rover 75 diesel cooling system. - MG-Rover.org Forums
Old 22-02-2011, 07:10   #1
crusaderxvx
Car: 1953 MG TD
Hi Good morming. can anybody tell me how the cooling system works. ie water from the bottom hose goes to the pump, normally water from the thermostat goes to the top of the rad, but it doesnt seem to do this on the 75 cheers Ian
crusaderxvx is offline   Reply With Quote Quick reply to this message
Old 22-02-2011, 13:22   #2
T-Cut
The cooling principle in the diesel is the same as any other engine. The physical layout may look different, but coolant flow is basically the same.
The flow from the head/thermostat goes to the radiator top through the large upper (tapered) hose. Several members have inserted an inline stat within this hose to improve (increase) the running temperature.
TC
T-Cut is offline   Reply With Quote Quick reply to this message
Old 22-02-2011, 16:25   #3
FrenchMike
Car: Rover 75 CDT
Hi,
a little diagram to see how it works:
Mike
FrenchMike is offline   Reply With Quote Quick reply to this message
Old 22-02-2011, 17:45   #4
crusaderxvx
Car: 1953 MG TD
Hi Mike thanks for the diagram. do you know where inline stat should be placed? and why the rad and bottom hose stays cold? cheers Ian
Old 22-02-2011, 17:55   #5
T-Cut
Originally Posted by crusaderxvx View Post
Do you know where inline stat should be placed?
Looking at French Mike's image, it goes in the large central hose running from top of engine to top left corner of radiator (as viewed from front).The hose is cut to insert an aluminium housing. I believe an alternative is to use an in-hose type, which presses into the hose (no cutting).
Coolant exiting the bottom of the radiator has normally flowed down through it and is therefore colder than the upper input. With the diesel, the input is often quite cool anyway due to stat failure. Typically 60-70C, which in engine running terms is cool. After passing through the radiator this fluid will be distinctly cold.
TC
Old 22-02-2011, 18:18   #6
crusaderxvx
Car: 1953 MG TD
TC
Hi TC thanks for the input cheers Ian
Old 24-02-2011, 05:49   #7
crusaderxvx
Car: 1953 MG TD
hI. AND THANKS FOR INPUT. on the diesel the thermostat is the other side of the engine, water flows across the head, and exits from the side on its way to top of rad.
does any one know where the coolant is fed to from the filling resevoir, i suspect the engine block?
trying to get as much info as possible on the cooling system. and experimenting with inline thermostats.
objective is to inprove engine and heater operating temp.
also ideal to be able to replace stat if necesary. maybe an in hose stat? as used on some cars.
when i get a workable system, will share for others the results.
cheers Ian
Old 24-02-2011, 10:37   #8
T-Cut
Does any one know where the coolant is fed to from the filling resevoir, I suspect the engine block?
It's all explained in French Mike's image. The header tank isn't part of the circulation loop. It simply ensures that the loops remain flooded by being positioned higher than the engine. Coolant added to the header passes into the system via a T-piece in the heater pipework. Once coolant gets into the coolant flow, it never gets back into the header, other than through temperature expansion or a severe overheat.
TC
Old 24-02-2011, 10:46   #9
Mintee
Car: Rover 75
There already is a workable system that fits into the top hose - ranging from a few pounds (a Renault in-hose thermostat) to a spun aluminium housing holding a Chevy thermostat available from an American drag racing suppliers.
All seem to work well. What problem do you think needs solving?
Mintee is offline   Reply With Quote Quick reply to this message
Old 24-02-2011, 21:39   #10
djyare03
Car: ZT CDTI 135bhp
Hi.
Just like to say i have just fitted an inline stat from: http://www.specialist-components.co.uk/
and it works a treat.
They have a few listed on ebay, they an't cheap at nearly &70 (roughly) but it takes 15 mins to fit and top the coolant back up, as oppssed to the estimated 3-4 hours to replace teh original unit.
and it looks nice aswell, is a nice turned aluminium unit.
Not sure what stat it has inside but im sure its just a universal 88degree unit.
djyare03 is offline   Reply With Quote Quick reply to this message
Old 24-02-2011, 22:04   #11
calibrax
Car: MGZT+ CDTi 135
It's a 90c stat from a Chevrolet.
I had one, but never got chance to fit it. My engine died (not related to the stat or temp) and I had a replacement fitted, so I had them fit a brand new OEM stat while the engine was out. Sold my Specialist Components stat to another 75/ZT owner.
calibrax is offline   Reply With Quote Quick reply to this message
Old 25-02-2011, 08:16   #12
Mintee
Car: Rover 75
Are the Specialist Components supplying Chevy stats now? I thought they came with some shoddy 'Mini' 88C ones with some random (and pointless) hole drilled in them?
Old 25-02-2011, 11:06   #13
Mike123
Car: Rover 75
I fitted a Specialist Components inline stat a couple of weeks ago, it came with an 88C stat without any holes drilled in it. So far all works well with engine temp cycling between 86C and 96C as the stat opens and closes. Not sure if its a Mini stat or not. The car (without a FBH) still takes a good 7 miles plus to reach 88C which is a great improvement on never going above 67C during the previous couple of months.
Mike123 is offline   Reply With Quote Quick reply to this message
Old 25-02-2011, 12:09   #14
Mintee
Car: Rover 75
Why did some have holes drilled in them? That has never been answered has it?
I got idea it has a Mini thermostat in from here.
Old 25-02-2011, 12:20   #15
calibrax
Car: MGZT+ CDTi 135
No, you're right... sorry wasn't thinking straight. Mine did have a hole drilled in it, but I had swapped it over for a 91c QTH-107 stat.
Old 25-02-2011, 12:30   #16
Mike123
Car: Rover 75
[QUOTE=Mintee;4298644]Why did some have holes drilled in them? That has never been answered has it?
I think there was a concern that coolant would not wash over the wax filled sensor that operates the thermostat but it was later found that coolant leaked past (by design?) anyway so the drilled hole was slowing/preventing warm up as too much coolant was entering the radiator before the thermostat opens.
Old 25-02-2011, 12:35   #17
Mike123
Car: Rover 75
What temperatures are you getting using 91c QTH-107 stat ?
Old 25-02-2011, 16:22   #18
RoverInTheWoods
Car: 75 CDT Tourer Conn SE
I've yet to fit it, but I'm going to to use a 92C Opel unit, as it's the highest temp I could find
RoverInTheWoods is offline   Reply With Quote Quick reply to this message
Old 25-02-2011, 19:53   #19
calibrax
Car: MGZT+ CDTi 135
Like I said above, I never fitted it - as my engine was taken out of the car, I had the OEM thermostat replaced instead, and sold the Specialist Components housing.
Old 25-02-2011, 22:21   #20
Mike123
Car: Rover 75
What is the advantage of a 92C thermostat ? What running temp are you hoping for ?
How refill cooling system rover 75 cdt? bergjoce MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 13-03-2011 13:25
420 diesel cooling system bleed screw lackofgrip MG ZS / Rover 45 & 400 29 19-11-2010 16:12
75 1.8 cooling system Dean MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 03-12-2006 21:59
Cooling System Bleed Pipe - 1995 218 Diesel Turbo TD_218 Wanted 3 22-02-2006 21:52
Rover 25 45 or 75 complete exhaust system for Diesel markmediaLTD Wanted 1 31-05-2004 18:36
