Oil in the coolant but no water in engine oil! - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 30-07-2011, 19:13   #1
Logix_00
Car: Rover 400 GSDi (2.0 Turbo Diesel)
The car seems to be running fine but I'm assuming that it wont last long. I changed the back box this week as the short pipe b4 it had a number of holes in it and I go do a few checks this weekend and find my water reservoirs has oil mixed in with it! I thinking oh ***** head gasket but I check the dip stick and top up point and its still black oil in there! Could it be that I overfilled the oil a while back?
I completely drained the cooling system and refilled her, took her for a blast and the oils back in the top reservoir! While draining the system I took off a few pipes and noticed that there was a little oil also in the pipe that leads to the turbo cooler!
I just don't know what it is, any suggestions!
Logix_00 is offline   Reply With Quote
Old 30-07-2011, 19:32   #2
bobbybrown
Hobbyist
Car: 220SDI R REG
If you have oil in the coolant it won't be because you overfilled the oil before, it could be the head gasket as you say.
bobbybrown is offline   Reply With Quote
Old 30-07-2011, 19:48   #3
**Kayleigh**
MG-Rover Mobile Mechanics
**Kayleigh**'s Avatar
Car: MGF x6, MGTF x4, MGZS x4, MGZR x5, MGZT x2, 93' CELICA, Recovery Truck x2
Send a message via MSN to **Kayleigh**
oil getting into the water.... could be head gasket failure.
__________________
** We specialize in Cylinder Head Gasket replacements & Engine Re-conditioning! **
-- Our Head Gaskets are £275 non vvc and £305 vvc --
... All Head Gaskets are inclusive of the Cambelt & Waterpump ...
~ We can guarantee you won't find anyone offering the services we do, at the prices we do! ~
' Courtesy cars available to use during the work process via pre-booked appointment '
* See www.mg-rovermobilemechanics.com or call/text 07595708278/07595704340 for more info *
**Kayleigh** is offline   Reply With Quote
Old 30-07-2011, 19:49   #4
Dakta
Diesel ECU Tuner
Dakta's Avatar
Tower Defence War Champion!
Car: 420 SDi, ZR TD
Send a message via MSN to Dakta
or oil cooler failure?
__________________
I thought the diesel was limited in upper RPM power because the fuel burns much slower than gas. Is this true?
Yeah, there's really no point to rev over 7000.
Dakta is offline   Reply With Quote
Old 30-07-2011, 20:12   #5
bobbybrown
Hobbyist
Car: 220SDI R REG
Indeed but which is more likely?
Then again, I haven't heard of a great number of L series suffer from head gasket failure in their standard form.
Old 30-07-2011, 20:13   #6
Dakta
Diesel ECU Tuner
Dakta's Avatar
Car: 420 SDi, ZR TD
I don't know. I just wanted to stir the bowl.
I'd hate to say 'HGF' when there's an equally corrodable alternative explanation. Of course, the HG could be shot but from what we see on here people's coolant tanks tend to a-splode.
__________________
Old 30-07-2011, 21:11   #7
E_T_V
Car: Maestros, 200, 600, ZTT
It is a LOT more likely to be oil cooler failure, as HGF almost always leaks combustion gases into the coolant.
Oil cooler failure is rare though, but not unheard of.
E_T_V is offline   Reply With Quote
Old 30-07-2011, 21:29   #8
bobbybrown
Hobbyist
Car: 220SDI R REG
hmmm, valuable info there, nice one
You may not post replies
Removing Oil/Water Mix from coolant pipes and engine Markt8 MG ZR / Rover 25, 200 & Streetwise 4 27-09-2010 20:36
Please Help. Sludge In Oil Tank. Engine Coolant Water Always Low. SebUK MG ZS / Rover 45 & 400 3 23-02-2008 22:54
oil in water coolant bluefish MG ZR / Rover 25, 200 & Streetwise 10 22-07-2007 13:50
