just changed - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > 'R8' Rovers (aka Wedges!!)
Old 07-02-2012, 17:09   #1
jensden51
Car: Rover 200 (89-95)
just changed
Hi, I have just changed my anti-freeze today, drained and flushed twice, but I can get less than 3 litres back in, surely thats not enough?
Dennis.
jensden51 is offline   Reply With Quote
Old 07-02-2012, 19:00   #2
Turb
Car: 218 SLD
Run the engine and squeeze the rad pipes to bleed it through.
Turb is offline   Reply With Quote
Old 07-02-2012, 19:13   #3
jensden51
Hi ,took bleed screw out, engine running, hoses squeezed, but still less than 3 litres of water to refill.
Old 07-02-2012, 19:18   #4
Stu
Administrator
Stu's Avatar
Car: Saab 93 Vert + Alfa Mito Turbo
Send a message via MSN to Stu Send a message via Skype™ to Stu
Have you got the circulation going into the heater matrix?
__________________
Stu
Get cash back on your Insurance and many other web purchases through Quidco
Stu is offline   Reply With Quote
Old 07-02-2012, 19:22   #5
jensden51
Hi Stu, yes heater getting hot.
Dennis
Old 07-02-2012, 21:42   #6
stevmo
Car: Ford Mondeo ST24
there will still be an amount in the matrix. I had this when I drained cooling system in my mondeo 2.0 and capacity is 6 litres approx and I got 3.5 in.
stevmo is offline   Reply With Quote
Old 07-02-2012, 22:42   #7
TR1CKY
Car: Rover 220 Coupe TURBO
Send a message via MSN to TR1CKY
Have you run the engine with the expansion cap off? Could be an airlock that needs to bubble it's way out.
TR1CKY is offline   Reply With Quote
Old 08-02-2012, 06:25   #8
jensden51
Hi, Tried everything suggested, will try again later today. thanks for replies.
Dennis
Old 09-02-2012, 01:46   #9
bkevbush
Car: 216gti tc
the system holds 5.8ltrs but then the question is how much came out?ive never found the bleed screw much use as its not at the highest point in the system!the expansion tank is,also just running it doesnt always seem to get it to bleed,i found get it on a slope or jack up front a bit(assuming your expansion tank is at front of bay)fill up as normal with heater valve open(hot)check its moving freely on bulkhead.then drive it a couple of miles pull over and check level again top up as nescessary,this method always worked best for my k series car
bkevbush is offline   Reply With Quote
Old 09-02-2012, 07:46   #10
jensden51
Thanks for all replies, checked all again, heater hot, radiator hot, top and bottom hoses hot, so hoping all is now ok.
Dennis.
You may not post replies
Anybody changed these? Storm_9010 MG ZR / Rover 25, 200 & Streetwise 9 03-03-2011 19:03
Has anyone ever changed the spoiler? reeder139 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 04-08-2010 15:58
I've changed my name :D Hayes'ee England - North 3 03-06-2010 17:03
Who's changed our name? Red Devil MGF and MGTF (Sponsored by MGF Mania) 45 09-10-2008 16:24
When have they changed that? VandenPlas MG / Rover Related Chat - up to 2005 10 15-06-2004 19:54
