Rover 25 heater blower fan not working - MG-Rover.org Forums
Old 07-07-2011, 08:35   #1
Diesel011
Car: Mg Zr 160
Recently my blower fan stopped working, so I replaced the resistor unit behind the glovebox thinking that may be the problem.
But still nothing, I am thinking it may be a wiring problem or electrical as I have also lost power going to my cigarette lighter socket.
I have checked all the fuses in the car and they are all fine, it must be the 12v+ feed that is not coming to the fuse box but I am not sure where to trace this.
Diesel011 is offline   Reply With Quote Quick reply to this message
Old 13-08-2011, 18:09   #2
Xstream
Car: Rover 400 (95-99)
I've just had this happen to me did you fix yours?
Xstream is offline   Reply With Quote Quick reply to this message
Old 13-08-2011, 18:16   #3
Popeye 89
Car: MG ZR160
Send a message via MSN to Popeye 89
mine was like this. easy fix for meee
firstly check all fuses related to the heater fans
then....what i did anyway
pulled the blower motor out (non aircon) cleaned the connection on the plug, cleaned the crap outa there and plugged it back in and it worked.
its one of 4 things. blower motor, fuse, wiring, control panel
Popeye 89 is offline   Reply With Quote Quick reply to this message
Changing heater blower, rover 25 pompey_jack MG ZR / Rover 25, 200 & Streetwise 2 10-04-2010 06:31
02 Rover 45 heater blower not working karltf MG ZS / Rover 45 & 400 0 10-11-2009 11:59
Rover 75 internal fan heater blower stuck on full! Stratus Introduce yourself 2 24-02-2009 19:04
Problem With Rover 220 Heater/Air Blower Not Working majestic MG ZR / Rover 25, 200 & Streetwise 6 17-07-2007 19:40
Rover 214 (R3) - 1998 - Heater Blower not working on 1 and 2 nicksouthorn MG ZR / Rover 25, 200 & Streetwise 4 08-11-2006 21:55
