#1 |
Car: Rover 45
Hi All
My Rover 45 has jus had a transplant, New head gasket well all gaskets, thermostat,New cam belt water pump temp switchs, runs fine BUT temp gauge only go's up to 1/3 & cooling fan wont come on, thermostat does not seem to be opening.
Need HELP PLEASE?
| Sponsored Links | |||
Advertisement | |||
#2 |
the temp on my ZR only ever gets to just under half, and until recently i was wondering if the fan worked (it does... quite regular now
)when it is idling in the drive (or wherever it lives) have the bonnet up and feel the hoses to the radiator, one will warm up slowly, then as the thermostat opens the hot water will rush through and heat the other pipe. if your cooling system is working properly the fan probably won't kick in at all. btw
__________________
![]() chasing spiders |
#3 |
Car: Rover 45
Hi
The top hose is getting very hot but the bottom one is just warm, I run it for 15 mins or so, Just dont want to blow head again took me 3 days to change lol.
Cheers |
#4 |
so it's had HGF... did you flush the coolant system? could be some leftover milkshake in there somewhere.
__________________
#5 |
MG-Rover Mobile Mechanics
Location: Derbyshire Car: MGF x6, MGTF x4, MGZS x4, MGZR x5, MGZT x2, 93' CELICA, Recovery Truck x2
if the thermostat was stuck shut it would overheat...
if the thermostat was stuck open it would sit low on the temperature gauge... radiator could be blocked... but again that would make it overheat not sit low on the temp gauge... or it could be that the temperature sensor is knackered x (might be worth trying another thermostat first).
__________________
** We specialize in Cylinder Head Gasket replacements & Engine Re-conditioning! ** -- Our Head Gaskets are £275 non vvc and £305 vvc -- ... All Head Gaskets are inclusive of the Cambelt & Waterpump ... ~ We can guarantee you won't find anyone offering the services we do, at the prices we do! ~ ' Courtesy cars available to use during the work process via pre-booked appointment ' * See www.mg-rovermobilemechanics.com or call/text 07595708278/07595704340 for more info *
| Bookmarks |
| Thread Tools | |
