#1 |
vvc vvt v-tech
Why does the toyota vvt-i produce more power than the vvc with the same cc? I'v heard of the lack of time to fix gliches in the vvc but what are they and can they be over come? oh and just a tought i'v heard that 200bhp is about the highest power you should go in a k-series(?) but 214bhp would be true to the 160 name (in kw that is
)thanks John |
#2 |
Administrator
Peak HP isn't the answer to it all though.
The 160bhp K series in the elise is as quick as the VVT they are also using. And from speaking to the testers is a better all round package than the VVT. |
#3 |
isn't vvc supposed to be more advanced than v-tech, but wasn't developed to its full potential due to B*W?
#4 |
Administrator
Swings and roundabouts really. VTEC is more reliable, VVC is probably more advanced, but is certainly more complicated and expensive to produce.
#5 |
I heard about the vvc having more potential but due to damage to the cams it wasn't tuned further? i thought that v-tech did something to the timing that vvc didn't?
#6 |
Car: MGF
VTEC please, it's not a childs computer.
Brian. |
#7 |
Car: Other Manufacturer
Hehe!
Me not guilty this time Brian!
#8 |
The difference is fundamentally one of timing.
As i understand it the VTEC / VVTi systems work with a pair of interchangeable cam lobes that switch at a fixed point on the rev range. Basically you get reasonable performance and good economy at low revs, but when the cam lobes switch the timing and duration of the valve opening alters allowing more fuel into the combustion chamber and thus more power is released (at a trade off in fuel consumption). These systems are simple and durable, but from a drivers point of view thay can feel a bit 'all or nothing' in a similar way to a turbo'd engine feels when driving normally and then on boost. To be fair the technology has come along a bit these days and the 'mild cam' driving experience is still reasonably quick. VVC on the other had is a quantum leap forwards, but like everything Rover develop, is a great idea but the execution has suffered a bit. Unlike the VTEC/VVTi systems described above, the VVC only has one cam lobe profile per inlet valve but the clever part is in the rotation of the cam shaft. There are 2 epicyclic <sp?> drive gears at each end of the head, each one is responsible for driving 2 camshafts, a half length shaft, with lobes on the far end, and a quarter length shaft that is slotted onto the end of the half shaft. A bit like a hinge pin if you know what i mean. Basically this means that the VVC head has five camshafts, a normal full length exhaust cam (2 valves per cylinder x 4 cylinders = 8 valves / 8 cam lobes), 2 inlet half shafts and 2 inlet quarter shafts (1 cam shaft per cylinder with 2 cam lobes on each. 2 valves x 4 camshafts = 8 valves / 8 cam lobes. 8 inlet valves + 8 exhaust valves = 16 valves). Now you know why VVC is also known as Very Very Complicated! Anyway the trick here is as i said, 1 camshaft per cylinder and each one is independantly driven through a set of gears which varies the timing of the shafts rotation, slowing and speeding it up to produce different valve open durations. Because the system is gear driven the cam timing is infinitely variable within an upper and lower limit and thus there is no fixed point at which the cams switch, they are 'on cam' all the time to a greater or lesser degree.This is the VVCs great advantage, and also it's weakness. Because the rotational speed of the camshaft is speeding up and slowing down per revolution to provide greater valve opening times (slow shaft speed) and shorter intervals between openings (fast shaft speed), the cam lobes wear a lot faster than in a normal engine. Rover had great problems resolving this and because the VVC F had a fixed introduction date, they basically ran out of development time. Rather than solve this mechanically they simply 'de-tuned' the engine management system so that the VVC was running within safe perameters. This is why the VVC produces less bhp than the other systems, to use a computer analogy, it is running in 'safe mode'. This would have been OK if it wasn't for BMW then putting the kibosh on the F development programme (including the VVC mechanism) until they sold the company to MGR. Basically the VVC mechanism was supposed to had post development to resolve the issue and release it's full potential but it didn't happen during BWMs tenure. I heard that there was a lot of work going on in this area since the buy out but these are only rumours and have yet to be proven. I did hear that K2000 had caused the VVC development project a bit of a hiccup though, K2000 has a different head to the other K4 engines and thus the VVC technology isn't directly transferrable, VVC K2000 is a goal they want to achieve and thus the programmes were merged, again another rumour. The last i heard they were looking at different metals and facings for the cam lobes and experimenting with different 'hotter' maps but this was over a year ago now and i have heard very little since. Anyway, this is my understanding of the situation.
__________________
Andrew Phillips MGF Register Committee - Archivist & Registrar MGF 'Scarlet Fever' MG ZT260 'old #27' |
#9 |
Good explanation Andrew but not quite accurate
, the VVC is not engaged all the time but is controlled by the hydraulic controller when certain parameters are met,RPM/oil temp.To my knowledge there has never been an issue with VVC cam wear and I have never seen any 'worn out', in fact the materials used are very high quality. With regard to further tuning of the VVC cams it would be possible to make higher lift and revised profile cams and IMO the actual VVC mechanism would be capable of the extra work. I have heard of a tuning company producing 210BHP from the VVC engine by this method. For the standard engine to remain 'reliable' at this level of tuning then other mods would have to be done, probably one of the reasons why this has not been done for the production engines. Maybe a VHPD bottom end and a VVC with modified cams would work
#10 | ||||
![]() Quote:
I quote from the article 'KingK', by Simon Erland Quote:
__________________
#11 |
__________________
#12 | |
Location: London Car: MGF and MG ZT-T (also Mk3 Triumph Spitfire and Mk1 Austin Mini)
Cam lobe wear is the problem I'd heard of Mike. Piper were attempting to develop alternatives - as you probably know - but nothing materialised from it.
The other problem with the VVC at high engine speeds has nothing to do with the crankshaft - but rather with harmonic vibrations within the VVC cams - which build, if what I've been told is correct - quadricatically. The whole mechanism is very likely to fall apart if reved beyond 8k... ![]() I guess the lack of cam lobe wear on the VVCs out there could have a lot to do with the conservative grind that Rover/BMW decided to launch the engine with? Quote:
Perhaps when S&R announce the engines for the ZRX and TFX we'll get an answer for this... |
#13 | |
![]() pretty much how i see it, i read about it on the dutch sd1 owners site soon after i got my vi. v-tec - 2 settings vvc - infinately variable. bear in mind honda engines and toyota engines are far better (imo) than rover's, hence the higher power out puts of the vvti and b18c, but only rover have been able to make vvc work... after all its a 1970's concept. Col |
#14 | |
rich |
#15 |
childs computer???
#16 |
Administrator
V-Tech make childrens toys.
Far more complex than the VTECH in most cases
#17 |
#18 | |
he he seriously though Andrew does "It is a similar story for the flywheels measured" mean that you can't use aftermarket flywheels too or that they vibrate too? on that point doesn't ptp have a lightend flywheel for the k-series? (wow nice explanaition). is there anybody who has reliably "tuned" the vvc and at what cost? |
#19 |
The VTEC most talk of was designed 14 yrs ago and cracked 100bhp/litre then as std. Variable lift yes please.
#20 |
is ivtec different?
| Bookmarks |
| Thread Tools | |
| Beaten by a 1.0 Yaris VVT-i | Spawney | Others | 44 | 10-12-2005 15:12 |
| 190bhp engine. VVT-i | Griffo | For Sale | 16 | 28-09-2004 20:36 |
| VVC, VVT and VTEC | petrakak | Others | 1 | 29-08-2004 22:03 |
