Freelander leaking water please help!!!! - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Land Rover
Old 29-09-2010, 14:24   #1
wolle18
mhmm pink :D
wolle18's Avatar
Bloons Champion!Tournaments Won: 4
Car: Rover 25
Hi everyone
my dad has a 1999 Freelander and he is having a problem with it leaking water as it only seems to leak when the engine is cold when he is topping the water up but after it has been running a few mins it don't seem to be leaking at all so it is very confusing as the temp gauge is as it suppose to be so we dont no what it could be so if you have had the same problem or could suggest what it could be reply to the thread cheers would really apprecaite it
wolle18 is offline   Reply With Quote
Old 29-09-2010, 15:59   #2
The Jester
Car: MGF Lucifer & Ford Clitoris
Send a message via MSN to The Jester
what model is it......?
im looking at purchasing one so asking questions myself
but your dads problem could be the water pump if its the 1.8 petrol as its the same engine as mgf
when the engine goes cold things contract thus the leak....can you source roughly where its coming from?
see this thread if water is leaking from the same area (again its same engine if petrol 1.8)
http://forums.mg-rover.org/showthread.php?t=383932
if its a diesel or not from same area ignore everything ive just said...just trying to help lol
The Jester is offline   Reply With Quote
Old 29-09-2010, 16:16   #3
wolle18
mhmm pink :D
wolle18's Avatar
Car: Rover 25
yeh mate it is a 1.8 and i changed the cam belt and water pump last week and cant be leaking from there as the water seems to be on the other side and at the back but true it could be threw contracting but cant seem to source the leak lol
Old 29-09-2010, 19:24   #4
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Sounds like the inlet manifold gasket.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details.
technozen is offline   Reply With Quote
Old 29-09-2010, 23:19   #5
wolle18
mhmm pink :D
wolle18's Avatar
Car: Rover 25
thanks for the reply technozen but its not leaking right at the front of the engine its like at the back below the injection thingy and below the camshaft oil seals near the air filter
Old 30-09-2010, 08:03   #6
technozen
Mmmm....Rover..
technozen's Avatar
Err, the "injection thingy" is the inlet manifold.
It's gasket is known to perish which results in external coolant leaks and internal leaks into cylinders 1 and 4.
__________________
Old 30-09-2010, 11:50   #7
wolle18
mhmm pink :D
wolle18's Avatar
Car: Rover 25
o i see mate but the injection thing i mean is where the throttle body onnects to is its under there where the water is or seems to be coming from
Old 30-09-2010, 19:33   #8
technozen
Mmmm....Rover..
technozen's Avatar
The manifold gasket was changed in production because of it's tendency to leak, the older type gasket was black, the modified type is green.
It's hard to know which type is fitted to yours although I have seen the modified type leaking!
This thread covers the gasket replacement....
http://forums.mg-rover.org/showthread.php?t=213626
__________________
Old 01-10-2010, 17:19   #9
wolle18
mhmm pink :D
wolle18's Avatar
Car: Rover 25
thank you mate i think you is right with saying it was the gasket so picked one up and will fit it hopefully 2moz hope that stops the leaking thanks agen mate
You may not post replies
leaking water? help! bam2009bino Metro / Rover 100 5 12-08-2009 15:59
Leaking Water CARLT MGF and MGTF (Sponsored by MGF Mania) 14 10-10-2008 14:29
Water droplets under Oil Filler Cap but I have the freelander gasket?! trancera MG ZR / Rover 25, 200 & Streetwise 22 12-07-2007 22:22
leaking water zsgav28 MG ZS / Rover 45 & 400 1 19-05-2007 20:12
leaking water msd26179 MG ZR / Rover 25, 200 & Streetwise 2 10-03-2007 16:38
