Cv Joint Gaiter Split MG ZR - MG-Rover.org Forums
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Old 20-05-2011, 23:23   #1
coollg
Car: 2003 MG ZR TD +(100) Trophy Blue
Hi Guys,
Took me alloy wheels off today to have a go at fitting mg zr side skirts(didnt go well).
I noticed there seems a lot of like think black oil round the inside of my alloy wheel. I then looked behind the wheel hub to find the front passengerside cv boot gator has split and obv lost most of its oil. Want to get this fixed asap to avoid problems with the actually CV joint , not noise of symptoms atm
How much should a garage charge to fix this , my freind reckons about 50 all in.
This is on a MG ZR Td 52plate
Many Thanks Lee
coollg is offline   Reply With Quote Quick reply to this message
Old 20-05-2011, 23:26   #2
Popeye 89
Car: MG ZR160
Send a message via MSN to Popeye 89
do it yourself
for 20 at a motor factor you can get a split gaitor kit with adhesive and grease with 2 new clamps. takes about 10 mins. just cut the old one off, pack the joint with grease and wrap the new one on
Popeye 89 is offline   Reply With Quote Quick reply to this message
Old 20-05-2011, 23:27   #3
coollg
I Would do that but I the best i can do is get a wheel off, my dad is fair tool friendly same with a couple of friends.
Do u have to take anymore more then the hweel off?
Old 20-05-2011, 23:29   #4
Popeye 89
Car: MG ZR160
if you can get to it with the wheel off, then no
Old 20-05-2011, 23:29   #5
BLMC
Car: -
Originally Posted by coollg View Post
Hi Guys,
Many Thanks Lee
A new CV boot is 5.70 @ Rimmers so 50 sounds about right.
BLMC is offline   Reply With Quote Quick reply to this message
Old 20-05-2011, 23:31   #6
coollg
Ok i think for ease and obv a perminate fix( as im not mechanicaly minded) should be about to get for 50 or less. Guy im gonna try is a small independant garage since like the 1980s , he did my headgaskt on my r200 last 18k miles before i sold it did the job for 375 all in. So guess he may be ok
Old 20-05-2011, 23:32   #7
BLMC
Car: -
Where are you ?
(Put your location in your user cp)
Old 20-05-2011, 23:33   #8
coollg
O sorry im in southend essex east from london
Old 20-05-2011, 23:39   #9
Fast Alan
Car: Rover 200 BRM LE No.73 & No.1 Press car
Send a message via MSN to Fast Alan
Yes have it done properly ,split cv gaitors will nearly always fall apart again
Fast Alan is offline   Reply With Quote Quick reply to this message
Old 20-05-2011, 23:43   #10
coollg
think ill get fixed now jsut at garage n hope its around 50 , then i may get a haynes manual then have a looky ect get ideas ect.
Old 20-05-2011, 23:46   #11
Fast Alan
If you could do it yourself,you can buy whole joints plus the gaitor etc for less than 20 pounds and you have got rid of the old rusty abs ring into the bargain
Old 21-05-2011, 00:02   #12
coollg
If only i could haha
Old 21-05-2011, 00:13   #13
Fast Alan
being in Southend you can always wander to our monthly meet at the halfway house and talk first hand to members
http://forums.mg-rover.org/showthrea...22#post4452822
One on Sunday
Old 21-05-2011, 00:21   #14
coollg
You see i wish i could but i work till 5.30 on a sunday which sux
Old 21-05-2011, 00:30   #15
Fast Alan
Ahhh never mind (always looking for new members ) good luck with the joint shouldnt be much at most decent garages and if you feel confident just a couple of big nut and a lever to get the hub away.
Old 21-05-2011, 09:24   #16
wdavison
Car: Rover 25
dont use split boots these are crap i always use stretchy boots that just stretch over and secure with big clips. just as easy and a much better fix.
wdavison is offline   Reply With Quote Quick reply to this message
Old 21-05-2011, 09:27   #17
Stu
Administrator
Stu's Avatar
Car: Saab 93 Vert + Alfa Mito Turbo
Send a message via MSN to Stu Send a message via Skype™ to Stu
Agree with the people suggesting not to use a split gaiter.
They are good for a stop gap of a few weeks to stop dirt getting in until you can do it properly. Thats about it.
__________________
Stu
Get cash back on your Insurance and many other web purchases through Quidco
Stu is offline   Reply With Quote Quick reply to this message
Old 21-05-2011, 10:03   #18
coollg
Well first quote formula one- 115.84 , with wheel alignment , was half hours labour or summin
Old 21-05-2011, 11:12   #19
coollg
Any have a fitting guild for summin for the gautior , bought a haynes manual. Says about removing the drive shaft ect this sound right? Bought the boot kit and ball joint splitter.
Getting dad to do it whos mechanical knowledge is he has built a kit car
Old 21-05-2011, 11:31   #20
Ricky146a
Hobbyist
Car: MGF 1.8i and Volvo C70 Convertible plus a boat that is a moneypit
Study chapter 8 (driveshafts ) and chapter 10 (suspension and steering). If you also look at your car whilst reading them it will all become clear.
Not a difficult job but make sure the car is very well supported.
Good luck and come back to us if you have any problems.
Ricky146a is offline   Reply With Quote Quick reply to this message
How much to repair (in garage) a split cv joint gaiter on a ZR?? robmal123 MG ZR / Rover 25, 200 & Streetwise 1 11-06-2010 06:34
CV Joint gaiter & Lower trailing arm bush repairs. aknot 'R8' Rovers (aka Wedges!!) 3 03-05-2009 08:34
Any experience in fitting a split CV joint gaiter ? wilson21 Rover 800 13 07-11-2007 22:32
Replace cracked/split reluctor ring in CV Joint chudofbroady MG ZS / Rover 45 & 400 11 28-02-2007 21:05
CV joint gaiter replacement without removing driveshaft? BrianR 'R8' Rovers (aka Wedges!!) 10 27-06-2004 17:20
