To buy or not to buy? (2001 Rover 25) - MG-Rover.org Forums
Old 12-01-2012, 13:39   #1
RichG11
Car: Rover 25
Hey guys,
I just had my old Astra literally blow up on me. After looking around, Rover 25's seem to offer a lot for not such a huge price.....
But I will cut to the chase. I have found a 2001 1.6L IL 5dr with 67,000 miles on the clock at £775.
I am told these have problems with head gaskets but is there anything else I should look out for?
Any advice would be very happily received as I am on a tight budget with a newborn little girl and other stuff.
Hope im not breaking any rules asking this question, Cheers
Rich
RichG11 is offline   Reply With Quote
Old 12-01-2012, 22:35   #2
MalcQV
Car: Alfa Romeo GT
Had a 2003 1.6 iXL. Never had any HGF's but then I was told it had just been replaced by the garage I bought it from.
Had to repair the cabling to the wash wipe in the rear hatch, they do fracture.
Had a complete new exhaust inc. cat and two front tyres. All the other consumables such as oil obviously.
I bought mine with 60k on an sold it with 78k I think or there about.
A good reliable car and cheap to run
MalcQV is offline   Reply With Quote
Old 12-01-2012, 23:23   #3
MGJohn
MGJohn's Avatar
Car: MG Montego Turbo; Rover 25; R620ti x2 & MGZS 120+ x2
Rich
Hi and
Find a good one and they are exceptional value now. The 1.4 is quite lively and the 1.6 has more poke too. Better to have the 1.6 if you'll be carrying lots of baby stuff and passengers. been there done that althought the 1.4 will cope adequately.
Test drive. Drive that car for for at least 20 miles to get the engine up to fully warmed as only then are issues likely to show if there are any. No need to go silly, just drive normally. Explain to the seller your concerns before buying and on advice by more experienced buyers, you want to drive the car for at least twenty miles. I'd even offer to put a gallon in the car to demonstrate that I'm seriously considering buying the car. If for any reason that twenty mile drive is not possible, I would walk away.
If the test drive is on, then drive the car being all ears and eyes for the twenty miles. Try to include some stop-start stuff and faster speeds ( legal ) on the local dual carriageway. Do not be persuaded that a quick run round the block is sufficient. That will tell you very little.
Assuming that the car checks that it's in obviously good shape regarding body and interior, after that drive with the car nice and warmed up, lift the bonnet and have a good look at things. Look at the Coolant expansion bottle. Is the level of the hot coolant near or a little above the MAX level. That's a good sign if it is. If the coolant is clean and clear, another good sign. Open up the AirFilter housing ( four spring clips ) take out and look at the filter element. Is it fairly new or looks like it came out of the Arc being full of dirt, leaves etc and far from efficient. A good clean engine compartment with newish Oil and Air Filter elements are good signs of a cared for car, moreso than shiney paint and clean carpets in my experience.
Those are key features I would look for on any Rover, particularly those with the sophisticated K-Series engine which has a reputation for cylinder head gasket problems. A search here will show the various checks and what else to look for.
One other thing I would look for is under the timing belt case on the driver's side of the engine. Looking for tell tale signs of coolant loss stains or even wetness there which could mean a worn water pump. I have put up pictures of what to look for when a water pump is worn out or starting to wear out. A quick search here should turn them up. A prime cause of so called gasket 'failure' when worn. A worn water pump is not expensive to replace. Caught in time can save that gasket from problems.
Spend some time on here searching and you will be well equipped to look at that and assess that 1.6 Rover 25. Better still if you can take a more experienced friend along to view it too.
__________________
So, now you wanna buy a BMW .... Huh! No natural class ...
Normally aspirated engines suck. They really do. Good job turbocharged engines blow and suck. That's better.
MGJohn is offline   Reply With Quote
Old 13-01-2012, 09:42   #4
RichG11
Car: Rover 25
This is exactly why I posted here! I knew I would get informed opinions and experience as to what to look for!
Thank you so much. I am still on the look out for a car, strangely enough a 1999 Rover 400 1.4 with 33,000 on the clock has shown up close to me. Very tempted as the price is very good! (£795).
Old 13-01-2012, 10:23   #5
JoeyTaffy93
On se connaît
JoeyTaffy93's Avatar
Car: '54 1.8T MG ZT+, '53 1.4 Rover 25 iL, '03 1.4 Rover 25 Impression
Send a message via MSN to JoeyTaffy93
I own a 2001 1.6 Rover 25 iS, great car and fun to drive, never let me down reliability wise, all I've replaced is a radiator and IMG (quite common but very cheap to fix, cost £5 for the gasket and took about an hour to 2 to fit). Mines at 169,000 miles and doesn't miss a beat.
As for the 414, see if you can get it down to around £650/700.
JoeyTaffy93 is online now   Reply With Quote
Old 13-01-2012, 10:43   #6
RichG11
Car: Rover 25
Thanks for that Joey. Yeah, I am in the process of trying to get a lift to go and view the 400. Before I even leave I will be phoning and offering £700. I don't want to pay more anyway as it needs tax. £800 is my budget all in so....
Old 13-01-2012, 11:15   #7
Rover_King
Car: Rover 45 1.8 Connoisseur
What astra was it and what happened?
Rover_King is offline   Reply With Quote
Old 13-01-2012, 11:16   #8
JoeyTaffy93
On se connaît
Not a problem mate and best of luck with it.
Old 13-01-2012, 11:21   #9
RichG11
Car: Rover 25
it was a 1996 Astra 1.7 TDS, the one with the isuzu engine. I basically bought it for £500 3.5 years ago and ran it into the ground lol. It went for its MOT the other day and while it was on the rollers the passenger side front brake calliper actually exploded. On top of that nearly every brake line was split, big hole in the middle of the exhaust and something to do with the floor of it was rotten....
The repairs were going to cost a good £250 so i just decided to cut my losses and take £100 and use it as an excuse to buy a new car lol.
You may not post replies
Rover 200VI for sale! Two options – Buy to fix / buy for parts djbarry06 MG ZR / Rover 25, 200 & Streetwise 7 24-01-2011 23:11
Rover 827 Coupe To buy or not to buy! John T Kelly Rover 800 3 30-07-2008 23:08
Rover 25 - Now what would you buy? Ian MG ZR / Rover 25, 200 & Streetwise 50 24-03-2006 12:03
should i buy a rover 25? edwardcasbon MG ZR / Rover 25, 200 & Streetwise 13 07-11-2004 23:08
Rover 420 - to buy or not to buy? new boy Others 11 21-02-2003 09:13
