Clutch pedal high - possible adjustment? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 21-03-2011, 16:24   #1
barhopper
Car: Rover 200 SDi
Hi all,
Ever since I have had my 22sdi it's always had a high clutch pedal which often makes pulling off a little jerky which is rather annoying. Is there any adjustments that can be made to help?
Cheers,
BarHopper
barhopper is offline   Reply With Quote Quick reply to this message
Old 21-03-2011, 19:14   #2
crizd
Car: ZS+ MKII TD
Someone sells an adjustment kit on here, bet he'll be on in a few mins. I think they are for the 400/45/ZS tho, not sure about your model.
crizd is offline   Reply With Quote Quick reply to this message
Old 21-03-2011, 20:11   #3
Shuntis
Car: 53 MG ZT-T CDTi
AFAIK 400/45/ZS have hydraulic clutches, 200/25/ZR have cable clutch.. could be due a new clutch cable?
I could be wrong
Shuntis is offline   Reply With Quote Quick reply to this message
Old 21-03-2011, 20:52   #4
E_T_V
Car: Maestros, 200, 600, ZTT
If it was low it'd need a clutch cable. High clutch cable may just need resetting (its self adjusting I think).
E_T_V is offline   Reply With Quote Quick reply to this message
Old 23-03-2011, 09:34   #5
barhopper
Car: Rover 200 SDi
I will have a look at the weekend, I have never had a good look at the cable so will see what I find. Would be nice if I could make an adjustment only if it was a very minor change. It drives me nutty at times lol.
Old 24-03-2011, 20:30   #6
dazzer75
Trader Supporter
Car: MG ZR
The clutch cable casing on mine was starting to fail and causing the pedal to feel sticky at points so I got a new cable .When you have removed the old cable there is a bolt with a lock nut on just above the pedal box that can be adjusted to lower the pedal then attach the new cable and it will set itself and your pedal will be lower.
dazzer75 is offline   Reply With Quote Quick reply to this message
Old 24-03-2011, 21:41   #7
adamkdeejay
Car: trophy
i done mine with out touching the bolt at the top dammmmd bolt pinged off
adamkdeejay is offline   Reply With Quote Quick reply to this message
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Clutch pedal adjustment cult88 MG ZS / Rover 45 & 400 6 24-06-2009 08:35
CLutch pedal adjustment Bubble_jon MG ZR / Rover 25, 200 & Streetwise 1 19-07-2008 14:03
Clutch Pedal adjustment Paul M MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 30-07-2006 19:20
Clutch pedal adjustment?????? lancylass Others 0 07-05-2005 09:27
ZR clutch pedal adjustment Philip40 MG ZR / Rover 25, 200 & Streetwise 1 01-11-2004 18:11
