MGF Ride Height - MG-Rover.org Forums
Old 26-01-2012, 19:45   #1
moomoo
Car: MGF
MGF Ride Height
After fitting my new alloys this evening i got the tape measure out and checked my ride height. I know i need to pump up the Hydragas but as it stands my rear is 30cm from centre of alloy to wheel arch and my front is 32cm. This is a good 5cm lower than it should be. Im not going to get chance to sort this for a week or so. If i drive my car as it is will it cause any potential damage or is it just a case of avoiding lumps and bumps? I read somewhere about the membranes in the hydragas cylinders my be damaged if its run too low?
moomoo is offline   Reply With Quote Quick reply to this message
Old 26-01-2012, 19:49   #2
IanMc
Reap what you sow......
IanMc's Avatar
Car: Flame Red '95 MGF, 10 Reg Suzuki Swift, 55 Reg Vectra, 07 C1 & 02 Clio...
I would say that any damage that may occur, may already have occurred. I wouldn't think another week will make any difference one way or another.
__________________
Treat others as you would like to be treated yourself.....
IanMc is online now   Reply With Quote Quick reply to this message
Old 26-01-2012, 22:00   #3
Hobby
Car: MGF
You did'nt say what size wheels you put on, but if its 16" trophy or similar what should the height be?? With 15" it should be about 35cm or 350mm so if an inch is added thats 25mm or 2.5cm divided by 2 from centre hub thats 12.5mm or 1.2cm so the height should be 238mm or 23.8cm. Is this correct??
Hobby is offline   Reply With Quote Quick reply to this message
Old 26-01-2012, 22:05   #4
moomoo
Car: MGF
Im running 16" 11 spoke alloys at the moment.
Old 26-01-2012, 22:10   #5
Benfinlayson
Car: MGF
You measure from the centre Of the wheel to the arch so therefore the distance should be the same whatever the wheel size.
Benfinlayson is offline   Reply With Quote Quick reply to this message
Old 26-01-2012, 22:15   #6
Hobby
Car: MGF
THINK YOU ARE CORRECT !!!!!!
Old 26-01-2012, 22:22   #7
Carl
One off a full set
Car: MG ZS 180 MG ZT CDTi 135+ ,MGF 75th Anniversary, MG ZT 120+
Send a message via MSN to Carl Send a message via Skype™ to Carl
if the ride is low then they tyres will suffer - especially the inside edge - the ride height should be 368 +/- 10mm (IRRC) - as its axel center to arch lip the wheel size doesnt matter
Carl is offline   Reply With Quote Quick reply to this message
MGF Ride height Peitolm MGF and MGTF (Sponsored by MGFnTFBITZ) 18 23-11-2009 13:49
mgf ride height bmw4me MGF and MGTF (Sponsored by MGFnTFBITZ) 3 18-09-2009 14:30
What's your MGF ride height? richgould MGF and MGTF (Sponsored by MGFnTFBITZ) 6 05-07-2008 11:44
MGF ride height Christine MGF and MGTF (Sponsored by MGFnTFBITZ) 2 26-05-2008 16:44
