mg6 200bhp? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > MG 6 (Sponsored by the MG Car Club)
Old 05-07-2011, 16:10   #1
jaffo
Car: Saab 93 aero sportwagon ttid 180 & mg zr trophy se
mg6 200bhp?
158bhp seems quite a conservative figure for such a well balanced and great handling car as the mg6 and i wonder how much potential there is for mild tuning of the engine(i.e chipping it) to take it up around 200 bhp which would match the octavia vrs?
i wouldnt of thought that a fairly mild extra 40 bhp wouldnt be difficult to attain and would still leave decent reliability and economy?
jaffo is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 16:23   #2
david87
Car: 07 Saab 9-3 estate TiD, 08 Focus St-2 (asbo orange ftw)
i wouldnt of thought that a fairly mild extra bhp wouldnt be difficult to attain and would still leave decent reliability and economy?
i'd imagine the current figure is an insurance thing, given its low cost is one of the things the mg6 has going for it
though there is the 2lt to come, look to that and hope
david87 is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 16:37   #3
jaffo
i was sort of thinking post purchase......
Old 05-07-2011, 16:49   #4
Phil
Car: CityRover
You won't get a huge increase by chipping it, petrols don't respond to fuelling changes like diesels do. It'll add 5 maybe 10bhp at the very most.
The only way I can see of getting that much from this engine is by fitting a bigger turbo, but given that it's based on the K series there's always that HG issue (even though we've been assured it's been sorted).
Phil is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 16:51   #5
jaffo
i would agree with a naturally aspirated engine but the 6 is turbo charged and as such there will quite a large potential for extra power there....even with a lpt turbo(and im not sure what type is in the 6)...
Old 05-07-2011, 16:53   #6
great_kahn
Car: Focus
Its a turbo petrol, compleltely different story to a nasp petrol.
Did some reading on the low pressure turbo 1.8 k series, seems 180bhp was realistic figure. Imagine MG6 would be similar.
great_kahn is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 18:14   #7
radion_auto
Asteroids Champion!
Car: MG ZR 160TDi
Send a message via MSN to radion_auto
Totally agree GK. Force-fed gassers should have plenty of tuning potential. If you compare to the old 1.8K turbo, that has been taken to about 190bhp i believe. This new engine is apparently much stronger, at least in the gasket area, although the pistons etc are an unknown quantity.
I bet it would be rock solid at 180bhp at you suggest, a simple remap from your friendly local remapper should do it
radion_auto is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 22:07   #8
Peterover
Car: Rover Streetvan: Gimp. MG TF 115 Sunstorm: Rosie. Smart Roadster: Rodie
The current engine in the MG6 will disapear late next year, when its replaced with the new petrol and diesel units. IIRC
Peterover is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 22:36   #9
Stevo135+
Car: Other Manufacturer
You could quite probably take the latest K-series/N-series or whatever it's called this week, up to 200bhp with the right mods and enough mods. Im not thinking of a simple re-map with more boost as we know that:
1, VVC160 pistons were the basis of the factory K-turbo, and they are not happy much over 180-190bhp long term.
2, The non VVC head is very restrictive on the 1800cc engine, and with the turbo this is going to be even more of an issue breathing wise.
A full turbo back 2.5" de-cat exhaust, panel filter and a bigger I/C would be my first mods to an MG6. Then id look at seeing what potential there is in the std ECU for re-programming. I suspect that it's going to be far less tunable than MEMS3 if at all?
I'd also look at flowing the head, and porting the inlet ports to match a VVC inlet manifold and 52mm throttlebody to the head. There is probably some improvements to be made with porting and port matching the turbo exhaust manifold too.
We have to assume that the old K-series VVC head cannot be bolted onto the new engine, and they don't use this head for the new engine's which is a shame as it would have added about 15-20bhp at the same boost level as std!
If all the above were done to an MG6 engine, then as per the old K-turbo's you could be looking at 200bhp at close to std boost levels and using the std turbo. Putting a bigger turbo on would definately help push past 200bhp if you could tune the ECU, and could accept a big more lag and a slightly higher boost threashold.
Stevo135+ is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 06:45   #10
forehead
Car: Rover 75
170hp diesel would be a better seller and miles more fun than a 200hp petrol.
Concentrate on sellers not niche.
forehead is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 10:42   #11
Smoggie
Car: MG6
I believe they are doing both. Nothing wrong with that.
Smoggie is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 11:37   #12
MalcQV
Nahh the petrol will be the true petrolheads car. Diesels are for ploughing fields and shifting farm animals
MalcQV is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 11:45   #13
great_kahn
Car: Focus
Indeed.
Old 06-07-2011, 11:47   #14
MalcQV
Indeed.
It has the scoop on the front ready to lift the dung.
Old 06-07-2011, 11:53   #15
lordpercy
Car: Rover 75 connoisseur SE 1.8T auto
i personally think you will not get much xtra power out of this engine, and what you would spend is just not worth it.
lets face it, it base based on the euro4 development ZT's k series etc (contrary to what they say), same power/torque etc
and even with the HG sorted it still is to me quite a fragile engine.
and how many of us owners have got anything more out the ZT 1.8T, a bet not even a handfull.
might even be cheaper to fit a ZT V6...would it fit on the engine mounts?
(are the 1.8 and 2.5 mounts the same?
lordpercy is offline   Reply With Quote Quick reply to this message
Old 06-07-2011, 11:57   #16
great_kahn
Car: Focus
Hopefully the new 2.0 petrol they are developing will be stronger. 2.0 TFSI VAG unit can handle 400bhp on stock internals. That is what they should be aiming for.
Get some serious power going to match the chassis and handling
Old 06-07-2011, 11:57   #17
great_kahn
Car: Focus
Ooooh arrrr.
Old 06-07-2011, 13:26   #18
radion_auto
Asteroids Champion!
Car: MG ZR 160TDi
Apparently its a completely new development, albeit based on the K series design. I'd put money on it being able to handle 180bhp, with a fairly modest investment.
Much as i love the V6, it's a thirsty engine and still only 190bhp after all the money spent on the conversion. Plus the engine has little tuning potential.
the N-turbo-kavachi-tech-tech etc etc can't be any less tunable than the 1.8K turbo surely...?
Old 06-07-2011, 15:52   #19
jaffo
i was actually thinking that 250.00 of tuning box/chip to make an easy 180/190bhp would be an attractive route to go down,not a factory special or a 400 bhp tinderbox.....just a little more go which would be nice and probably not do the economy much harm either......
Old 06-07-2011, 16:20   #20
forehead
Car: Rover 75
Indeed and I'd bet you know which would be the bigger seller.
I'd estimate at least 5:1 if not as much as 10:1
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
how can i get 200bhp out of my 25 jonesy89 MG/R Modification & Tuning 141 04-11-2012 06:08
200bhp Tf!! simon-g MGF and MGTF (Sponsored by MGFnTFBITZ) 24 01-08-2008 13:44
VI to 200bhp manick MG ZR / Rover 25, 200 & Streetwise 59 18-08-2007 13:26
Quest to see if 200BHP + is possible? Gravitypilot Diesel Forum! 24 02-06-2007 21:13
200BHP 1.8i SHARKYMGF MG/R Modification & Tuning 10 05-08-2003 16:11
