Mgf vvc 1.8 1997 - MG-Rover.org Forums
Old 12-05-2011, 16:09   #1
talkabouthorses
Car: MGF
Send a message via MSN to talkabouthorses
Mgf vvc 1.8 1997
hi i have brought a mgf rebuilt the engine and replaced loads of parts including brake disc pads and cat plus back box, she runs lovely, i have no however go a smell of fuel in the car i have checked all the pipes in engine and the smell seems worst when its been stood once you have doors open and closed and running the car it goes away a bit, been told there is a hose from fuel filler cap to tank that perrishes and causes smell in the interior does anyone have any ideas or has had same problem xx
talkabouthorses is offline   Reply With Quote Quick reply to this message
Old 13-05-2011, 16:47   #2
xboxdevil
Car: 1996 mgf vvc
Lifted straight from Dieter's site:
- rework the rubber hose under the brown gaiter between tank and filler pipe if it's kinked
- change the cheap clamps at that rubberhose to jubilee clamps
- change the green coloured cheap clamp at the fueltank sender unit hose to a jubilee clamp
- check the large sealing of the sender unit (tank to sender body)
- check whether there is a non return 'flap' installed inside the filler pipes lower end.
- check the screws of the fuel tank cover plate behind the seats on the right torque. Screws should be tightened starting from the centre to the outer.
- remove the tank cover plate behind the seats and re-align the white coloured shredder between the tank and the cover plate.
- add a self adhesive foam tape if the existing sealing material is not placed right.
See here http://www.mgfcar.de/fueltank/index.htm for more info.
xboxdevil is offline   Reply With Quote Quick reply to this message
Old 14-05-2011, 10:39   #3
talkabouthorses
Car: MGF
you are a star will be doing list today, have ordered a new ruer hose that goes inside the gator just in case it has perrised not looking forward to taking the panel off from back of seats but never say i dont have a go lol ta muchly have a great weekend xx
Old 14-05-2011, 10:46   #4
xboxdevil
Car: 1996 mgf vvc
Good luck, I hope you get it sorted :-)
cheap back box mgf vvc 1997 spidercrab Wanted 0 27-03-2011 21:34
1997 mgf with vvc engine COUGAR55 MGF and MGTF (Sponsored by MGFnTFBITZ) 6 26-03-2011 03:07
For Sale 1997 1.8i VVC MGF - Very Low Miles & Owners (1997) claire86 For Sale 3 01-02-2009 18:53
MGF VVC - 1997 R Reg Brooktop For Sale 1 29-03-2005 13:11
1997 Mgf 18 Vvc Greg-Richards MGF and MGTF (Sponsored by MGFnTFBITZ) 9 24-04-2004 21:13
