Rover 400 diesel. - MG-Rover.org Forums
Old 14-12-2011, 00:37   #1
seand1986
Car: Rover 400 SEi D
Exclamation Rover 400 diesel.
Hi guys. New here. Own a rover 400 diesel, year 2001. Replaced a sticking thermostat today thinking it would cure my heater problems. Alas I'm no further on. I can feel heat at the vents but there is next no no air coming out. My blower only works on setting 3 and 4. I wouldn't mind that if anything came out lol. What could be blocking the airf anything at all? Answers appreciated please.
seand1986 is offline   Reply With Quote Quick reply to this message
Old 14-12-2011, 15:27   #2
Aries1604
Car: Rover 45 KV6
The heater resistor pack has failed, so the heater fan is not working on lower speeds. Common problem, easy fix.
Either buy this:-
http://www.ebay.co.uk/itm/NEW-MG-ROV...item1e671438fa
or this:-
http://www.ebay.co.uk/itm/Rover-Heat...item1e6931d5c0
depending on your ability.
Edit/ Missed the fact that nothing is coming out even on 3 and 4. As Chrisund123 says below, you have probably do have a blockage, so clear that first, as this could be the cause of the resistor pack failure.
Hope that helps.
Aries1604 is offline   Reply With Quote Quick reply to this message
Old 14-12-2011, 15:30   #3
Chrisund123
Car: 45 2.0 Diesel
If the blower operates on 3 and 4 but no air comes out then is say you have a blockage - check the easy bits first and drop out the blower motor and pollen filter - you'll be working down there anyway of you're replacing the resistor pack!
Chrisund123 is offline   Reply With Quote Quick reply to this message
Old 14-12-2011, 15:31   #4
Alfie63
Car: Rover 45
I went for the bottom option. Need to have a soldering iron, but a quick 30 minute job to get it all working
Alfie63 is offline   Reply With Quote Quick reply to this message
Old 14-12-2011, 20:56   #5
seand1986
Thanks guys. Removed the pollen filter and hey presto it's blowing great now. Don't think it's as warm as it should be mind you. Might have to bleed the system. Had my therm replaced yesterday and in wondering if there is still some air that needs to work its way out.
Old 14-12-2011, 22:52   #6
Rover_King
Car: Rover 45 1.8 Connoisseur
They stopped producing the 400 in 1999/2000. Is yours a 45?
Rover_King is offline   Reply With Quote Quick reply to this message
Old 14-12-2011, 23:47   #7
seand1986
Oops just checked my log book. It's a 2000. Ahhh well it only stung me 200 off a girl I know 2 years ago and it's passed mot twice with just tires needed each time.
Old 14-12-2011, 23:59   #8
seand1986
Another issue I have is cold mornings. The car isn't hard to start but what it seems to be doing is not firing on all cylinders for a while until it warms up. At least that's what my uncle told me when he had it one cold morning. I'm wondering should I be worried or can this be fixed cheaply?
rover 400 diesel Marksambailey MG/R Modification & Tuning 1 13-06-2010 18:34
Rover 400 Diesel Problem DOOD Diesel Forum! 7 10-08-2009 17:13
Leaking diesel on Rover 400 edward kennedy Diesel Forum! 10 28-06-2009 22:33
Clutch - Rover 400 Diesel sellby MG ZS / Rover 45 & 400 0 22-12-2007 07:15
