How to disconnect rear wiper? - MG-Rover.org Forums
Old 22-12-2011, 18:36   #1
alamb200
Car: Rover 25
Hi,
I have finally got round to buying a bike rack for my Rover 25 but on fitting it I came across a problem.
One of the struts sits on the rear Windows so I cannot use the rear windscreen wiper. My problem is this sometimes my rear wiper starts despite the fact that it is not turned on (something to do with the reverse gear).
My solution is to split the electrics to the rear wiper and put a switch in between so I can turn it on or off depending on whether my bike rack is on the car. The trouble is I cannot work out which wires to cut, can anyone help?
Thanks,
alamb200
alamb200 is offline   Reply With Quote Quick reply to this message
Old 22-12-2011, 18:39   #2
BLMC
Car: -
Thumbs up
As the rear wiper has it's own fuse then that is the place to look.
BLMC is offline   Reply With Quote Quick reply to this message
Old 22-12-2011, 19:29   #3
charlie74
Car: Rover 45
or fit an inline fuse/switch in the hatch wiring next to the actual motor,
but pulling the main fuse is still the best easiest option
charlie74 is offline   Reply With Quote Quick reply to this message
Old 22-12-2011, 19:39   #4
BLMC
Car: -
No need to do that mate, if it's an early car with the regular spade fuses you can use spade connectors in the fuse holder and extend out with wire and use a switch in the wiring.
Old 23-12-2011, 11:15   #5
alamb200
Car: Rover 25
My plan was to mount the switch in the boot through the rear wiper cover.
Is this going to be too difficult?
Old 23-12-2011, 11:24   #6
charlie74
Car: Rover 45
nope,, but i would recommend a cap covered switch,, that way if your carrying anything in the boot, it cant turn it off )))... might save a bit of frustration
Old 23-12-2011, 11:36   #7
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Fix the faulty tailgate wiring loom.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - discount for .org Supporters - PM for details.
technozen is offline   Reply With Quote Quick reply to this message
Old 23-12-2011, 11:36   #8
david.c
Car: MGTF115 & Rover25
Why not take the wiper arm off when you use the carrier? One nut.
david.c is offline   Reply With Quote Quick reply to this message
Old 24-12-2011, 08:22   #9
alamb200
Car: Rover 25
I have tried removing the arm in the past and it is firmly stuck in place and will not shift.
I do not think the wiring loom is faulty I think it is by design if you are in engage reverse with your wipers turned on.
Does anyone know which of the four wires I should cut?
Old 24-12-2011, 12:22   #10
BLMC
Car: -
Don't cut any of the wires, do it the way I told you.
Old 31-12-2011, 15:41   #11
alamb200
Car: Rover 25
No worries I will follow your advice on this.
Can you let me have any instructions on how to get at the fuse connectors so I can make the changes?
Cheers,
alamb200
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
disconnect rear doors from cdl Popeye 89 MG ZR / Rover 25, 200 & Streetwise 0 19-10-2011 15:54
rover 25 rear wiper motor and wiper arm djalien10 For Sale 5 14-09-2009 19:06
HELP - Sunroof, Rear heater and Rear Wiper not working Vantango MG ZR / Rover 25, 200 & Streetwise 3 23-03-2009 15:54
Rover 414Si - 1996 - Rear wiper,rear fog problems!! markus250 MG ZS / Rover 45 & 400 8 16-11-2006 19:37
No sterio, rear wiper, rear window heater & indash alarm light! 216sli 'R8' Rovers (aka Wedges!!) 0 09-09-2006 07:45
