Head Gasket cost on Rover 25 - MG-Rover.org Forums
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 15-03-2011, 14:46   #1
ocelot100
Car: Rover 25
hello everyone, I have an 04 Rover 25 1.4cc. I have been losing coolant regularly for last month or so. Took it to a Rover/Kia dealership near me in Hampshire today - they confirmed my worst fears that it was the head gasket that needed replacing (they said coolant in the oil confirmed this was the cause of losing coolant all the time - there were no other obvious signs of coolant leakage to my eyes). They have quoted me between 750-800 for the replacement and fixing of the problem. I thought that was a bit steep. But I didn't want to risk driving it around any longer to other garages for an alternative quote in case the gasket blows. Is 750-800 too high? Am I being taken for a mug? I don't know much about cars, but it is a well known dealership in the area so I suspect it may be higher than a normal garage but then again I want it done properly so I trust the technicians at the dealer know what they are doing,and I know dealerships always charge more. Any views on the price please would be appreciated! thanks
ocelot100 is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 16:32   #2
1955diesel
Never forgotten
Car: Other Manufacturer. Previously - more Rovers than I care to remember.
If in doubt about the head gasket failure finding, read - http://forums.mg-rover.org/showthread.php?t=243523
Replacement should include a new cam belt and water pump and should cost less than 500. A respected mobile service is often mentioned on these pages that charges less - http://www.mgroversolutions.com/#/price-list/4531823635
1955diesel is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 17:33   #3
scottish1
Car: Rover 25
got my head gasket, water pump, cambelt and tensioner replaced for 150...parts came to about 140 i think. So 800 is way steep...usually about 350-450 i reckon. Mine was replaced with MLS gasket and has been on the car for over a year (9000 miles aprox.) and is working perfectly...car did not over-heat so did not need to skim head and re-used head bolts *waits for the gasps of air*. All in all, I would beat them down to 400 for all the trimmings or take it elsewhere to a respected local garage who will know what to do anyway perfectly fine. This is only my opinion but I hope it helps you when it comes to what to ask for( MLS head gasket,cambelt(if not replaced recently)and tensioners, water pump) and how much it should roughly cost.
scottish1 is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 17:57   #4
1955diesel
Never forgotten
That is exactly what the Rover service instruction tells you to do if everything is within spec. so no need for any gasping.
Old 15-03-2011, 18:03   #5
Kelaroost
Car: MG ZR
Send a message via AIM to Kelaroost
But with a mls aren't you "supposed" to change the lower oil rail, maybe this is why they are charging so high if they are including the parts and labour for this too?
Kelaroost is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 18:50   #6
ocelot100
Car: Rover 25
thank you - this is very helpful information
Old 15-03-2011, 19:41   #7
Man in the Car
Car: 06 MG ZR+120
The price quoted is probably about right for main dealer rates. Also, if the place you took it to is an ex Rover dealership, and a current XPart service agent, they may have quoted for the route recommended by XPart and are going to fit the new Chinese mls gasket - the kit comprises a one piece mls gasket, strengthened bottom rail and higher tensile bolts and costs over 220 without all the other seals, gaskets, water pump, belts etc that they may change at the same time.
You should get a price of under 500 from an independant garage.
Man in the Car is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 20:02   #8
ocelot100
Car: Rover 25
'man in the car' thanks for that, helpful information.
Old 15-03-2011, 20:09   #9
choochoo
Car: MG ZR
I work for a engine reconditioners and alot of main dealers dont have cylinder heads skimmed we check them and advise them if is warped first but they mainly only have them pressure tested
choochoo is offline   Reply With Quote Quick reply to this message
Old 15-03-2011, 20:34   #10
scottish1
Car: Rover 25
I was scared that people would hate me for re-using the head bolts lol glad to hear you back that choice. I have never felt the need to replace the oil rail tbh, but then again, I don't know what one is :S lol I do know they use the strengthened land rover one but other than that...not a scooby lol
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Cost of replacing head gasket?!! SpiritOf45 MG ZS / Rover 45 & 400 9 02-05-2009 23:08
Rover 45 - head gasket cost!? wiganwoman MG ZS / Rover 45 & 400 10 01-02-2009 20:00
cost to repair head gasket mappy MGF and MGTF (Sponsored by MGFnTFBITZ) 12 02-11-2007 19:21
Cost of R75 Head Gasket! Jim K MG ZT / Rover 75 (Sponsored by Rimmer Bros) 26 24-04-2006 21:43
25 VVC Head Gasket Replacement cost RickJ MG ZR / Rover 25, 200 & Streetwise 19 06-01-2006 10:44
