Pre 2000 Diagnostics - Page 2 - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > MGF and MGTF (Sponsored by MGF Mania)
Old 03-02-2012, 18:41   #21
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
I believe it's from 9.2 onwards, mine is v9.8
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here.
Fob not working? Common faults and fixes here.
Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available.
Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here
Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details.
technozen is offline   Reply With Quote
Old 03-02-2012, 21:18   #22
HansonAutos
Car: ZR:105, 220 Coupe Turbo
Send a message via AIM to HansonAutos Send a message via Skype™ to HansonAutos
Can they be easily updated?
Any ideas if these can do the same:
http://www.ebay.co.uk/itm/1507476578...84.m1438.l2649
I've been toying with the idea or ordering one of these as they do alot more cars and can program keys etc.
HansonAutos is offline   Reply With Quote
Old 03-02-2012, 21:29   #23
technozen
Mmmm....Rover..
technozen's Avatar
The SBB unit spec doesn't mention its ability to read/erase fault codes or security match ECU's.
I have no idea if the T300+ can be updated.
__________________
Old 06-02-2012, 18:20   #24
technozen
Mmmm....Rover..
technozen's Avatar
I can also confirm the the T300+ will allow adjustment of engine idle and CO levels, so far only tried on MEMS1.9 and 2J.
__________________
Old 06-02-2012, 19:18   #25
Broon
Car: MGF MK2 1.8i,BMW 330i
Turns out ive got v9.2. do you know if its possible to update the software at all. Advanced diagnostics seem to have updates but you have to have bought it form them I think
Broon is offline   Reply With Quote
Old 06-02-2012, 19:33   #26
technozen
Mmmm....Rover..
technozen's Avatar
It should work.
Using the 5AS cable try to connect to your car by selecting ZR from the Remotes menu.
If it doesn't connect then your unit will code Pektron fobs
__________________
Old 06-02-2012, 19:44   #27
Broon
It should work.
So do you still use the 5AS cable for Pektron, or the standard cable?
Old 06-02-2012, 19:49   #28
technozen
Mmmm....Rover..
technozen's Avatar
The standard OBD cable.
__________________
Old 06-02-2012, 19:57   #29
Broon
Old 06-02-2012, 21:56   #30
Mgwanderer
Now thats Beauty
Mgwanderer's Avatar
Location: Kortrijk (Belgium)(originally from Liverpool)
Car: MGTD, MGA,MGF(Mk2 Dec 2000) Jaguar X-type estate
I haven't played with the tool much but can confirm that it does the following....
Reads and clears faults on the following ecu's
MEMS 1.6, 1.9, 2J, 3.
It also gives live data and allows you to do actuator tests, ie turn on the cooling fan etc.
Fob coding to the 5AS, reading and modifying the EKA code.
Security match the 5AS and engine ECU if either are replaced.
The 5AS options require a different lead to the ECU diagnostics but this is easy enough to make or it can be bought made up.
I have yet to investigate the Pektron fob programming as I don't have access to a vehicle with this system.
Have you also had live data out of the mems 1.9 as I can do the reading faults and clearing them, read the EKA code but I have not been able to read live data
Mgwanderer is offline   Reply With Quote
Old 06-02-2012, 22:06   #31
technozen
Mmmm....Rover..
technozen's Avatar
Yes, I have had live data from MEMS 1.9, 2J and 3.
__________________
Old 06-02-2012, 22:17   #32
Mgwanderer
Now thats Beauty
Mgwanderer's Avatar
What cable are you using for live data from 1.9 mems??
Old 06-02-2012, 22:34   #33
Mattlav
Car: MGF 1.8 16v 1998
Send a message via MSN to Mattlav Send a message via Skype™ to Mattlav
on this note.. how do you find out exactly what type/software etc is? i have a 1998 MGF but little unsure about its actuall port/software?
Mattlav is offline   Reply With Quote
Old 06-02-2012, 23:58   #34
Broon
You shouldn't have MEMS3 as they started in 2000, so will be 1.9 or 2J. 1.9 has ONE connector on the side of ECU, 2J has TWO connectors
Old 07-02-2012, 04:59   #35
Mgwanderer
Now thats Beauty
Mgwanderer's Avatar
Good morning Broon,
have you managed to get live data out of a 1.9 mems unit and if so what cable did you use?
Old 07-02-2012, 10:50   #36
Broon
Originally Posted by Mgwanderer View Post
Good morning Broon,
Ive never tried. I don't know anyone with an older F.
Old 07-02-2012, 11:05   #37
Mgwanderer
Now thats Beauty
Mgwanderer's Avatar
Thanks for the reply, I have asked the question about the cable to Technozen as well as he has had it working so hope he replies.
I have retrieved the fault codes etc but cannot seem to get live data..
Old 07-02-2012, 11:12   #38
Broon
He said he got live data form 1.9, so I guess its from the standard OBD cable as the 5As cable is just for the 5AS ECU. what software version do you have
Old 07-02-2012, 11:16   #39
Mgwanderer
Now thats Beauty
Mgwanderer's Avatar
I have 9.2 and am very happy with the unit , what do you have
Old 07-02-2012, 21:24   #40
technozen
Mmmm....Rover..
technozen's Avatar
I initially used the OBD cable that came with the unit and had live data with it from my MEMS2J 200VI and a MEMS1.9 Rover 400.
I then made up a lead for 5AS programming and decided to add a switch which allows me to use one lead for MEMS and 5AS, this lead gave me live data on MEMS1.9/2J/3.
Since the weekend I have had live data on a Jag XK8, Vauxhall Astra, Rover 25 and an MGF.
__________________
You may not post replies
= pre 2000 mg exhaust adaptor + exhaust gaskets + fuel filter = super_cds For Sale 1 09-06-2011 19:12
= mgf cat - downpipe - pre 2000 exhaust adaptor - exhaust rubbers - gaskets = super_cds For Sale 1 29-08-2010 15:59
2000 Rover 45 1.8 Connoisseur VS 2000 BMW 318i saloon Rover_King Other Motoring Chat 30 04-02-2010 14:39
Diagnostics on a 2000 25 TheBoy MG ZR / Rover 25, 200 & Streetwise 1 10-07-2009 18:11
Pre-pre FandM meet? ANDYJ_ZR Scotland 165 09-05-2006 16:42
