Rear window heater question - MG-Rover.org Forums
Old 04-10-2010, 17:50   #1
steve_p
Car: Other Manufacturer
My rear window heater doesn't seem to work but the light on the dash is always on as if it's switched on, except when the rear wiper is going, it just flashes as the wiper goes over it, now Sometime in june i remember removing a little strip of electrical tape from the rear window, at the time i thought nothing of it now i realise it was stopping the light coming, so my question is how can i get it to work properly, i'd like to fix it before it gets cold enough to need it. its a '99 211 by the way
cheers Steve
steve_p is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 18:20   #2
matrix MG
Tournaments Won: 1
Car: MG Express
have you checked the tailgate wiring? the wires going through the drivers side rubber grommet are prone to wear, and if the sheathing is rubbed off 2 or more it can cause various problems.
matrix MG is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 20:12   #3
jimbo2260
Car: Rover 45 connoisseur MKII
i had a similler problem, my heated rear window screen was not working, this is how i fixed it......open the boot, look at the right hand side were the boot joins the body, u should see a rubber tubing, peel it back from the body and you should see a load of wires, the green and purple wire is the rear heated screen,( its also the thickest one) if thats split then put it back together with appropirate fixings, this should solve you problem, then put evrything back together, making sure the rubber tubing is seald to the body or boot, which ever one u peeled back, and you should be ready to go!!!!!
jimbo2260 is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 20:15   #4
starchild
Car: MGF 1.8VVC, Vauxhall Astra SRi TDCi
Send a message via ICQ to starchild
I'm having the same problem too, hadn't got round to checking yet so will give that a go as soon as it stops raining.
starchild is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 22:26   #5
steve_p
thanks alot for the replies, i'll try sort it out tomorrow and report back
rear window heater gazglenn MG ZR / Rover 25, 200 & Streetwise 1 22-12-2008 16:25
Rear Window Heater SCFC_Messiah MG ZR / Rover 25, 200 & Streetwise 5 15-03-2008 12:54
rear window heater dimi MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 27-01-2007 02:29
No sterio, rear wiper, rear window heater & indash alarm light! 216sli 'R8' Rovers (aka Wedges!!) 0 09-09-2006 07:45
Rear Window Heater? AndyG V8 SBrake MG ZT / Rover 75 (Sponsored by Rimmer Bros) 15 11-01-2006 14:27
