheat and melt and then block the exhaust.
low compression wont cause a random misfire and make it intermittant likewise an inlet manifold leak
the fault is ignition related pure and simple.
you need to find out what cylinders are misfiring if its the inner 2 or outer 2 look at the coil that supplys these cyinders but before you replace the coil check the live and pulsed neg to it to make sure its not wiring or and ecu not suppling the pulsed neg (unlikely)
a fueling fault wont make the managment lamp flash
if its just one cylinder swap the spark plug with another cylinder and see if the misfire moves to the cylinder it was swapped with. if yes then replace all your spark plugs
if it is a cylinder that is supplied with a lead (coil not on top of plug) then try a new lead (im assuming it a EU3 engine)
2bellys is offline   Reply With Quote Quick reply to this message
Old 14-08-2010, 07:57   #4
graphic
Car: Rover 400 (95-99)
I would also check all wiring, looking for loose connections and places where the wiring might have rubbed through causing an intermittant short. Check main ECU plug is clean and tight.
Have a close look at wiring beneath battery tray and L/H side of inlet manifold.
graphic is offline   Reply With Quote Quick reply to this message
Old 14-08-2010, 08:33   #5
marty1a
[quote=2bellys;3983286]
Its does on a freelander 1.8k series engine, trust me on this one I chased my tail for a day until I compression tested it and found cylinder 1 down on compression!
As I said before start with the basics, as the RAC & the local garage have had it on diag equipment and cant find the fault
Have a look at http://www.random-misfire.com/ could be a vacuum leak
Old 14-08-2010, 14:49   #6
mgljf
Car: MG ZS
Done all of the above, and now it seems to have moved on to a different fault! its now running till it loses power completely to a stop and the engine management unit is no longer flashing and then it wont restart for ages.
Old 14-08-2010, 22:04   #7
LORDPSK
Car: NOW HAVE A 25, 45 & 75
Sounds like it is either the temp sender unit or lambo sensor which is over fueling the car and choking it
LORDPSK is offline   Reply With Quote Quick reply to this message
Old 17-08-2010, 01:03   #8
eddiemax28
Car: 2004 (54) mg zs+ td
Send a message via MSN to eddiemax28
id say the temp and lamba sensors too,, i had this on my 1.4 16v k, wouldnt start on cold mornings and when it did start it would misfire and blow out some smoke but once warm it was find untill the lamba sensor went down on it and lost power ect
eddiemax28 is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Flashing Engine Management Light James TF MGF and MGTF (Sponsored by MGFnTFBITZ) 9 16-02-2010 20:09
Engine Management flashing pablo892 MG ZS / Rover 45 & 400 6 07-07-2009 07:28
VVC Misfire when warm only when engine bay light comes on WEBER45 MGF and MGTF (Sponsored by MGFnTFBITZ) 10 04-03-2009 22:35
Engine management light flashing 2.0 diesel Corkey MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 24-09-2008 21:35
Rover 25 GTi Misfire and Engine management warning light ft1972 MG ZR / Rover 25, 200 & Streetwise 3 28-06-2008 13:56
