Thermostat on a Rover 45 Diesel? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 18-02-2012, 19:38   #1
chris.vincent3
Car: MG ZR MK1 1.8 120 RIP & MG ZR TD 170BHP RIP & Audi A3 2.0TDI
Send a message via MSN to chris.vincent3
Hi, looking for a thermostat for a diesel Rover 45 was quoted 30 for one from Seward and pretty sure i can fine one cheaper then that.
They the same throughout the L-Series range?
Is this the part number for it? PBM100040.
Thanks Chris.
chris.vincent3 is offline   Reply With Quote Quick reply to this message
Old 18-02-2012, 19:51   #2
bizzay1
Car: The Rover Died, Now Running A SAAB 9-5
http://www.ebay.co.uk/itm/Land-Rover...item3a6d2ca7cf
according to this that pn is for a landrover and won't fit a 45
bizzay1 is offline   Reply With Quote Quick reply to this message
Old 18-02-2012, 19:53   #3
chris.vincent3
thats what i thought when i tried in the compatability options then from that point i wasnt sure, so thought id ask on here.
as according to rimmerbros its the same part number so should fit :/
Old 19-02-2012, 09:32   #4
Rik420SDi
Car: Hyundai F2 Evo, 216 Cabby
Wrong.
A thermostat with that part number will definately 100% fit all L-series engines where the thermostat is located within the lower half of the Oil Cooler. It is also a series one Freelander part, and is rated at 82C.
Rik420SDi is offline   Reply With Quote Quick reply to this message
Old 19-02-2012, 13:38   #5
chris.vincent3
Originally Posted by Rik420SDi View Post
Wrong.
Ah so the part number I've linked is for the part I need needless of what car its listed for.
Old 19-02-2012, 14:00   #6
Rik420SDi
Correct. Looks exactly the same as the one I purchased. I never fitted it (didn't need it afterall) but sold it to ZRCH4S who fitted it to his.
If your thermostat locates in the lower half of the oil cooler then it's the correct part, no question.
Old 21-12-2014, 12:47   #7
GeoStationary
Car: Rover 45
Old thread but relevant. How do you tell which version of the thermostat is needed? Apparently there are two types for the 45 diesel.
GeoStationary is offline   Reply With Quote Quick reply to this message
Old 21-12-2014, 22:24   #8
E_T_V
Car: Maestros, 200, 600, ZTT
Look. If there is a big plastic housing on the front of the engine then its the earlier thermostat. If not then it is inside the oil cooler and is a conventional type thermostat.
E_T_V is offline   Reply With Quote Quick reply to this message
Rover 45 thermostat for the 2.0TD sarie Diesel Forum! 18 12-01-2011 09:55
rover 45 td thermostat neillluk Diesel Forum! 7 29-12-2010 11:58
thermostat on rover 45 emmz29 MG ZS / Rover 45 & 400 6 25-11-2010 20:34
Thermostat gone? 1.6i rover 45 W reg Fast Guy MG ZS / Rover 45 & 400 6 08-05-2010 12:14
Rover 75 2.0 diesel thermostat location Sirrius MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 23-01-2010 19:12
