#41 | |
Now thats Beauty
Location: Kortrijk (Belgium)(originally from Liverpool) Car: MGTD, MGA,MGF(Mk2 Dec 2000)
Thanks i'll try the OBD cable for live data, what are you switching to be able to do that??? Last edited by Mgwanderer; 07-02-2012 at 21:48. |
| Sponsored Links | |||
Advertisement | |||
#42 |
Mmmm....Rover..
The 5AS uses two data lines, a separate IN and OUT. On the diagnostic connector these are pins 3 and 1.
MEMS uses a single bi-directional line on Pin 7. Pin 3 and Pin 7 end up at the same pin on the DB25 connector at the T300 so the switch simply connects the correct one depending on what the lead is being used for.
__________________
I offer FREE engine/alarm diagnostics and fob coding (incl. Pektron fobs) to mg-rover.org Supporters - details here. Fob not working? Common faults and fixes here. Pektron BCU/SCU Faulty? This may be of some help. Full SCU programming and repair services available. Discounted SCU/BCU Full Relay Replacement Service - only for Supporters - details here Replacement relays for the Pektron SCU available - .org Supporters buy 4, 5th is free - PM for details. |
#43 | |
Now thats Beauty
I will let you know the outcome Once again many thanks |
#44 |
I have a Faultmate diagnostic system made by Blackbox Solutions. It does most everything Rover's Testbook does. You only buy the software you need for your application and it is suitable for just about every MG-Rover vehicle. It works very well on my early MGF with it's MEMS 1.9.
http://www.blackbox-solutions.com/products.html (Not the easiest site to navigate FYI) |
#45 |
Just looked i have one connection and a small lead.. so MEMS 1.9? anything i can do/get that isnt too expensive?
#46 |
Location: Originally from Bath UK, now Meggen, Lucerne Switzerland Car: MGF VVC and Audi A6 3.0 ltr Quattro Avant
I received my T300 unit last week.
Cabled it up and it all works. Cleared all fault data (all historic and in relation to high voltages at various sensors plus one low battery). Also reads live data. Good value for what it does and came in case. I have a MEMS 2J. |
#47 |
is it possible to shoot a video on the use of the tool??
or is it so easy to use..?? also, what is the case with this cable..?? http://themgclub.org/showthread.php?p=4115101 Last edited by nikolas; 29-02-2012 at 12:21. |
#48 | |
#49 |
i m looking forward to receiving mine..
all necessary equipment is included, right..?? |
#50 |
Location: South Bucks Car: MGF VVC, ZS 135+, Toyota RAV4
#51 |
#52 |
that grinds my gears
does this work with diesels?
#53 |
Definitely be interested in one of these - seems like a very useful bit of kit considering i need to get a fob programmed anyway!
Do yo think it would work on a 1998 Range Rover too? |
#54 |
I suspect it does as RR is LR and that is on the list of manufacturers the kit deals with.
#55 |
Great news as keeping the Landy going on a severe budget is not so easy! I don't want to get rid of it as it was my dads before he died so it's got sentimental value (and actually a great car too).
#56 |
Got mine today, so far used it on the 'F' ( Mems 2J ) used it to clear historic faults, and I can confirm it WILL talk to the ecu.
#57 |
Mmmm....Rover..
__________________
#58 |
am i doing sth wrong, or mine is faulty../?
![]() do you have a rover specific plug or you use the obd2 one? mine doesn't have rover specific plug..i connected obd2, never started.. ![]() i then tsted it on familys Polo it blinked for a while, then it started..seemed.. ok.. i unplugged it, and replugged it to confirm that it would start again, but it wouldn't start.. shall i think of replacing it?? |
#59 | |
Worked fine on mine first time. Plug in first and then turn on ignition to 2 for historic faults or 3 (ie start) for live data. Make sure plug fully in both ends. There is a right way up. |
#60 |
it worked only one time on family's Polo,
and never turned on since then.. ![]() also the only time that turned on, the screen blinked for a while, which didnt seem normal.. either there is problem with the wires, or with the tool itself.. |
| Bookmarks |
| Thread Tools | |
| = pre 2000 mg exhaust adaptor + exhaust gaskets + fuel filter = | super_cds | For Sale | 1 | 09-06-2011 19:12 |
| = mgf cat - downpipe - pre 2000 exhaust adaptor - exhaust rubbers - gaskets = | super_cds | For Sale | 1 | 29-08-2010 15:59 |
| 2000 Rover 45 1.8 Connoisseur VS 2000 BMW 318i saloon | Rover_King | Other Motoring Chat | 30 | 04-02-2010 14:39 |
| Diagnostics on a 2000 25 | TheBoy | MG ZR / Rover 25, 200 & Streetwise | 1 | 10-07-2009 18:11 |
| Pre-pre FandM meet? | ANDYJ_ZR | Scotland | 165 | 09-05-2006 16:42 |
