Refitting a TF fuel pump?? - MG-Rover.org Forums
Old 16-03-2011, 18:14   #1
COPPERKNOB
Car: MG TF 160, ZR 2.0 Diesel
Is there a knack to get the fuel pump fitted back ?? it feels like theres "something in the way" its almost like the tank isnt deep enough, it pushes down on a spring but i cant get the last 15-20mm down, its all lined up correctly but just wont go?
I removed it following having Russell out today, long story which will follow once its sorted
Steve
COPPERKNOB is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 18:35   #2
kanda
Car: MG TF
http://forums.mg-rover.org/showthread.php?t=269391
Does this help mate ??
kanda is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 18:40   #3
Louie07
Car: MG TF Sprint SE 2003
Steve
I have never fitted a new pump, but i hope this page from the manual helps:
Louie07 is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 18:42   #4
g7nbp
Car: MGF
If its anything like the one on the frontera you need a (non-pc alert!!) fat bloke to sit on it while you get the first turn on the thread. Fine after that.
(Always a good idea to ask the fat bloke to put his cigarette out as well - another long story for another time)
g7nbp is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 19:17   #5
CJJ
CJJ's Avatar
Car: MGTF 160, TF LE500, Nissan Leaf, KTM 640, Kangoo Van, Freelander
He he.
I had a car in a garage once and they were looking for a fuel leak under the bonnet and they were both smoking.
Neadless to say I went for a walk, half expecting to see a small mushroom cloud appear behind me.
CJJ is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 21:15   #6
MGFmad
Never forgotten
Car: Astra CDX auto, Freelander TD4 & Freelander 1.8, Mini One
Send a message via MSN to MGFmad
I did one on a Freelander which uses the same removal tool (although I didn't have it) so its possible the same arrangement applies. I refitted the rubber sealing ring onto the pump body then tried to fit the pump back in but like you could not get it down far enough to lock. The way I found to do it was to put the rubber sealing ring into the pump hole in the top of the tank then slot the pump in, fitted perfectly after that.
Hope this helps
MGFmad is offline   Reply With Quote Quick reply to this message
Old 16-03-2011, 21:20   #7
COPPERKNOB
Hope this helps
Cheers people
I think the sealing ring is the problem so i'll give that a go tomorrow, at the moment its on the lid but i'll swap it over and fingers crossed it'll go
Old 17-03-2011, 20:22   #8
COPPERKNOB
MGFmad ( sorry i dont know your name ) you are a genuis
I put the seal on the opening and the pump popped in first time and screwed up straight away, Thanks for the tip
Steve
Old 21-03-2011, 21:49   #9
MGFmad
Never forgotten
Steve
Glad you got it fixed
David
Old 21-03-2011, 21:55   #10
MGF Madman
Car: 1997 MGF 1.8mpi, 2001 MGF Trophy 160, 2011 Renaultsport Clio 200
I did mention about the rubber ring in the how to about it should sit on the fuel tank - suprises you how something as simple as that can stop you from fitting them lol
MGF Madman is offline   Reply With Quote Quick reply to this message
Old 26-11-2013, 15:32   #11
freeflyjohn
Car: MG TF
Smile Fuel Pump.
Good advice! Especially the bit about putting the seal in the tank first. Thanks.
freeflyjohn is offline   Reply With Quote Quick reply to this message
refitting oil-pump sony606 Rover 600 0 02-12-2009 13:29
Fuel pump sensor - new fuel pump? martinofmoscow MG ZS / Rover 45 & 400 1 05-08-2008 15:19
Sdi fuel pump to Newer ZS L series pump matt_mph Diesel Forum! 8 28-07-2008 07:52
MG TF Fuel pump Green_ninja MGF and MGTF (Sponsored by MGFnTFBITZ) 1 09-05-2007 15:24
r45 - testing the fuel pump outside the fuel tank? goranp MG ZS / Rover 45 & 400 1 17-08-2004 12:25
