Shredded T50 Torx bolt? Help - MG-Rover.org Forums
Old 13-02-2011, 14:50   #1
Glenn_23
Car: MG ZS
Can anyone help me. The bolt that holds the front seat runners to the floor has shredded when i was changing the interior over. Its sods law that it was the last bolt that i was trying to undo. Anyway can anybody advise me on what step to take to get it out?
Glenn_23 is offline   Reply With Quote
Old 13-02-2011, 15:46   #2
rover_all_over
Car: 414 16v 620 sldi
mmmmmm tricky try with a hack saw to make a grove init and use a slot headed screw driver and unscrew it?
rover_all_over is offline   Reply With Quote
Old 13-02-2011, 16:41   #3
mattyprice4004
Octo to the pus!
mattyprice4004's Avatar
Car: Rover 620 GSDI
Send a message via MSN to mattyprice4004
Angle grinder or hacksaw, slot the bugger.
__________________
Discount MG Rover Spares - www.dmgrs.co.uk
Cambelts, auxiliary belts, repair kits & more!
Heater speeds 1+2 not working? Click Here
High clutch pedal on your 400/45/ZS? Click Here
Rover 25/45 ZR/ZS diesel oil cooler pipes - Click Here
5-piece cambelt kit for the L series engine, £89.99. Click Here
http://facebook.com/discountmgroverspares
mattyprice4004 is offline   Reply With Quote
Old 13-02-2011, 17:26   #4
E_T_V
Car: Maestros, 200, 600, ZTT
Or drill it out.
E_T_V is offline   Reply With Quote
Old 13-02-2011, 18:23   #5
Southside
Car: Rover 200 Coupe
Send a message via MSN to Southside
I think if its tight enough to round off with a socket you've got no chance of undo'ing it with a screwdriver.
Southside is offline   Reply With Quote
Old 13-02-2011, 18:36   #6
Andy400
Car: Rover 45
hammer and chisel then finish getting it out with grips
Andy400 is offline   Reply With Quote
Old 13-02-2011, 20:53   #7
rover_all_over
ha ha thats a good point
Old 13-02-2011, 21:01   #8
Phil
Car: MG ZT 135+ (Plus Pack) Suzuki SV650
Centre punch it loose.
Phil is offline   Reply With Quote
Old 14-02-2011, 07:02   #9
alanrichard
alanrichard's Avatar
Car: exR45 TD, R75Tourer CDTI, XRV750, DR350
Yeah hammer n chisel or punch.
Note: don't try to chisel the head off! Whack the edge to nudge it anticlockwise - works a treat.
a
alanrichard is offline   Reply With Quote
Old 14-02-2011, 08:15   #10
stamford
Car: MG ZS200, TD5 Discovery, MGF SE 1.8i Wedgewood
Weld an M8 nut to the head. Less damage then flying sparks from a grinder! That's assuming a decent chisel doesn't move the head around.
stamford is offline   Reply With Quote
Old 14-02-2011, 11:47   #11
Glenn_23
Car: MG ZS
I managed to get a T50 head Allen Key in and got some grip at the bottom of the nut. They round very easy might have to invest in some more Nuts.
Old 14-02-2011, 12:53   #12
stamford
Saying that some torx and allen key heads are not what I call sharp and full to the tip, they are deformed from when manufactured. I have before now ground the head down to ensure a full size dimensional grip is available.
You may not post replies
bumper torx bolt size Petevick MGF and MGTF (Sponsored by MGF Mania) 15 12-11-2012 07:18
45 front seats torx bolt size zippo1970 MG ZS / Rover 45 & 400 5 08-07-2009 10:19
Tx30 Torx Bolt Removal??? Softwarez MG ZR / Rover 25, 200 & Streetwise 9 11-08-2008 15:17
Sheared Torx Bolt madmandegge MG ZR / Rover 25, 200 & Streetwise 17 26-05-2006 17:05
Torx bolt size Shuntis Others 20 08-05-2004 13:19
